Discuss
Oven light stays on constantly
 in
Thanks for the steps! My oven light is now shut off and stove is working! You saved me quite a
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven light stays on constantly
  #11 (permalink)
Old 09-01-2017, 11:33 AM
Junior Member
mc5523 is on a distinguished road
Default Thank you!
Thanks for the steps! My oven light is now shut off and stove is working! You saved me quite a bit of $ !!!!
  #12 (permalink)
Old 11-29-2017, 07:14 AM
Junior Member
Teedubbs is on a distinguished road
Default
I had the same problem but found a different solution. The door latch is a flat, fairly sturdy piece of metal. When u shut the door, the latch hits the door and shuts the light off. After repeated use, the plate on the door that the latch hits, wears out. The plate is made of very thin metal and is susceptible to wear. I cut a small piece of light metal, bent it so that I could drill a hole in it, then secured it to the door (where the latch strikes it) with the screw that was in the door
  #13 (permalink)
Old 12-07-2017, 09:12 PM
Junior Member
charitap is on a distinguished road
Default Any advice is highly appreciated
My oven light stays on even after closing the oven. For couple of weeks it would turn off after pressing hard and then that trick stopped working but the light will turn off after 15 minutes or so and then finally it never went away and kept on but oven works fine.
I trusted choice home warranty and called them to fix and they sent a repair man who pulled out double oven out of the wall and played with it for one hour and told me the control board is malfunction and needs replaced and said he will come and fix after the part arrives. days turned to months and that guy didnt pick up my phone or choice warranty phone and they sent another guy home to check. According to second guy, the control board needs replaced and top and bottom locker is assembly needs replaced and it will cost $281 etc as locker assembly is not. Choice says they will provide $600 to replace oven (oven costs about $2400 to replace RBD308PVS) or repair the oven and I need to pa $281 for locker assembly.
My question is did the first guy correct in diagnosis about control board malfunction or did he spoil my oven? or even worse did he stole any parts of the oven? Ever since he put hands on it the oven stopped working and giving error code when I try to bake. BEfore that I only had light issue and I used to bake everything I need.
What should I do? replace the oven or just get someone to repair it. I dont want choice warranty guys to enter my property even.
Oven
  #14 (permalink)
Old 01-31-2018, 04:00 PM
Junior Member
chikker is on a distinguished road
Default
The advice below looks great! But I don't know what step 1 means; what/where is latch and control panel? The rest I can do.
Quote:
Originally Posted by firemankurt View Post
My Kitchenaid oven light stayed on and oven light button would not turn it of. Instead panel beeps 3 times.
The solution was quite simple and required no dis-assembly (Although I found solution after dis-assembly.)
Problem is that Self cleaning oven lock is partially engaged.
To reset and fix:
1. Pull out on latching mechanism/hook under control panel.
2. Move to your right until interior light turns off. (simulates door closed)
3. Press Self clean button and let lock fully engage.
4. Press cancel to stop Self clean.
5. Close door
Hope this helps someone.
  #15 (permalink)
Old 03-09-2018, 09:10 PM
Junior Member
jessephillips is on a distinguished road
Default Different Solution!
The multi-step solution from above didn't work for us, well it didn't even make sense for our oven - we must have a different model.
We have one that has two oven bays (the top one is really small).
Solution:
We pushed the "start" button on the top right (above the light off buttons). We held it down for 5 seconds, which I guess did something to unlock the buttons? And then we pressed start again and the lights went off. Weird.
Symptom:
The lights in both ovens were on and the off buttons wouldn't work -- but they didn't beep, they just didn't respond at all, which was annoying.
I hope this helps someone.
  #16 (permalink)
Old 08-09-2018, 11:38 PM
Junior Member
pshastri is on a distinguished road
Default
The steps mentioned in the reply worked to turn off the oven light.
Thanks,
-priya
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
My oven door won't stay shut and the light stays on. The door is loose. Vanise Oven Repair (including Ranges and Cooktops) 3 05-12-2016 09:20 PM
Light stays on Cody32 Refrigerator & Freezer Repair 0 12-14-2009 08:24 PM
Oven temperature control light stays on harterha Oven Repair (including Ranges and Cooktops) 1 07-04-2009 01:07 PM
Maytag Oven ON Light stays on Madmax Oven Repair (including Ranges and Cooktops) 1 04-28-2009 07:27 PM
Oven Light Stays On washind Oven Repair (including Ranges and Cooktops) 3 02-26-2008 05:30 PM
