Jenn-Air JED8345 Downdraft - Burners Out
Model Number: JED8345ADB Brand: Jenn-Air Age: 1 - 5 years
Our Jenn-Air JED8345ADB Downdraft Cooktop w/ 3 Burner Bays outfitted with 2 radiant glass smooth units having 2 burners each, and 1 grill metal element unit, suddenly and without warning of any kind, simply stopped working. None of the burners light-up nor does the heating element for the grill; however, the indicators all turn on when the switches are turned on; also, the fan blower works as it should.
Power meter shows 178 +/- 5 volts at the ceramic connectors for the heating element units.
I've checked the circuitry schematic diagram provided with the unit and have also opened the unit up, removing the top and the electrical box front, thereby exposing the bays and electrical wiring. There is no evidence of burned wiring, nor of any of the switches looking like they've shorted out or anything like that. The circuit diagram shows that the unit consists of wiring, the six switches, three indicator lamps, the 3 burner bay electric pods, the relay for the fan blower, and the fan blower motor. There is no control module nor any other type of relay or device that controls the burner bays other than the six switches. It simply does not seem possible that all six switches would burn out at exactly the same time. Is there something that I'm missing, some central control or relay where the power must go through before it goes to the burners? The fan relay appears to be non-essential for the burners themselves; moreover, when you turn on the switch for the grill, the fan blower turns on like it should. Thus, the relay is working properly and is getting juice when the switch is turned on, trigging the relay to turn the fan on. Also, there's power for the fan, since the fan works properly, both speeds.
Could all three heating units have gone bad simultaneously? Two ceramic, radiant heat glass tops and one grill heating element?
Can you tell me what's wrong with this unit?
Thanks.
P.S.: Your immediate reply would be appreciated. I ordered a service manual and an assortment of parts today from your company. Order #908804. I MUST get this unit working by next Wednesday for the Thanksgiving Holiday, else, my wife's holiday plans will be ruined.
Ads By Google
Related ModelsJenn-Air JED8345ADB Surface Unit - Ddraft Ele Jenn-Air JED8345ADW Surface Unit - Ddraft Ele Jenn-Air JED8430ADB Surface Unit - Ddraft Ele Jenn-Air JED8430ADQ Surface Unit - Ddraft Ele Jenn-Air JED8430ADW Surface Unit - Ddraft Ele Jenn-Air JED8430BDB Surface Unit - Ddraft Ele Jenn-Air JED8430BDF Surface Unit - Ddraft Ele Jenn-Air JED8430BDN Surface Unit - Ddraft Ele Jenn-Air JED8430BDS Surface Unit - Ddraft Ele Maytag JEI0430ADS0 30" Inducton Cooktop Maytag JEI0536ADS0 36" Induction Cooktop General Electric JEI83101 Counter top microwave General Electric JEI832WN01 Counter top microwave General Electric JEM10001 Counter top microwave General Electric JEM10E01 Counter top microwave General Electric JEM10F01 Counter top microwave General Electric JEM10G01 Counter top microwave General Electric JEM18F01 Counter top microwave General Electric JEM2-001 General Electric JEM20001 Counter top microwave General Electric JEM20E01 Counter top microwave General Electric JEM20F01 Counter top microwave General Electric JEM20G01 Counter top microwave General Electric JEM20H01 Counter top microwave General Electric JEM20H02 Counter top microwave General Electric JEM21001 Counter top microwave General Electric JEM21E01 Counter top microwave General Electric JEM21K01 Counter top microwave General Electric JEM21K02 Counter top microwave General Electric JEM21K03 Counter top microwave General Electric JEM21K04 Counter top microwave General Electric JEM21L01 Counter top microwave General Electric JEM21L02 Counter top microwave General Electric JEM22E01 Counter top microwave General Electric JEM22H01 Counter top microwave General Electric JEM23E01 Counter top microwave General Electric JEM23F01 Counter top microwave