Discuss
Hotpoint Oven thermostat replacement
 in
Need to replace Thermostat but can't get the capillary tube out of the oven. Plate that holds the burners
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Hotpoint Oven thermostat replacement
  #1 (permalink)
Old 11-20-2009, 10:28 AM
mcqueary mcqueary is offline
Junior Member
mcqueary is on a distinguished road
Default Hotpoint Oven thermostat replacement
Model Number: RGB744GEV2WH   Brand: Hotpoint   Age: 5 - 10 years
Need to replace Thermostat but can't get the capillary tube out of the oven. Plate that holds the burners blocks removal of tube because of length of tube.
Related Models
General Electric RGB744GEV2WH Gas range
General Electric RGB744WEA1WW Gas range
General Electric RGB744WEA2WW Gas range
General Electric RGB744WEA3WW Gas range
General Electric RGB744WET1WW Gas range
General Electric RGB744WET2WW Gas range
General Electric RGB744WEV1WW Gas range
General Electric RGB744WEV2WW Gas range
General Electric RGB745BEA1AD Gas range
General Electric RGB745BEA1CT Gas range
General Electric RGB745BEA1WH Gas range
General Electric RGB745BEA2AD Gas range
General Electric RGB745BEA2CT Gas range
General Electric RGB745BEA2WH Gas range
General Electric RGB745BEA3AD Gas range
General Electric RGB745BEA3CT Gas range
General Electric RGB745BEA3WH Gas range
General Electric RGB745BEA4AD Gas range
General Electric RGB745BEA4WH Gas range
General Electric RGB745BEA5AD Gas range
General Electric RGB745BEA5WH Gas range
General Electric RGB745BEA6AD Gas range
General Electric RGB745BEA6WH Gas range
General Electric RGB745BEA7WH Gas range
General Electric RGB745BEA8WH Gas range
General Electric RGB745BEH1CT Gas range
General Electric RGB745BEH1WH Gas range
General Electric RGB745BEH2CT Gas range
General Electric RGB745BEH2WH Gas range
General Electric RGB745BEH3CT Gas range
General Electric RGB745BEH3WH Gas range
General Electric RGB745BEH4CT Gas range
General Electric RGB745BEH4WH Gas range
General Electric RGB745BEH5CT Gas range
General Electric RGB745BEH5WH Gas range
General Electric RGB745BEH6CT Gas range
General Electric RGB745BEH6WH Gas range
General Electric RGB745BEH7CT Gas range
General Electric RGB745BEH7WH Gas range
General Electric RGB745EEH1BB Gas range
General Electric RGB745EEH2BB Gas range
General Electric RGB745EEH3BB Gas range
General Electric RGB745EEH4BB Gas range
General Electric RGB745EEH5BB Gas range
General Electric RGB745GEH1 Gas range
General Electric RGB745GEN1 Gas range
General Electric RGB745GER1 Gas range
General Electric RGB745GER2 Gas range
General Electric RGB745GER3 Gas range
General Electric RGB745GES1 Gas range
General Electric RGB745GET1AD Gas range
General Electric RGB745GET1WH Gas range
General Electric RGB745GET2AD Gas range
General Electric RGB745GET2WH Gas range
General Electric RGB745GEV1AD Gas range
General Electric RGB745GEV1WH Gas range
General Electric RGB745GEV2AD Gas range
General Electric RGB745GEV2WH Gas range
General Electric RGB745GEV3AD Gas range
General Electric RGB745GEV3WH Gas range
General Electric RGB745SEV1AD Gas range
General Electric RGB745SEV1WH Gas range
General Electric RGB745SEV2AD Gas range
General Electric RGB745SEV2WH Gas range
General Electric RGB745WEA1WW Gas range
General Electric RGB745WEA2WW Gas range
General Electric RGB745WEA3WW Gas range
General Electric RGB745WEA4WW Gas range
General Electric RGB745WEA5WW Gas range
General Electric RGB745WEA6WW Gas range
General Electric RGB745WEA7WW Gas range
General Electric RGB745WEA8WW Gas range
General Electric RGB745WEH1WW Gas range
General Electric RGB745WEH2WW Gas range
General Electric RGB745WEH3WW Gas range
General Electric RGB745WEH4WW Gas range
General Electric RGB745WEH5WW Gas range
General Electric RGB745WEH6WW Gas range
General Electric RGB745WEH7WW Gas range
General Electric RGB745WET1WW Gas range
General Electric RGB745WET2WW Gas range
General Electric RGB745WEV1WW Gas range
General Electric RGB745WEV2WW Gas range
General Electric RGB745WEV3WW Gas range
General Electric RGB746GEJ1 Gas range
General Electric RGB746GEJ2 Gas range
General Electric RGB746GEJ3 Gas range
General Electric RGB746GEJ4 Gas range
General Electric RGB746GEJ5 Gas range
General Electric RGB746GEJ6 Gas range
General Electric RGB746GEJ7 Gas range
General Electric RGB746GEJ8 Gas range
General Electric RGB746GEJ9 Gas range
General Electric RGB746GEJA Gas range
General Electric RGB746GEN1 Gas range
General Electric RGB746GES1 Gas range
General Electric RGB746HED1CT Gas range
General Electric RGB746HED1WH Gas range
General Electric RGB746HED2CT Gas range
General Electric RGB746HED2WH Gas range
General Electric RGB746HED3CT Gas range
General Electric RGB746HED3WH Gas range
General Electric RGB746HEH1CT Gas range
General Electric RGB746HEH1WH Gas range
General Electric RGB746WEH1WW Gas range
General Electric RGB746WEH2WW Gas range
General Electric RGB746WEH3WW Gas range
General Electric RGB746WEH4WW Gas range
General Electric RGB746WEH5WW Gas range
General Electric RGB746WEH6WW Gas range
General Electric RGB747GEP1 Gas range
General Electric RGB747GER1 Gas range
General Electric RGB747GER2 Gas range
General Electric RGB747GER3 Gas range
General Electric RGB750SEY1WW Gas range
General Electric RGB751GEL1 Electric range
General Electric RGB790BEK1BB Gas range
General Electric RGB790CEK1CC Gas range
General Electric RGB790SEH1SA Gas range
General Electric RGB790SEH2SA Gas range
  #2 (permalink)
Old 11-20-2009, 01:31 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
You have to remove the top panel, the burners, the orifice spuds and the burner box which is secured with a few screws around.
Here are the breakdown diagrams and Replacement parts for GE RGB744GEV2WH | AppliancePartsPros.com
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Looking for a replacement oven thermostat ronrico Oven Repair (including Ranges and Cooktops) 0 11-18-2009 03:47 PM
Oven Thermostat Knob Replacement christinee Oven Repair (including Ranges and Cooktops) 0 12-15-2008 10:57 AM
Hotpoint oven baking element replacement cameron Oven Repair (including Ranges and Cooktops) 1 09-28-2008 07:03 PM
oven thermostat replacement button579 Oven Repair (including Ranges and Cooktops) 4 09-24-2008 05:23 PM
Oven thermostat replacement danreiss Oven Repair (including Ranges and Cooktops) 0 03-24-2008 02:44 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
