Discuss
Oven light stays on constantly
 in
All of the sudden the interior oven light won't shut off, even with the door closed or by pressing the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven light stays on constantly
  #1 (permalink)
Old 11-15-2009, 01:11 PM
Junior Member
caballin39 is on a distinguished road
Default Oven light stays on constantly
Model Number: RBD306PD   Brand: Whirlpool   Age: 5 - 10 years
All of the sudden the interior oven light won't shut off, even with the door closed or by pressing the light switch. The oven works great otherwise. Any help appreciated.
Ads By Google
Related Models
Whirlpool RBD306PDB1
Whirlpool RBD306PDB10
Whirlpool RBD306PDB11
Whirlpool RBD306PDB12
Whirlpool RBD306PDB13
Whirlpool RBD306PDB14 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDB15 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDB2
Whirlpool RBD306PDB4
Whirlpool RBD306PDB6
Whirlpool RBD306PDB7
Whirlpool RBD306PDB8
Whirlpool RBD306PDB9
Whirlpool RBD306PDQ1
Whirlpool RBD306PDQ10
Whirlpool RBD306PDQ11
Whirlpool RBD306PDQ12
Whirlpool RBD306PDQ13
Whirlpool RBD306PDQ14 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDQ15 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDQ2
Whirlpool RBD306PDQ4
Whirlpool RBD306PDQ6
Whirlpool RBD306PDQ7
Whirlpool RBD306PDQ8
Whirlpool RBD306PDQ9
Whirlpool RBD306PDT11
Whirlpool RBD306PDT12
Whirlpool RBD306PDT13
Whirlpool RBD306PDT14 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDT15 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDZ1
Whirlpool RBD306PDZ10
Whirlpool RBD306PDZ2
Whirlpool RBD306PDZ4
Whirlpool RBD306PDZ6
Whirlpool RBD306PDZ7
Whirlpool RBD306PDZ8
Whirlpool RBD306PDZ9
Whirlpool RBD307PDB1
Whirlpool RBD307PDB2
Whirlpool RBD307PDQ1
Whirlpool RBD307PDQ2
Whirlpool RBD307PDQ4
Maytag RBE170PA  Ref - Top Mount
Maytag RBE170PW  Ref - Top Mount
Maytag RBE170TA Ref - Top Mount
Maytag RBE170TM Ref - Top Mount
Maytag RBE170TV Ref - Top Mount
Maytag RBE170TW Ref - Top Mount
Maytag RBE17KA-0A  Ref - Top Mount
Maytag RBE17KN-0A  Ref - Top Mount
Maytag RBE193PA  Ref - Top Mount
Maytag RBE193PW  Ref - Top Mount
Maytag RBE193TA Ref - Top Mount
Maytag RBE193TM Ref - Top Mount
Maytag RBE193TV Ref - Top Mount
Maytag RBE193TW Ref - Top Mount
Maytag RBE19KA-3A  Ref - Top Mount
Maytag RBE19KN-3A  Ref - Top Mount
Maytag RBE19KY-3A  Ref - Top Mount
Maytag RBE214AFM Ref - Top Mount
Maytag RBE214AFV Ref - Top Mount
Maytag RBE214RFA  Ref - Top Mount
Maytag RBE214RFV  Ref - Top Mount
Maytag RBE214TFA Ref - Top Mount
Maytag RBE214TFM Ref - Top Mount
Maytag RBE214TFV Ref - Top Mount
Maytag RBE21KA-4AF  Ref - Top Mount
Maytag RBE21KA4AF  Ref - Top Mount
Maytag RBE21KN-4AF  Ref - Top Mount
Maytag RBE21KN4AF  Ref - Top Mount
Frigidaire RBF136CL Frg(v1) / Electric Cooktop
Frigidaire RBF139CE1 Frg(v1) / Cooktop
Frigidaire RBF139CE2 Frg(v1) / Cooktop
Amana RBG322T Mwave - Cntrtp / Stand Alone
Amana RBG322T1 Mwave - Cntrtp / Stand Alone
Amana RBG358P Mwave - Cntrtp / Stand Alone
Amana RBG622T Mwave - Cntrtp / Stand Alone
Amana RBG635T Mwave - Cntrtp / Stand Alone
Frigidaire RBGF119E1 BLACK Frg(v8) / Electric Cooktops and Control Box
Frigidaire RBGF119EL1 Frg(v7) / Electric Cooktops and Control Box
Frigidaire RBGF119EW1 Frg(v6) / Electric Cooktops and Control Box
Amana RBK22AA0 Range - S/i Std Gas
Amana RBK22AA093M Range - S/i Std Gas
Amana RBK22AA5 Range - S/i Std Gas
Amana RBK22AAL Range - S/c S/i Ddraft Gas
Amana RBK22AAW Range - S/c S/i Ddraft Gas
Amana RBK24AA Range - S/i Std Gas
Amana RBK24AA0 Range - S/i Std Gas
Amana RBK24AA093M Range - S/i Std Gas
Amana RBK24AA5 Range - S/i Std Gas
Amana RBK24AAL Range - S/c S/i Ddraft Gas
Amana RBK24AAW Range - S/c S/i Ddraft Gas
Amana RBK26AA Range - S/i Std Gas
Amana RBK26AA0 Range - S/i Std Gas
Amana RBK26AA093M Range - S/i Std Gas
Amana RBK26AA5 Range - S/i Std Gas
Amana RBK26AAL Range - S/c S/i Ddraft Gas
Amana RBK26AAW Range - S/c S/i Ddraft Gas
  #2 (permalink)
Old 03-08-2010, 08:02 PM
Junior Member
guido79 is on a distinguished road
Default Re: Oven light stays on constantly
Quote:
Having the same problem with our Whirlpool (RBD306PDZ8) on the lower oven. The door does not close all of the way allowing the light to stay on. My wife has taped velcro to the side of the oven to keep the door shut so the light turns off. This can probably happen with the top oven too as they appear to use the same hinge assembly. I'm going to order new hinges and install them to see if this fixes the issue.
Hope this helps you.
  #3 (permalink)
Old 07-18-2012, 02:43 PM
Junior Member
firemankurt is on a distinguished road
Lightbulb Kitchenaid Oven Light Stays On
My Kitchenaid oven light stayed on and oven light button would not turn it of. Instead panel beeps 3 times.
The solution was quite simple and required no dis-assembly (Although I found solution after dis-assembly.)
Problem is that Self cleaning oven lock is partially engaged.
To reset and fix:
1. Pull out on latching mechanism/hook under control panel.
2. Move to your right until interior light turns off. (simulates door closed)
3. Press Self clean button and let lock fully engage.
4. Press cancel to stop Self clean.
5. Close door
Hope this helps someone.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Light stays on Cody32 Refrigerator & Freezer Repair 0 12-14-2009 08:24 PM
Oven temperature control light stays on harterha Oven Repair (including Ranges and Cooktops) 1 07-04-2009 01:07 PM
Maytag Oven ON Light stays on Madmax Oven Repair (including Ranges and Cooktops) 1 04-28-2009 07:27 PM
My oven door won't stay shut and the light stays on. The door is loose. Vanise Oven Repair (including Ranges and Cooktops) 2 03-24-2008 11:36 AM
Oven Light Stays On washind Oven Repair (including Ranges and Cooktops) 3 02-26-2008 05:30 PM
