Discuss
Burner knob/shaft feels broken on cooktop
 in
Hello-- While cooking last night, one of my knobs seems to have broken. Not the knob, but the shaft that
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Burner knob/shaft feels broken on cooktop
  #1 (permalink)
Old 03-09-2008, 11:30 AM
jeffthx jeffthx is offline
Junior Member
jeffthx is on a distinguished road
Default Burner knob/shaft feels broken on cooktop
Model Number: GJC3634   Brand: Whirlpool   Age: 1 - 5 years
Hello--
While cooking last night, one of my knobs seems to have broken. Not the knob, but the shaft that the knob sits on. It isn't "tight" in its place--I can move the shaft around (like a loose tooth), and it gives when I push on it. I can't seem to turn the knob/shaft--it just sits there moving in every direction except rotating like it's supposed to. As a result, I can't turn the burner on or off. Luckily the burner actually is off right now.
I'm somewhat comfortable making simple repairs, and this one seems like it would be easy if I can figure out the right part that I need (assuming a part is needed instead of just making an adjustment), and if I can figure out how to get to the piece that needs to be fixed.
Any thoughts or suggestions will be appreciated.
Thanks,
Jeff
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-10-2008, 11:14 AM
Junior Member
Default
Looking over the parts breakdown, it looks like I need to order the entire switch (which I have done). I can't easily fix the shaft itself--the whole switch has to be replaced.
If anyone has any suggestions that I should keep in mind when I replace this part, I'd appreciate it.
Thanks,
Jeff
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Radiant Cooktop - Burner regulation NG Gabrielle Oven Repair (including Ranges and Cooktops) 3 Yesterday 11:48 AM
replace broken cooktop Jeff Vandervort Oven Repair (including Ranges and Cooktops) 0 01-15-2008 12:08 PM
One burner is broken in Glass Top Electric Range sval79 Oven Repair (including Ranges and Cooktops) 0 12-31-2007 01:03 PM
Thermador Cooktop - burner sparks but no gas flow dmullerd Oven Repair (including Ranges and Cooktops) 2 11-25-2007 07:01 PM
Hardwic Gas stove burner knob chinook bloodhounds Oven Repair (including Ranges and Cooktops) 2 10-02-2007 07:17 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
