The front left (xlo, 9.1K) burner on my gas range works fine when the unit is cold. After it warms up (either running the burner, or the oven), the burner will not light. There is no smell of gas; the igniters are generating sparks. After the stove cools, the burner works again.
I replaced the (violet) valve and Potentiometer kit (2 pots and simmer control), and I'm still seeing the same failure.
serial #82040094, if that helps...
