Discuss
Jenn-Air Cooktop fan switch removal
 in
I am replacing the fan switch which is held on by two pressed on Pal nuts on two posts under
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Jenn-Air Cooktop fan switch removal
  #1 (permalink)
Old 11-22-2009, 04:24 PM
Junior Member
malcolma is on a distinguished road
Default Jenn-Air Cooktop fan switch removal
Model Number: 2211381   Brand: Jenn-Air   Age: More than 10 years
I am replacing the fan switch which is held on by two pressed on Pal nuts on two posts under the cover panel. Is there a removal tool for these ?.
Ads By Google
Related Models
Jenn-Air 22114 SURFACE UNIT- DDRAFT ELE
Jenn-Air 22115 SURFACE UNIT- DDRAFT ELE
Jenn-Air 22116 SURFACE UNIT- DDRAFT ELE
Roper 2214*0A Ranges, Electric*
Roper 2214*1A Ranges, Electric*
Roper 2214*2A Ranges, Electric*
Roper 2214W0A Ranges, Electric*
Roper 2214W1A Ranges, Electric*
Roper 2214W2A Ranges, Electric*
Amana 2215S ROOM AIR CONDITIONER
Roper 2216*00 Ranges, Electric*
Roper 2216*10 Ranges, Electric*
Roper 2216*20 Ranges, Electric*
Roper 2216W00 Ranges, Electric*
Roper 2216W10 Ranges, Electric*
Roper 2216W20 Ranges, Electric*
Frigidaire 2221 GAS RANGE
Roper 2224*0A Ranges, Electric*
Roper 2224*1A Ranges, Electric*
Roper 2224W0A Ranges, Electric*
Roper 2224W1A Ranges, Electric*
Jenn-Air 22305 SURFACE UNIT- DDRAFT ELE
Frigidaire 2231 GAS RANGE
Roper 2233*0A Ranges, Electric*
Roper 2233*1A Ranges, Electric*
Roper 2233W0A Ranges, Electric*
Roper 2233Z1A Ranges, Electric*
Roper 2234*0A Ranges, Electric*
Roper 2234*1A Ranges, Electric*
Roper 2234*2A Ranges, Electric*
Amana 2234.000 MWAVE - FAMILY SIZE (60 HZ)
Roper 2234W0A Ranges, Electric*
Roper 2234W1A Ranges, Electric*
Roper 2234W2A Ranges, Electric*
Roper 2236*00 Ranges, Electric*
Roper 2236*10 Ranges, Electric*
Roper 2236*20 Ranges, Electric*
Amana 2236.100 COMMERCIAL MICROWAVES
Amana 2236.101 COMMERCIAL MICROWAVES
Roper 2236W00 Ranges, Electric*
Roper 2236W10 Ranges, Electric*
Roper 2236W20 Ranges, Electric*
Amana 2237.A MWAVE - FAMILY SIZE (60 HZ)
Amana 2238.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2238.001 MWAVE - FAMILY SIZE (60 HZ)
General Electric 22388L0 Electric range
General Electric 22388W0 Electric range
Amana 2239.A MWAVE - FAMILY SIZE (60 HZ)
Amana 2240.000 MWAVE - FAMILY SIZE (60 HZ)
Jenn-Air 22401 SURFACE UNIT- DDRAFT ELE
Jenn-Air 22402 SURF CONT PANEL UNIT- DDFT ELE
Jenn-Air 22403 SURF CONT PANEL UNIT- DDFT ELE
Jenn-Air 22404 SURF CONT PANEL UNIT- DDFT ELE
Frigidaire 2241 GAS RANGE
Roper 2244*0A Ranges, Electric*
Roper 2244*1A Ranges, Electric*
Roper 2244*2A Ranges, Electric*
Roper 2244W0A Ranges, Electric*
Roper 2244W1A Ranges, Electric*
Roper 2244W2A Ranges, Electric*
Jenn-Air 2250ENC WALLOVEN- STD ELE
Jenn-Air 2250ENS JENN-AIR COOKING
Amana 2254.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2254.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2254.A MWAVE - FAMILY SIZE (60 HZ)
Jenn-Air 2255 WALLOVEN- STD ELE
