Discuss
bake element doesnt heat
 in
we have a used cermic glass top range the top heat element broiler works the bottom bake element does not
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » bake element doesnt heat
  #1 (permalink)
Old 11-19-2009, 04:18 PM
Junior Member
dcihon is on a distinguished road
Default bake element doesnt heat
Model Number: ART6110W   Brand: Amana   Age: 5 - 10 years
we have a used cermic glass top range the top heat element broiler works the bottom bake element does not heat so we orderd a new one from your company and that one doesnt heat .... any suggestiond
Ads By Google
Related Models
Amana ART6110W Range - S/c S/i Ddraft Ele
Amana ART6110WW Range - S/c S/i Ddraft Ele
Amana ART6112LL Range - S/c S/i Ddraft Ele
Amana ART6112WW Range - S/c S/i Ddraft Ele
Amana ART6113E Range - S/c S/i Ddraft Gas
Amana ART6113LL Range - S/c S/i Ddraft Gas
Amana ART6113WW Range - S/c S/i Ddraft Gas
Amana ART6114 E Range - S/c S/i Ddraft Gas
Amana ART6114E Range - S/c S/i Ddraft Gas
Amana ART6114LL Range - S/c S/i Ddraft Gas
Amana ART6114WW Range - S/c S/i Ddraft Gas
Amana ART6121CC Range - S/c S/i Ddraft Gas
Amana ART6121E Range - S/c S/i Ddraft Gas
Amana ART6121WW Range - S/c S/i Ddraft Gas
Amana ART612ECC Range - S/c S/i Ddraft Gas
Amana ART612EE Range - S/c S/i Ddraft Gas
Amana ART612EWW Range - S/c S/i Ddraft Gas
Amana ART6510LL Range - S/c S/i Ddraft Ele
Amana ART6510WW Range - S/c S/i Ddraft Ele
Amana ART6511 E Range - S/c S/i Ddraft Gas
Amana ART6511E Range - S/c S/i Ddraft Gas
Amana ART6511LL Range - S/c S/i Ddraft Gas
Amana ART6511WW Range - S/c S/i Ddraft Gas
Amana ART6522CC Range - S/c S/i Ddraft Gas
Amana ART6522E Range - S/c S/i Ddraft Gas
Amana ART6522LL Range - S/c S/i Ddraft Gas
Amana ART6522WW Range - S/c S/i Ddraft Gas
Amana ART6600E Range - S/c S/i Ddraft Ele
Amana ART6600LL Range - S/c S/i Ddraft Ele
Amana ART6600WW Range - S/c S/i Ddraft Ele
Amana ART660E Range - S/c S/i Ddraft Ele
Amana ART660L Range - S/c S/i Ddraft Ele
Amana ART660W Range - S/c S/i Ddraft Ele
Amana ART6610E Range - S/c S/i Ddraft Ele
Amana ART6610LL Range - S/c S/i Ddraft Ele
Amana ART6610WW Range - S/c S/i Ddraft Ele
Amana ART661E Range - S/c S/i Ddraft Ele
Amana ART663E Range - S/c S/i Ddraft Ele
Amana ART663LG Range - S/c S/i Ddraft Ele
Amana ART663WW Range - S/c F/s Ele
Amana ARTC7003L Range - S/c S/i Ddraft Gas
  #2 (permalink)
Old 11-19-2009, 09:25 PM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for ART6110W models | AppliancePartsPros.com
Here is some wiring info
http://www.servicematters.com/maytag...s/T232_2R3.pdf
Could be a number of things.
A wire has burned off somwhere
The thermostat
The selector switch
Also I would check the element with a meter just to be sure it is OK.
It is rare but sometimes thay are bad out of the box.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bake element does not heat jfm1234 Oven Repair (including Ranges and Cooktops) 0 12-09-2009 08:02 AM
bake element no heat rolf Oven Repair (including Ranges and Cooktops) 3 06-25-2009 09:59 PM
bake element will not heat pdqhale Oven Repair (including Ranges and Cooktops) 4 06-23-2009 05:26 PM
Bake element will not heat djmikey9 Oven Repair (including Ranges and Cooktops) 2 05-07-2009 11:51 AM
Oven Bake Element will not heat up wcwilson1 Oven Repair (including Ranges and Cooktops) 1 04-16-2009 08:56 AM
