| » Magic Chef oven -burner doesn't light |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Burner didn't light; purchased igniter kit (MAC 1240035) and Valve.Safety (24" LP) (MAC 12002128). Burner still won't light. What's my next step? Salesman at AppliancePartsPro.com advised me to contact you. Thanks, AV Berviller
if you are not getting power to those, which it sounds like you aren't, it could be your control/thermostat??? i don't know which one you have... but that's probably your problem...could be a fuse though... need model...
__________________
roy the appliance whisperer |
Open the control panel, remove wires from the oven thermostat and check for continuity across the thermostat terminals while the thermostat is "on".
Replace the oven thermostat if it's open. - The part number for the oven thermostat is AP379270 Here are the break down diagrams for the Magic Chef oven Model 9122VUV Gene.
__________________
Professional appliance repair services in Orange County, California. |
Hi Art,
If the new igniter glows but gas does not come out - check the gas shut off valve next to the gas safety valve. It could be closed since you replaced the safety valve. If the igniter does not glow - check for 120V coming to the igniter while the thermostat calls for heat. Post your findings, please. Gene.
__________________
rene,
Most likely the problem is a bad igniter even if it does glow. You can learn how oven igniter works from one of our previous posts: Oven won't lite? - The part number for the oven igniter is AP205873 Here are the break down diagrams for the Magic Chef range Model 9122VUV Gene.
__________________
| Display Modes | |
| Oven Thermostat Help Magic Chef | tg022474@aol.com | Oven Repair (including Ranges and Cooktops) | 1 | 02-21-2008 06:01 PM |
| Temperamental MAgic Chef Oven | sweetp43 | Oven Repair (including Ranges and Cooktops) | 2 | 01-24-2008 04:44 PM |
| Magic chef oven 6498vrv | michaelman31 | Oven Repair (including Ranges and Cooktops) | 5 | 12-04-2007 07:03 PM |
| Magic Chef Oven Not Turning On | COLORICAN | Oven Repair (including Ranges and Cooktops) | 2 | 11-26-2007 07:40 AM |
| Magic Chef gas oven won't light | koohgar | Oven Repair (including Ranges and Cooktops) | 10 | 10-17-2007 02:00 PM |
