Discuss
Only the top oven element gets a little hot.
 in
When you turn the oven on only the top element puts off some heat. The control panel does not indicate
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Only the top oven element gets a little hot.
  #1 (permalink)
Old 11-12-2009, 07:47 PM
Junior Member
t5816k0 is on a distinguished road
Cool Only the top oven element gets a little hot.
Model Number: Rdds30V   Brand: Thermador   Age: 5 - 10 years
When you turn the oven on only the top element puts off some heat. The control panel does not indicate a problem. The oven will heat a little and the temperature on the screen will only reach about 200 after about 1/2 hour. The bottom element stays cool to the touch. Should I replace the lower element or could it be something else?
Ads By Google
Related Models
Thermador RDDS30V
Thermador RDDS30VQB PRIOR TO S/N 9707
Thermador RDDS30VQB S/N 9707 & UP
Thermador RDDS30VRS PRIOR TO S/N 9707
Thermador RDDS30VRS S/N 9707 & UP
Whirlpool RDE1100W0
Whirlpool RDE1100W1
Whirlpool RDE1100W2
Whirlpool RDE1300W
Whirlpool RDE1300W1
Whirlpool RDE1300W2
Whirlpool RDE1400W
Whirlpool RDE1400W1
Whirlpool RDE1400W2
Whirlpool RDE22302
Whirlpool RDE2300W
Whirlpool RDE2300W1
Whirlpool RDE2300W2
Whirlpool RDE2400P0
Whirlpool RDE2400P1
Whirlpool RDE2400P2
Whirlpool RDE2400W0
Whirlpool RDE2400W1
Whirlpool RDE2400W2
Whirlpool RDE2500P0
Whirlpool RDE2500P1
Whirlpool RDE2500P2
Whirlpool RDE3000W
Whirlpool RDE3020W
Whirlpool RDE3100W
Whirlpool RDE31E0W
Whirlpool RDE32302
Whirlpool RDE3230W
Whirlpool RDE3300W
Whirlpool RDE3340W
Whirlpool RDE3360W
Whirlpool RDE3400W
Whirlpool RDE3400W1
Whirlpool RDE3400W2
Whirlpool RDE3450W
Whirlpool RDE34EPW
Whirlpool RDE350PW
Whirlpool RDE350PW1
Whirlpool RDE355PP
Whirlpool RDE3600W
Whirlpool RDE3600W2
Whirlpool RDE3700W
Whirlpool RDE3700W1
Whirlpool RDE3700W2
Whirlpool RDE3900W
Whirlpool RDE3900W1
Whirlpool RDE390PW
Whirlpool RDE390PW2
Whirlpool RDE3950W
Whirlpool RDE395PP
Whirlpool RDE4400W0
Whirlpool RDE4400W1
Whirlpool RDE4400W2
Whirlpool RDE4900W
Whirlpool RDE4900W1
Whirlpool RDE4900W2
Whirlpool RDE4950W
Whirlpool RDE6030W0
Whirlpool RDE6030W1
Whirlpool RDE6030W2
Whirlpool RDE6030W3
Whirlpool RDE6100W
Whirlpool RDE6100W1
Whirlpool RDE6100W2
Whirlpool RDE6300W
Whirlpool RDE6300W1
Whirlpool RDE6300W2
Whirlpool RDE630PN0
Whirlpool RDE6550W
Whirlpool RDE6550W1
Whirlpool RDE6550W2
Whirlpool RDE6700W
Whirlpool RDE6700W1
Whirlpool RDE6700W2
Whirlpool RDE8400W
Whirlpool RDE8400W1
Whirlpool RDE8400W2
Whirlpool RDE8500W
Whirlpool RDE8500W1
Whirlpool RDE8500W2
Whirlpool RDE8550
Whirlpool RDE85501
Whirlpool RDE85502
Whirlpool RDE950PW
Whirlpool RDE950PW1
Whirlpool RDE950PW2
Whirlpool RDE955PP
Whirlpool RDE9600W
Whirlpool RDE9600W2
Thermador RDF30
Thermador RDF30QB PRIOR TO S/N 9708
Thermador RDF30QB S/N 9708 & UP
Thermador RDF30QW PRIOR TO S/N 9708
Thermador RDF30QW S/N 9708 & UP
Thermador RDF30RS PRIOR TO S/N 9707
Thermador RDF30RS S/N 9707 & UP
Thermador RDFS30
Thermador RDFS30 PRIOR TO S/N 9708
Thermador RDFS30 S/N 9708 & UP
Whirlpool RDH2030
Whirlpool RDH2036
Whirlpool RDH2330
Whirlpool RDH2336
Whirlpool RDH2630
Whirlpool RDH2636
Whirlpool RDH4330
Whirlpool RDH4336
Whirlpool RDH4630
Whirlpool RDH4636
Whirlpool RDH7330
Whirlpool RDH7336
Whirlpool RDH7630
Whirlpool RDH7636
Whirlpool RDH8330
Whirlpool RDH8630
  #2 (permalink)
Old 11-13-2009, 05:40 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Wiring (ref30/res30) replacement parts for THERMADOR RDDS30V | AppliancePartsPros.com
Bake element is Item 24 in Section 10
I would check it before replacing it as it could be other things.
Unplug or remove power from the unit.
Remove the bake element usually a screw or two and it pulls forward.
Undo the wires from it. I like to clip something onto the oven wires so they do not disappear into the back.
Measure it with a meter.
Should be around 10 ohms.
Often you can see where it burned out but not always.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
oven element/broiler element not working stove top is MD110772 Oven Repair (including Ranges and Cooktops) 3 07-05-2011 01:23 AM
Oven element brent_trucker Oven Repair (including Ranges and Cooktops) 0 11-30-2009 09:40 AM
Oven element not getting hot keribarker Oven Repair (including Ranges and Cooktops) 2 04-10-2009 05:16 AM
Viking oven - how do I replace the bottom oven element blueyezn Oven Repair (including Ranges and Cooktops) 1 11-25-2008 12:11 PM
Element won't heat up (20ohms on element and 120volts to the element)? puddlejumper123 Oven Repair (including Ranges and Cooktops) 0 04-22-2008 07:49 PM
