Discuss
Whirlpool fault code E6 F2
 in
Gene, have read all you previous posts. I have the e6 f2 problem as well. unplugged the ribbon cable turned
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whirlpool fault code E6 F2
  #1 (permalink)
Old 11-26-2009, 09:21 PM
Junior Member
msdabbert is on a distinguished road
Default Whirlpool fault code E6 F2
Brand: -brand-   Age: Less than 1 year
Gene, have read all you previous posts. I have the e6 f2 problem as well. unplugged the ribbon cable turned back on and got the e1 f2, them my display went blank. Yesterday it beeped a few times and went blank. If I cut the power for awhile and then restore it the oven will work for a short time and will sometimes give the e6 f2 and will sometimes just be entirely blank, put the panel will beep if i press buttons but the oven wont run. Not sure if I should go panel or board. any help would be appreciated.
Ads By Google
  #2 (permalink)
Old 10-20-2011, 12:35 PM
Junior Member
btaler is on a distinguished road
Default
What did you find? I have the exact same problem.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool fault code E6 F2 Shawn Oven Repair (including Ranges and Cooktops) 262 03-20-2013 01:21 PM
Whirlpool fault code E6 F2 pcbulins Oven Repair (including Ranges and Cooktops) 0 11-19-2009 07:44 PM
whirlpool f7 fault code copper Microwave Repair 0 08-15-2009 10:46 AM
Whirlpool Fault code F2 mrbruce300 Washer Repair 1 07-15-2009 01:58 PM
Whirlpool Fault code E2 F3 t6865mc Oven Repair (including Ranges and Cooktops) 1 02-27-2009 05:57 AM
