Discuss
fridgidaire, fges3065kw, hot element indicator stays on
 in
The hot element indicator stays on even though its not hot. Its only the front right burner that has this
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » fridgidaire, fges3065kw, hot element indicator stays on
  #1 (permalink)
Old 11-29-2009, 07:22 AM
Junior Member
Rooster4g is on a distinguished road
Post fridgidaire, fges3065kw, hot element indicator stays on
Model Number: fges3065kw   Brand: Frigidaire   Age: Less than 1 year
The hot element indicator stays on even though its not hot. Its only the front right burner that has this issue.
Related Models
Frigidaire FGES3065KWA ELECTRIC RANGE
Frigidaire FGES3065KWB ELECTRIC RANGE
Frigidaire FGES3065KWC ELECTRIC RANGE
Frigidaire FGES3065KWD ELECTRIC RANGE
Frigidaire FGES3075KBA ELECTRIC RANGE
Frigidaire FGES3075KBB ELECTRIC RANGE
Frigidaire FGES3075KBC ELECTRIC RANGE
Frigidaire FGES3075KBD ELECTRIC RANGE
Frigidaire FGES3075KWA ELECTRIC RANGE
Frigidaire FGES3075KWB ELECTRIC RANGE
Frigidaire FGES3075KWC ELECTRIC RANGE
Frigidaire FGES3075KWD ELECTRIC RANGE
Frigidaire FGET2745KBA WALLOVEN
Frigidaire FGET2745KFA WALLOVEN
Frigidaire FGET2745KWA WALLOVEN
Frigidaire FGET2765KBA WALLOVEN
Frigidaire FGET2765KFA WALLOVEN
Frigidaire FGET2765KWA WALLOVEN
Frigidaire FGET3045KBA WALLOVEN
Frigidaire FGET3045KFA WALLOVEN
Frigidaire FGET3045KWA WALLOVEN
Frigidaire FGET3065KBA WALLOVEN
Frigidaire FGET3065KFA WALLOVEN
Frigidaire FGET3065KWA WALLOVEN
Frigidaire FGEW2745KBA WALLOVEN
Frigidaire FGEW2745KBB WALLOVEN
Frigidaire FGEW2745KFA WALLOVEN
Frigidaire FGEW2745KFB WALLOVEN
Frigidaire FGEW2745KWA WALLOVEN
Frigidaire FGEW2745KWB WALLOVEN
Frigidaire FGEW2765KBA WALLOVEN
Frigidaire FGEW2765KBB WALLOVEN
Frigidaire FGEW2765KFA WALLOVEN
Frigidaire FGEW2765KFB WALLOVEN
Frigidaire FGEW2765KWA WALLOVEN
Frigidaire FGEW2765KWB WALLOVEN
Frigidaire FGEW3045KBA WALLOVEN
Frigidaire FGEW3045KBB WALLOVEN
Frigidaire FGEW3045KFA WALLOVEN
Frigidaire FGEW3045KFB WALLOVEN
Frigidaire FGEW3045KWA WALLOVEN
Frigidaire FGEW3045KWB WALLOVEN
Frigidaire FGEW3065KBA WALLOVEN
Frigidaire FGEW3065KBB WALLOVEN
Frigidaire FGEW3065KFA WALLOVEN
Frigidaire FGEW3065KFB WALLOVEN
Frigidaire FGEW3065KWA WALLOVEN
Frigidaire FGEW3065KWB WALLOVEN
Frigidaire FGF303BWA Frigidaire/gas Range
Frigidaire FGF303CWA Frigidaire/gas Range
Frigidaire FGF303CWB Frigidaire/gas Range
Frigidaire FGF303CWC Frigidaire/gas Range
Frigidaire FGF303CWD Frigidaire/gas Range
Frigidaire FGF303CWE Frigidaire/gas Range
Frigidaire FGF303CWF Frigidaire/gas Range
Frigidaire FGF303CWG GAS RANGE
Frigidaire FGF303KWA GAS RANGE
Frigidaire FGF303LWA GAS RANGE
Frigidaire FGF303LWB GAS RANGE
Frigidaire FGF311PHSD Frigidaire/gas Range
Frigidaire FGF311PHSE Frigidaire/gas Range
Frigidaire FGF312ASA Frigidaire/range
Frigidaire FGF312BSA Frigidaire/gas Range
