Discuss
Oven doesn,t heat up.
 in
While the oven was in use I heard a loud pop. The oven displayed a F1 error code. After clearing
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven doesn,t heat up.
  #1 (permalink)
Old 11-25-2009, 05:15 PM
Junior Member
BamaJud is on a distinguished road
Unhappy Oven doesn,t heat up.
Model Number: 79095321301   Brand: Kenmore   Age: 5 - 10 years
While the oven was in use I heard a loud pop. The oven displayed a F1 error code. After clearing the error code by pressing and holding the Clear/Stop button. My oven will not heat=up, neither element will heat-up.
Could it be my tempature Probe?
Ads By Google
Related Models
Kenmore 791.0  HAIR CLIPPERS
Kenmore 791.4  HAIR CLIPPERS
Kenmore 791.6102190  GAS RANGE
Kenmore 791.6102890  GAS RANGE
Kenmore 791.6112190  GAS RANGE
Kenmore 791.6112890  GAS RANGE
Kenmore 791.6162190  GAS RANGE
Kenmore 791.6162890  GAS RANGE
Kenmore 791.6262190  ELECTRIC RANGE
Kenmore 791.6262890  ELECTRIC RANGE
Kenmore 791.6272190  ELECTRIC RANGE
Kenmore 791.6272890  ELECTRIC RANGE
Kenmore 791.6302190  GAS RANGE
Kenmore 791.6302890  GAS RANGE
Kenmore 791.6412190  ELECTRIC RANGE
Kenmore 791.6412890  ELECTRIC RANGE
Kenmore 791.734891  GAS RANGE
Kenmore 791.734898  GAS RANGE
Kenmore 791.783889  GAS RANGE
Kenmore 791.7838890  KENMORE GAS RANGE
Kenmore 791.7838891  GAS RANGE
Kenmore 791.7839090  GAS RANGE
Kenmore 791.7839091  GAS RANGE
Kenmore 791.7839092  GAS RANGE
Kenmore 791.7839094  GAS RANGE
Kenmore 791.785889  GAS RANGE
Kenmore 791.7858890  KENMORE GAS RANGE
Kenmore 791.7858892  GAS RANGE
Kenmore 791.7859090  GAS RANGE
Kenmore 791.7859091  GAS RANGE
Kenmore 791.7859092  GAS RANGE
Kenmore 791.7859093  GAS RANGE
Kenmore 791.7859094  GAS RANGE
Kenmore 791.7859095  GAS RANGE
Kenmore 791.7898810  KENMORE GAS RANGE
Kenmore 791.7898814  GAS RANGE
Kenmore 791.7898815  GAS RANGE
Kenmore 791.7898884  GAS RANGE
Kenmore 791.7898885  GAS RANGE
Kenmore 791.7898894  GAS RANGE
Kenmore 791.7898895  GAS RANGE
Kenmore 791.7899010  GAS RANGE
Kenmore 791.7899011  GAS RANGE
Kenmore 791.7899012  GAS RANGE
Kenmore 791.7899080  GAS RANGE
Kenmore 791.7899081  GAS RANGE
Kenmore 791.7899082  GAS RANGE
Kenmore 791.7899090  GAS RANGE
Kenmore 791.7899091  GAS RANGE
Kenmore 791.7899092  GAS RANGE
Kenmore 791.9338911  ELECTRIC RANGE
Kenmore 791.9338913  ELECTRIC RANGE
Kenmore 791.9338981  ELECTRIC RANGE
Kenmore 791.9338983  ELECTRIC RANGE
Magic Chef 79F-5EXW
Magic Chef 79FA-5EVW
Magic Chef 79FA-5EXW
Magic Chef 79FK-5EVW
Magic Chef 79FK-5EXW Walloven - S/c Ele
Magic Chef 79FN-5EVW Walloven - S/c Ele
Magic Chef 79FN-5EXW Walloven - S/c Ele
Whirlpool 7CSE3A1
Whirlpool 7CSE3W1
Whirlpool 7CSE5A2
Whirlpool 7CSE5W2
Whirlpool 7DP840CWDB0
Whirlpool 7DP840CWDB1
Whirlpool 7DP840DWGX0
Whirlpool 7DP840SWKX0 Portable Dishwasher
Whirlpool 7DP840SWKX1 Portable Dishwasher
Whirlpool 7DP840SWSX0 Portable Dishwasher
Whirlpool 7DU1100XTSQ0 Undercounter Dishwasher
Whirlpool 7DU1100XTSS0 Undercounter Dishwasher
Whirlpool 7DU840CWDB0
Whirlpool 7DU840CWDB1
Whirlpool 7DU840DWGX0
Whirlpool 7DU850SWSQ0 Undercounter Dishwasher
Whirlpool 7DU900PCDB0
Whirlpool 7DU900PCDQ0
Whirlpool 7DU900PCDQ1
Whirlpool 7DU900PCDQ2
Whirlpool 7DU910PFGB0
