| » KitchenAid Oven Will not heat |
Model Number: KDRP407HSS4 Brand: Kitchen Aid Age: 5 - 10 years
Oven will not heat. We were getting error codes F02 at random. Recently, during baking the oven temp went up to the max by itself and the door locked. We unlocked by turning off the breaker overnight. We also replaced the control unit. The controls work but the oven will not heat.
Here is your tech sheet
http://www.servicematters.com/docs/w...%204453057.pdf Sounds like the unit had a thermal run away. Perhaps the thermal fuse is blown.
__________________
See the attachment for the tech sheet, the old source is no longer available.
Here are our parts Replacement parts for WHIRLPOOL KDRP407HSS4 RANGE-DUAL FUEL | AppliancePartsPros.com Looking at the wiring diagram I would say that your control board is shot. Since the convection works correctly you know that power to the unit and it's temperature control is OK. Also that the thermal fuse is OK so that leaves the board. Before replacing it I would check that all the wiring to the elements is OK.
__________________
Cannot explain why the link does not work. I just tried it (open in new tab) and it worked for me.
Note: I use Firefox. Perhaps your net security settings are too high. You could go to the AppliancePartspros parts website and just enter in your model number.
__________________
| Display Modes | |
| KitchenAid oven takes long time to heat up | weiganp | Oven Repair (including Ranges and Cooktops) | 0 | 11-17-2009 10:46 PM |
| KitchenAid Dishwasher won't heat/sanitize | cooksle | Dishwasher Repair | 0 | 11-08-2009 10:27 PM |
| Kitchenaid Oven will not heat up unless valve is tapped on | evelyn915 | Oven Repair (including Ranges and Cooktops) | 0 | 10-19-2009 08:59 AM |
| KitchenAid Oven won't heat up. | tech_58 | Oven Repair (including Ranges and Cooktops) | 1 | 05-30-2009 07:28 PM |
| Kitchenaid microwave runs but won't heat | ladymay65 | Microwave Repair | 1 | 03-28-2009 01:09 PM |
