Discuss
Jenn Air F5 error code - "Clock" or Power relay board?
 in
Hi, I have a ~7-9 yr old Jenn Air dual fuel downdraft slide in range. SVD 48600B. About a week
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Jenn Air F5 error code - "Clock" or Power relay board?
  #1 (permalink)
Old 11-22-2009, 02:13 PM
Junior Member
chanpaul is on a distinguished road
Default Jenn Air F5 error code - "Clock" or Power relay board?
Model Number: SVD48600B   Brand: Jenn-Air   Age: 5 - 10 years
About a week ago while baking, the F5 error code came on. Now, whenever I try to do anything with the oven (bake/broil/conv), the F5 code will show and the oven inoperable. There are no other issues with the range. The clock display is as normal, no dimming, timers work, fan switch working.
Searching on the forums, it appears that I need a Power Relay Board AP4008573. However, when I called into the 1-877 number to order it, I was told I may instead need a "clock" module AP4088560.
Could someone please point me in the right direction please?
Thanks in advance.
Ads By Google
Related Models
Jenn-Air SVD48600B Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600BC Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600P Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600PC Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600PF Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600PG Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600PK Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600PR Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600PT Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600PU Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600W Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600WC Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310S Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310S-C Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SD Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SF Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SG Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SK Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SR Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SU Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVE47100B Range - S/c S/i Ddraft Ele
Jenn-Air SVE47100BC Range - S/c S/i Ddraft Ele
Jenn-Air SVE47100W Range - S/c S/i Ddraft Ele
Jenn-Air SVE47100WC Range - S/c S/i Ddraft Ele
Jenn-Air SVE47500B Range - S/c S/i Ddraft Ele
Jenn-Air SVE47500W Range - S/c S/i Ddraft Ele
Jenn-Air SVE47600B Range - S/c S/i Ddraft Ele
Jenn-Air SVE47600BC Range - S/c S/i Ddraft Ele
Jenn-Air SVE47600W Range - S/c S/i Ddraft Ele
Jenn-Air SVE47600WC Range - S/c S/i Ddraft Ele
Jenn-Air SVE87600B Range - S/c S/i Ddraft Ele
Jenn-Air SVE87600W Range - S/c S/i Ddraft Ele
Whirlpool SVF100W0
Whirlpool SVF100W1
Whirlpool SVF12FRHW00
Whirlpool SVF15NRHW00
Whirlpool SVF15NRHW01
Whirlpool SVF15NRHW02
Whirlpool SVF15NRJW00
Whirlpool SVF20NRKQ00
Whirlpool SVF60W0
Whirlpool SVF60W1
Whirlpool SVF70W0
Whirlpool SVF70W1
Whirlpool SVF75W0
Whirlpool SVF75W1
Whirlpool SVF75W2
Whirlpool SVF80W0
Whirlpool SVF80W1
Whirlpool SVF90W0
Whirlpool SVF90W1
Whirlpool SVP100W0
Whirlpool SVP50W0
Whirlpool SVP60W0
Whirlpool SVP60W1
Whirlpool SVP70W0
Whirlpool SVP75W0
Whirlpool SVP80W0
Whirlpool SVP90W0
Whirlpool SVU100W0
Whirlpool SVU100W1
Whirlpool SVU100W2
Whirlpool SVU60W0
Whirlpool SVU60W1
Whirlpool SVU60W2
Whirlpool SVU70W0
Whirlpool SVU70W1
Whirlpool SVU70W2
Whirlpool SVU80W0
Whirlpool SVU80W1
Whirlpool SVU80W2
Whirlpool SVU90W0
Whirlpool SVU90W1
Whirlpool SVU90W2
Amana SW22H Ref - SXS/I&W
Amana SW22MBG Ref - SXS/I&W
Amana SW22MBL Ref - SXS/I&W
Amana SW22MBW Ref - SXS/I&W
Amana SW25H Ref - SXS/I&W
Amana SWDT22H Ref - SXS/I&W
Amana SWDT25H Ref - SXS/I&W
Whirlpool SWF100W0
Whirlpool SWF100W2
Whirlpool SWF60W0
Whirlpool SWF60W2
Whirlpool SWF70W0
Whirlpool SWF70W2
Whirlpool SWF80W0
Whirlpool SWF80W2
Whirlpool SWF80W8
Whirlpool SWF80W9
Whirlpool SWF90W0
Whirlpool SWF90W1
Whirlpool SWF90W2
Amana SWP25H Ref - SXS/I&W
Whirlpool SWP70W0
Whirlpool SWP80W0
Whirlpool SWP90W0
Amana SWPD25H Ref - SXS/I&W
White Westinghouse SWS1233CQ0 White Westinghouse/washer
White Westinghouse SWS1233CQ1 White Westinghouse/washer
White Westinghouse SWS1233CS0 White Westinghouse/washer
White Westinghouse SWS1233CS1 White Westinghouse/washer
White Westinghouse SWS1339CC1 White Westinghouse/washer
White Westinghouse SWS1339CC2 White Westinghouse/washer
White Westinghouse SWS1549AQ0 Washer - W.westinghouse
White Westinghouse SWS1549AQ1 Washer - West/grupo Famsa
White Westinghouse SWS1549AQ2 White Westinghouse/washer
White Westinghouse SWS1549AS0 Washer - W.westinghouse
White Westinghouse SWS1549AS1 Washer - West/grupo Famsa
White Westinghouse SWS1549AS2 White Westinghouse/washer
White Westinghouse SWS1649CQ0 White Westinghouse/washer
White Westinghouse SWS1649CQ1 White Westinghouse/washer
White Westinghouse SWS1649CS0 White Westinghouse/washer
White Westinghouse SWS1649CS1 White Westinghouse/washer
  #2 (permalink)
Old 12-01-2009, 09:58 PM
Junior Member
Default
Hope everyone had a good thanksgiving.
Any chance a tech has an opportunity to see this and offer a comment or how to determine which part I actually need?
Thanks!
  #3 (permalink)
Old 12-08-2009, 12:22 PM
Junior Member
Default
2nd appeal for help. Please, can someone chime in on which part I should get?
I have already downloaded the repair manual but want to be sure before I take things apart and test them.
Much appreciated. Thanks.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Samsung Washer "OE" error code rfgriffin Washer Repair 4 09-20-2011 08:12 PM
Dacor EORS130 error code "CO1" displayed sjoyce15 Oven Repair (including Ranges and Cooktops) 0 01-05-2010 09:32 AM
"F" error code and water in base surp Dishwasher Repair 0 05-02-2009 09:45 AM
Error code "F6" Benjaminv Microwave Repair 1 04-20-2009 05:19 PM
Error Code"eeeeee" On Pad BIGLOU Oven Repair (including Ranges and Cooktops) 9 03-01-2008 04:51 PM
