Discuss
Electric Stove, wiring help..
 in
ok guys, this is funny. I was cleaning the stove real quick when i stupidly raised the bake element on
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Electric Stove, wiring help..
  #1 (permalink)
Old 11-25-2009, 07:31 PM
Junior Member
anibal is on a distinguished road
Default Electric Stove, wiring help..
Brand: Kenmore   Age: 5 - 10 years
ok guys, this is funny. I was cleaning the stove real quick when i stupidly raised the bake element on the bottom and it damn shorted to the inner stove chassis.
well needless to say I popped a 60 amp fuse at the box (old building/condo).
Replaced the fuse, bake element but when I check the wires at the block behind the stove, between neutral and red it is open....good... but between neutral and black I see about 328 ohms.
is that right?
Ads By Google
  #2 (permalink)
Old 11-26-2009, 05:23 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
You did not say what the problem is.
One side of the line (120 volts) is used to run the timer, lights etc so it is normal to see a resistance on one side and not the other.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Wiring foul-up for Jenn-Air Gas Electric range? bongo_geff Oven Repair (including Ranges and Cooktops) 6 11-05-2009 06:38 AM
electric range surface burner wiring drexelpats Oven Repair (including Ranges and Cooktops) 1 09-11-2009 09:45 AM
How to replace wiring--Thermador Stove Top Range bevbev Microwave Repair 1 07-25-2009 07:57 PM
Need to replace wiring harness on electric stovetop blarzelere Oven Repair (including Ranges and Cooktops) 0 05-30-2009 08:42 PM
need wiring diagram for kenmore electric dryer heilman47978 Dryer Repair 0 12-13-2008 07:01 PM
