| » kitchenaid oven wiring problem |
Model Number: KGBZ276XBL0 Brand: Kitchen Aid Age: More than 10 years
I was changing the igniter and shorted the feed wires. Now, instead of 120 volts, there is only about 50v - not enough to heat the igniter. I don't have a wiring diagram. It doubt it is a fuse since I still have voltage, albeit insufficient. Might there be some sort of in-line fuseable link or relay that may have PARTIALLY burned? Can I get a wiring diagram for free online? I swapped out the thermostats and both work. If I don't get this fixed ASAP my girlfriend is going to kill me. Plus, T-day is fast approaching. HEEEELLP
Related Models Last edited by kfhaggerty : 11-18-2009 at 09:25 AM. |
In order to provide most accurate advice we need the complete and correct model number. The model number you posted does not come up. Verify and repost it.
__________________
Order Appliance Parts - AppliancePartsPros.com Professional appliance repair in Orange County, California. |
I systematically found that I burned out the dual gas valve heater switch when I shorted the wires feeding the igniter. This cooked the low voltage switch with 120v. Now I have to change the whole valve as is is not a serviceable part. Thanks for your time.
I systematically found that I burned out the dual gas valve heater switch when I shorted the wires feeding the igniter. This cooked the low voltage switch with 120v. Now I have to change the whole valve as is is not a serviceable part. Thanks for your time. Ken.
Which part did you call "heater switch"? The dual gas valve does not have such part.
There are three parts in the Bake heating circuit besides the igniter: the oven thermostat, the selector switch and the dual gas valve. Here is the Tech sheet. Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KGBS276XBL0 | AppliancePartsPros.com Gene.
__________________
I found a tech sheet in the oven shell. KitchenAid calls the part a "gas valve heater coil". There are two valves, one with two coils and gas tubes for baking and the other with two for broil curcuits. A continuity test proved that the one for bottom oven baking is open, whereas the other three are not. The book says the valve has to be replaced. It is printed right on it that it is not a serviceable part, and it looks like the wire connectors are molded into the case. I have the document you referred to as well. By the way; the igniters are new and the second test I performed proved both thermostats are fine. Thanks again. K.
Quote:
Quote:
- The dual gas safety valve Part number: AP2968506 Gene.
__________________
| Display Modes | |
| To Gene: RE oven wiring problem | kfhaggerty | Oven Repair (including Ranges and Cooktops) | 0 | 11-19-2009 07:23 AM |
| Kitchenaid Oven Problem | Kitchenaid breakdown | Oven Repair (including Ranges and Cooktops) | 0 | 11-09-2009 04:18 PM |
| Kitchenaid Combo Wall Oven Problem | rob_s | Oven Repair (including Ranges and Cooktops) | 6 | 10-30-2009 10:51 AM |
| kitchenaid dual burner sw wiring | memine | Oven Repair (including Ranges and Cooktops) | 1 | 06-20-2009 04:58 PM |
| Kitchenaid Wiring Diagram | leinerd | Dishwasher Repair | 1 | 07-09-2008 11:53 AM |