Jenn-Air 2255ENC WALLOVEN- STD ELE
Jenn-Air 2255ENS JENN-AIR COOKING
Hoover 2260
Roper 2265*0A Ranges, Electric*
Roper 2265W0A Ranges, Electric*
Hoover 2266
Amana 2274.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2274.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2274.A MWAVE - FAMILY SIZE (60 HZ)
Roper 2275*0A Ranges, Electric*
Roper 2275W0A Ranges, Electric*
Roper 2276*0A Ranges, Electric*
Roper 2276*1A Ranges, Electric*
Amana 2276.A MWAVE - FAMILY SIZE (60 HZ)
Roper 2276W0A Ranges, Electric*
Roper 2276W1A Ranges, Electric*
Jenn-Air 2280EEL WALLOVEN- STD ELE
Frigidaire 2281 GAS RANGE
Jenn-Air 2281EEL WALLOVEN- STD ELE
Magic Chef 22FA-2KLW RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FA-2KW WALLOVEN-STD DBL OVEN GAS
Magic Chef 22FA-6CKLXV8 Range - Cont Clean Mwave Gas
Magic Chef 22FA-6KLX RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FA-6KLX-6F RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FA-6KLXV8 RANGE- CONT CLEAN MWAVE GAS
Magic Chef 22FK-2KLW RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FK-2KW WALLOVEN-STD DBL OVEN GAS
Magic Chef 22FK-6KLX RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FK-6KLX-6F RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FK-6KLXV8 RANGE- CONT CLEAN MWAVE GAS
Magic Chef 22FN-2KLW RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FN-2KW WALLOVEN-STD DBL OVEN GAS
Magic Chef 22FN-6CKLXV8 MAGIC CHEF COOKING
Magic Chef 22FN-6KLX RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FN-6KLX-6F RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FN-6KLXV8 RANGE- CONT CLEAN MWAVE GAS
Magic Chef 22FY-2KLW RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FY-2KW WALLOVEN-STD DBL OVEN GAS
Magic Chef 22FY-6KLX RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FY-6KLX-6F RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FY-6KLXV8 RANGE- CONT CLEAN MWAVE GAS
Magic Chef 22JA-7KLXV8 RANGE- CONT CLEAN MWAVE GAS
Magic Chef 22JK-7KLXV8 RANGE- CONT CLEAN MWAVE GAS
Magic Chef 22JN-7KLXV8 RANGE- CONT CLEAN MWAVE GAS
Magic Chef 22JY-7KLXV8 RANGE- CONT CLEAN MWAVE GAS
Magic Chef 22M-7KLXV8 RANGE- CONT CLEAN MWAVE GAS
Magic Chef 22MA-7KLXV8 RANGE- CONT CLEAN MWAVE GAS
Magic Chef 22MN-7KLXV8 RANGE- CONT CLEAN MWAVE GAS
Magic Chef 22MW-7KLXV8 RANGE- CONT CLEAN MWAVE GAS
Magic Chef 22RA-3B-49 RV RANGE- GAS
Magic Chef 22RA-3BKZ RV RANGE- GAS
Magic Chef 22RA-3BTZ RV RANGE- GAS
Magic Chef 22RA-3BZ RV RANGE- GAS
Magic Chef 22RA-4 RV RANGE- GAS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jenn Aire Oven Door Removal JimmyW Oven Repair (including Ranges and Cooktops) 2 02-04-2010 03:56 PM
switch tudp411 for Jenn Air cooktop tomjust Oven Repair (including Ranges and Cooktops) 1 12-06-2009 07:17 PM
GE Cooktop - Heat Switch + Select Switch dtshenoy Oven Repair (including Ranges and Cooktops) 3 06-06-2009 03:14 PM
Jenn Aire Compactor Removal bheffer Trash Compactor Repair 0 02-12-2009 01:08 PM
maytag switch removal jerman Washer Repair 1 10-13-2007 08:11 PM
