| » Bake mode does not maintain set temperature |
Model Number: w131w Brand: Jenn-Air Age: More than 10 years
The heating element comes on and goes to set temperature at which time the element shuts off. The element will not activate to maintain the set temperature. Even with the door open, the element does not respond. If the temperature is increased after the initial set temperature is reached (and the element shuts off), the element activates and raises the temperature to the new set point. Could this be a reley? Suggestions?
Thanks good28 |
Gene;
Thanks for the response. The Jenn Air Model W131W serial number is: 11234176HO ( the o may be D). Is the clock (ERC?) a part of the "control panel" and attached with screws? I look forward to your help. Thanks, Larry |
good28,
The correct clock for your oven is this one. See control panel diagram below. This is a pretty simple changeout. Make sure the power to the range is turned off. Looking at the below diagram... #2's hold #5 in place, remove. Then carefully remove #6 touch pad. You can then change the clock. Assemble everything in reverse. That's about it. Keep us posted. - Breakdown diagram of the control panel area |
I opened the diagram ready to proceed; however, I did not find a part number for the clock. I have seen at least two(2) clocks listed. How do I order the correct unit? I am probably missing/overlooking something simple, but please help me.
Thanks. Larry |
Not a problem. The diagram link is for you to see how everything is put together. Here is a direct link to the clock itself - Part Details - MAYTAG Timer, part number: AP382957 - it's currently in stock and as of today runs for $218.09 (other places sell it for about $225-$235).
Dear Team;
I ordered the referenced part, received it within three(3) days and proceeded with the installation per the instructions. I did make a sketch of the board connections- ~ 10 clip-ons that were color coded. The four(4) screws holding the board in place were convenient, the connections were doable and the installation took less than 30 minutes including taking extra precautions. The oven operated on activation and continues to perform well. An expensive part but justifiable with no labor costs. Thanks for the help. Not only did this save significant money for my daughter, but it provides a "good feeling" to me for accomplishing the task. I will address the next problem with a little more confidence. Please keep up the good work. Best regards, Good28 |
That's excellent!
Quote:
You know where to find us, should you need more help in the future. I also want to thank you for supporting this forum and ordering the part from us. |
| Display Modes | |
| Maytag - Dryer not heating timer mode | freebird | Dryer Repair | 0 | 08-16-2007 12:06 PM |
| Bake Element and BAKE cycle not working | jeffman | Oven Repair (including Ranges and Cooktops) | 1 | 08-04-2007 11:18 PM |
| Oven Will Not Bake | tony | Oven Repair (including Ranges and Cooktops) | 6 | 08-01-2007 06:21 PM |
| Frig Temperature control problem | vrocrider | Refrigerator & Freezer Repair | 2 | 07-29-2007 11:02 AM |
| Oven doesnt bake | ChrisF | Oven Repair (including Ranges and Cooktops) | 0 | 07-26-2007 06:25 PM |