Frigidaire FGF312BSB Frigidaire/gas Range
Frigidaire FGF312DSA Frigidaire/gas Range
Frigidaire FGF313BADA Frg(v2) / Gas Range
Frigidaire FGF313BAWA Frg(v1) / Gas Range
Frigidaire FGF316AQA Frigidaire/range
Frigidaire FGF316AQB Frigidaire/gas Range
Frigidaire FGF316ASA Frigidaire/range
Frigidaire FGF316ASB Frigidaire/gas Range
Frigidaire FGF316BQA Frigidaire/gas Range
Frigidaire FGF316BQB Frigidaire/gas Range
Frigidaire FGF316BQC Frigidaire/gas Range
Frigidaire FGF316BQD Frigidaire/gas Range
Frigidaire FGF316BSA Frigidaire/gas Range
Frigidaire FGF316BSB Frigidaire/gas Range
Frigidaire FGF316BSC Frigidaire/gas Range
Frigidaire FGF316BSE Frigidaire/gas Range
Frigidaire FGF316DQA Frigidaire/gas Range
Frigidaire FGF316DQB Frigidaire/gas Range
Frigidaire FGF316DQC Frigidaire/range
Frigidaire FGF316DQD Frigidaire/range
Frigidaire FGF316DQE Frigidaire/range
Frigidaire FGF316DQF GAS RANGE
Frigidaire FGF316DQG GAS RANGE
Frigidaire FGF316DQH GAS RANGE
Frigidaire FGF316DQX GAS RANGE
Frigidaire FGF316DSA Frigidaire/gas Range
Frigidaire FGF316DSB Frigidaire/gas Range
Frigidaire FGF316DSC Frigidaire/range
Frigidaire FGF316DSD Frigidaire/range
Frigidaire FGF316DSE Frigidaire/range
Frigidaire FGF316DSF GAS RANGE
Frigidaire FGF316DSG GAS RANGE
Frigidaire FGF316DSH GAS RANGE
Frigidaire FGF316DSJ GAS RANGE
Frigidaire FGF316WGSA Frg(v1) / Gas Range
Frigidaire FGF316WGSC Frg(v1) / Gas Range
Frigidaire FGF316WGSD Frg(v1) / Gas Range
Frigidaire FGF316WGSE Frg(v2) / Gas Range
Frigidaire FGF316WGSF Frg(v3) / Gas Range
Frigidaire FGF316WGSG GAS RANGE
Frigidaire FGF316WGSH GAS RANGE
Frigidaire FGF316WGSJ Frigidaire/gas Range
Frigidaire FGF316WGSK Frigidaire/gas Range
Frigidaire FGF316WGTA Frg(v2) / Gas Range
Frigidaire FGF316WGTC Frg(v2) / Gas Range
Frigidaire FGF316WGTD Frg(v4) / Gas Range
Frigidaire FGF316WGTE Frg(v5) / Gas Range
Frigidaire FGF316WGTF Frg(v6) / Gas Range
Frigidaire FGF316WGTG GAS RANGE
Frigidaire FGF316WGTH GAS RANGE
Frigidaire FGF318ECA Frigidaire/range
Frigidaire FGF318ECB Frigidaire/range
Frigidaire FGF318ECC Frigidaire/range
Frigidaire FGF318ECD Frigidaire/gas Range
Frigidaire FGF318GCA GAS RANGE
Frigidaire FGF318GCB GAS RANGE
Frigidaire FGF318GCC GAS RANGE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
indicator light stays on between left switches David May Oven Repair (including Ranges and Cooktops) 1 11-03-2009 06:42 AM
Burner doesn't work & hot indicator light stays on joaroe Oven Repair (including Ranges and Cooktops) 2 08-04-2009 08:12 PM
Ge Range Cooktop Hot Indicator Stays On For Hours MIKE HAMULAK Oven Repair (including Ranges and Cooktops) 0 11-17-2008 08:28 AM
surface indicator light stays on slomotion Oven Repair (including Ranges and Cooktops) 0 05-22-2008 10:30 AM
radiant cooktop unit-on indicator light stays on muggy442 Oven Repair (including Ranges and Cooktops) 0 02-15-2008 03:01 PM