Whirlpool 7DU912PFGQ0
Whirlpool 7DU920PWKB0 Undercounter Dishwasher
Whirlpool 7DU920PWKQ0 Undercounter Dishwasher
Whirlpool 7DU920PWKS0 Undercounter Dishwasher
Whirlpool 7ED0GTQXKQ00
Whirlpool 7ED0GTQXKQ01
Whirlpool 7ED0GTQXKQ02 Refrigerator
Whirlpool 7ED0GTQXMQ00 Refrigerator
Whirlpool 7ED20TKXDN00
Whirlpool 7ED20TKXDN01
Whirlpool 7ED20TKXDN02
Whirlpool 7ED20TQXFW00
Whirlpool 7ED20TQXFW01
Whirlpool 7ED20TQXFW02
Whirlpool 7ED20TQXFW03
Whirlpool 7ED20TQXFW04
Whirlpool 7ED20TQXFW05
Whirlpool 7ED22PQXDN00
Whirlpool 7ED22PQXDN01
Whirlpool 7ED22PQXFN00
Whirlpool 7ED22PQXFN01
Whirlpool 7ED22PQXFW00
Whirlpool 7ED22PQXFW01
Whirlpool 7ED25DQXFW00
Whirlpool 7ED25DQXFW01
Whirlpool 7ED25DQXFW02
Whirlpool 7ED25PQXDW00
Whirlpool 7ED25PQXDW01
Whirlpool 7ED25PQXDW02
Whirlpool 7ED27DQXDN00
Whirlpool 7ED27DQXDN01
Whirlpool 7ED27DQXDN02
Whirlpool 7ED27DQXDW02
Whirlpool 7ED27DQXFN00
Whirlpool 7ED27DQXFN01
Whirlpool 7ED27DQXFN02
Whirlpool 7ED27DQXFW00
Whirlpool 7ED27DQXFW01
  #2 (permalink)
Old 11-25-2009, 05:40 PM
Member
tommyboy84 is on a distinguished road
Default F1 code
F1 - Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced.
This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
  #3 (permalink)
Old 11-30-2009, 09:18 AM
Junior Member
decoratingdames is on a distinguished road
Default
I feel for you but all I can offer is to keep your feet on the ground because you may be in for the run around of your life.
My Kenmore Elite double wall ovens are only 5 years old, cost about 3,000.00 and have not worked since last spring.
The part that I need to repair them costs about $200.00 and is manufactured by GE....unfortunately, they have discontinued the part and cannot offer anything compatible.....and after all of these months of research, I am finding out that this is a typical scenario.
These companies are doing it all the time in an effort to have you simply plunk down another $3 grand, every five years. It is disgraceful! And to make matters worse, Sears actually offered me a 10 PERCENT DISCOUNT ON A NEW SET OF DOUBLE OVENS! How insulting!!
I had been a customer of theirs since 1980...bought every major appliance from them including my last purchase in 2003 totally over $10,000.00
Sears and GE have backed me into a corner with no other recourse then to purchase and finance another set of ovens. I am soooo frustrated and angry and my hope for you is that my experience is one that you won't have to duplicate.
Good Luck......My new ovens will probably be a Miele or what ever manufacturer will offer me a 10yr warranty......as long as it dosen't put a single penny into the wallet belonging to Sears and GE I am in!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Wall oven will not heat/re-heat properly dottavio Oven Repair (including Ranges and Cooktops) 0 01-07-2010 09:47 AM
magic chef oven doesn"t ignite gary robbins Oven Repair (including Ranges and Cooktops) 0 10-29-2009 04:07 PM
Dryer Doesn DALE R Dryer Repair 3 10-26-2009 05:53 PM
Amana Brioler An Self Clean Doesn`s Work blic4444 Oven Repair (including Ranges and Cooktops) 1 06-04-2009 02:05 PM
Washer Doesn`t Allways Spin After Draining TODD H Washer Repair 4 04-20-2009 01:22 PM
