| » Whirlpool Double Oven No Display but beeps |
Model Number: GBD307PDB09 Brand: Whirlpool Age: 1 - 5 years
First off thanks to all of you that contribute to this forum, I have used it and saved $100's in the past year or so fixing mutliple appliance problems. I used it to repair my oven last year
(Whirlpool GBD307PDB09) and am now back with a new problem that I don't see any answers to. Last year I had to to replace both the Oven shut down thermal fuse and the Control Panel Thermal Fuse due to the self cleaning problem with this model. NOW, while the oven was not in use the control panel beeped about 5-6 times and the display went blank; pushing buttons results in beeps but no apparant function. Shut down power and power up results in single beep and then 5-6 beeps approximately 1 minute later. So far I have checked and ruled out: Control Panel Thermal fuse Oven shutdown Thermal Fuse Sister Board (ciruit closed) Control power transformer is outputing about 2V too high (is the panel that sensative?) the OHMS are also out of range input is supposed to be between 75-95 and is at 58 output is supposed to be <1 and is 2 I am following the directions from a previous post right now, I have unplugged the control panel power ribbon and powered up will plug it all back in, in a few hours to check, but the beeps have already done their thing. Any suggestions welcomed? Ads By Google Related Models |
I am having the exact same problem. After I start the oven, the display goes blank after a few minutes. Push the buttons and it beeps, but does not do anything else. Wait a half hour or so, and the display is back, and oven works fine. It has now done this twice - yesterday and about two months ago. In between, everything was fine. Any ideas on what the problem is?
fellow posters:
Mine and my neighbor's same Built-In Electric Convection Oven (GBD307PDB7) is doing the same thing and mine is completely dark now. Here's some other suggestions from another site: My Built-In Electric Convection Oven (GBD307PDB7) control panel doesn't work. Won't turn oven on, no lights, but still beeps when you push buttons. It went off last week, then came back on as we pushed some buttons. Now, won't come on. Advice? Submitted: 444 days and 14 hours ago. Category: Appliance Value: $15 Status: CLOSED +Read More Answer im sorry i just saw the model # if your first question. well it sound like the low voltage trans former is bad. GBD307PDB7 CONTROL PANEL Parts Quote:
Hey all, I ended up replacing the entire control panel, found one with a lifetime warranty for the tune of $161+ change. It fixed my problem and has been working fine since Nov. Hope that helps.
| Display Modes | |
| Whirlpool double oven display is blank | jrgaytan | Oven Repair (including Ranges and Cooktops) | 7 | 01-29-2013 06:46 PM |
| whirlpool double oven, only beeps, no display, does not turn on | umairs123 | Oven Repair (including Ranges and Cooktops) | 0 | 02-15-2010 07:17 AM |
| Whirlpool Gold Double Oven Display Out | fireresource | Oven Repair (including Ranges and Cooktops) | 2 | 01-22-2010 01:08 PM |
| Whirlpool Double Builtin Oven LED OUT, TURNS ON FOR ABOUT 10 SECONDS THEN BEEPS | bearingrnwd | Oven Repair (including Ranges and Cooktops) | 0 | 12-20-2009 07:17 PM |
| Whirlpool double oven display is dead | ameierinco | Oven Repair (including Ranges and Cooktops) | 1 | 10-13-2009 08:25 AM |
