| » New Error Code on Whirlpool after service |
Model Number: RBS245PDB2 Brand: Whirlpool Age: 1 - 5 years
Was getting the E3 F2 code and had the control panel replaced yesterday. Today, I'm getting a new error code - E0 F2. Any thoughts?
Here is the tech sheet
http://www.servicematters.com/docs/w...%204454766.pdf Unplug the unit Open it up Remove the ribbon cable from the keypad to the control board at the control board. Clean the edge connector. If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive. Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here. Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates. Reconnect everything and give it a try.
__________________
| Display Modes | |
| whirlpool duet error code FH | misterfixall | Washer Repair | 13 | 11-10-2010 10:32 AM |
| Whirlpool Error Code F1E6 | mikelanyll | Oven Repair (including Ranges and Cooktops) | 9 | 11-08-2010 04:53 PM |
| F3 Error code on whirlpool Range | Larry56 | Oven Repair (including Ranges and Cooktops) | 3 | 10-11-2009 09:29 AM |
| whirlpool gas range error code f-2 | ted2799 | Oven Repair (including Ranges and Cooktops) | 0 | 09-12-2009 05:25 PM |
| Whirlpool Error Code F5-E0 | Kevin Byrne | Oven Repair (including Ranges and Cooktops) | 2 | 10-18-2007 08:01 PM |