General Electric JEM23G01 Counter top microwave General Electric JEM23K01 Counter top microwave General Electric JEM23K02 Counter top microwave General Electric JEM23K03 Counter top microwave General Electric JEM23K04 Counter top microwave General Electric JEM23L01 Counter top microwave General Electric JEM23L02 Counter top microwave General Electric JEM25BF001 Counter top microwave General Electric JEM25BF01 Counter top microwave General Electric JEM25BF02 Counter top microwave General Electric JEM25GV01 Counter top microwave General Electric JEM25GV02 Counter top microwave General Electric JEM25GV03 Counter top microwave General Electric JEM25GY01 Counter top microwave General Electric JEM25J01 Counter top microwave General Electric JEM25L01 Counter top microwave General Electric JEM25WF001 Counter top microwave General Electric JEM25WF01 Counter top microwave General Electric JEM25WF02 Counter top microwave General Electric JEM25WV01 Counter top microwave General Electric JEM25WV02 Counter top microwave General Electric JEM25WV03 Counter top microwave General Electric JEM25WY01 Counter top microwave General Electric JEM26WH01 Counter top microwave General Electric JEM27KWH01 Counter top microwave General Electric JEM27KWH02 Counter top microwave General Electric JEM27KWH03 Counter top microwave General Electric JEM27KWH04 Counter top microwave General Electric JEM27LWH01 Counter top microwave General Electric JEM27LWH02 Counter top microwave General Electric JEM2F01 Counter top microwave General Electric JEM2G01 Counter top microwave General Electric JEM2H01 Counter top microwave General Electric JEM3-001 General Electric JEM30WH01 Counter top microwave General Electric JEM31BF001 Counter top microwave General Electric JEM31BF01 Counter top microwave General Electric JEM31BF02 Counter top microwave General Electric JEM31CA001 Counter top microwave General Electric JEM31CF001 Counter top microwave General Electric JEM31CF01 Counter top microwave General Electric JEM31CF02 Counter top microwave General Electric JEM31E01 Counter top microwave General Electric JEM31F01 Counter top microwave General Electric JEM31G01 Counter top microwave General Electric JEM31GA01 Counter top microwave General Electric JEM31GA02 Counter top microwave General Electric JEM31GV01 Counter top microwave General Electric JEM31GV02 Counter top microwave General Electric JEM31GY01 Counter top microwave General Electric JEM31H01 Counter top microwave General Electric JEM31H02 Counter top microwave General Electric JEM31J01 Counter top microwave General Electric JEM31K01 Counter top microwave General Electric JEM31L01 Counter top microwave General Electric JEM31L02 Counter top microwave General Electric JEM31L03 Counter top microwave General Electric JEM31L04 Counter top microwave General Electric JEM31M01 Counter top microwave General Electric JEM31M02 Counter top microwave General Electric JEM31M03 Counter top microwave General Electric JEM31SA01 Counter top microwave General Electric JEM31SF001 Counter top microwave General Electric JEM31SF01 Counter top microwave General Electric JEM31SF02 Counter top microwave General Electric JEM31WA01 Counter top microwave General Electric JEM31WF001 Counter top microwave General Electric JEM31WF01 Counter top microwave General Electric JEM31WF02 Counter top microwave General Electric JEM31WV01 Counter top microwave General Electric JEM31WV02 Counter top microwave General Electric JEM31WY01 Counter top microwave General Electric JEM32F01 Counter top microwave General Electric JEM32G01 Counter top microwave General Electric JEM32G02 Counter top microwave General Electric JEM32H01 Counter top microwave General Electric JEM32H02 Counter top microwave General Electric JEM32H03 Counter top microwave General Electric JEM33L002 Counter top microwave General Electric JEM33LLWH01 Counter top microwave General Electric JEM33M01 Counter top microwave General Electric JEM33M02 Counter top microwave General Electric JEM33M03 Counter top microwave
