Discuss
jenn air stove top burner replacement
 in
You have the burners I need for my jenn air stove top, however I saw on the internet that a
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » jenn air stove top burner replacement
  #1 (permalink)
Old 08-17-2007, 02:56 PM
jfh1@bellsouth.net jfh1@bellsouth.net is offline
Junior Member
jfh1@bellsouth.net is on a distinguished road
Default jenn air stove top burner replacement
Model Number: part ap3970566   Brand: Jenn-Air   Age: More than 10 years
You have the burners I need for my jenn air stove top, however I saw on the internet that a special tool was needed to remove the old ones, it looked like an oversized oil filter wrench, but it said it was no longer available. Can you advise on how to replace the burners, they are the solid metal ones from over 12 years ago.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-17-2007, 09:51 PM
Admin / APP Team Admin / APP Team is offline
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
It shouldn't be a problem. Take a look at the diagram below (I'm not sure what type of a cooktop you have. I did a back search from part number of the element and came up with a model number for a solid element module, as pictured on the diagram below). Remove the screws that surround the module, then carefully remove the top glass, disconnect the wires from each element (note which wire goes where!) and remove the elements using the diagram below.
Jenn-Air had discontinued the entire module assembly for solid type elements, but they do have a glass top module with radiant elements. If you really like the solid elements, then by all means fix the old module. But if it doesn't matter much, radiant elements are much better (in my opinion). They're almost as fast as gas to heat up and pretty fast to cool down, so you'll have much better control. Anyway, if you're interested, check out the radiant module:
- Jenn-Air radiant module black model
- Jenn-Air radiant module white model
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jenn-Air Range, oven not heating Mark Wise Oven Repair (including Ranges and Cooktops) 5 02-09-2008 04:49 PM
Burner won't ignite flaumbetty Oven Repair (including Ranges and Cooktops) 5 01-25-2008 06:39 AM
Jenn-Air Wiring Repair Rescue JenSed Oven Repair (including Ranges and Cooktops) 5 08-21-2007 11:53 AM
Jenn-Air Radiant Range with Convection Oven Dee Oven Repair (including Ranges and Cooktops) 0 07-24-2007 05:11 PM
replace burner solenoid richard Oven Repair (including Ranges and Cooktops) 2 07-21-2007 11:56 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
