| » GE oven ELECTRIC F2 CODE |
Model Number: JBP79WY1 Brand: GE Age: More than 10 years
While Baking The Broiler Came On. We Were Unble To Turn The Oven Off. We Had To Unplug It. When We Plugged It Back In Hours Later To Use The Cook Top The Broiler Came On Again. What Part Do I Need
Replacement parts for GE JBP79WY1 | AppliancePartsPros.com The most likely cause is the Control Board Item 16 is Section 2. Sounds like the broil relay contacts are welded together. The parts breakdown is confusing in that it shows 2 Item 15's in Section 2 One at $27.67 and one at $87.11. The drawing shows a ribbon cable coming off of it but when you look at the parts picture it is just a faceplate/overlay. You will probably need one of these as they are normally glued to the control board assembly. Only way to tell is open the control panel and check. I would call AppliancePartsPros to clear up the above confusion.
__________________
| Display Modes | |
| code F1 on electric oven | bigjohn327 | Oven Repair (including Ranges and Cooktops) | 1 | 07-03-2009 08:10 PM |
| Kenmore Electric Single Oven F10 code | houstonm | Oven Repair (including Ranges and Cooktops) | 1 | 06-09-2009 02:20 PM |
| whirlpool electric oven fault code e3 f2 | heidi | Oven Repair (including Ranges and Cooktops) | 1 | 02-04-2009 05:39 PM |
| electric oven - F-3 error code, still having problems | AKT | Oven Repair (including Ranges and Cooktops) | 0 | 03-20-2008 10:10 AM |
| electric oven - F-3 error code | AKT | Oven Repair (including Ranges and Cooktops) | 1 | 02-20-2008 03:02 PM |
