Discuss
viking burner ignition
 in
The rt front burner on my range will not autoignite. Gas does flow from it and the igniter will fire
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » viking burner ignition
  #1 (permalink)
Old 11-12-2009, 04:12 PM
rcape rcape is offline
Junior Member
rcape is on a distinguished road
Default viking burner ignition
Brand: -other-   Age: 5 - 10 years
The rt front burner on my range will not autoignite. Gas does flow from it and the igniter will fire if I activate it by turning on another burner. The igniter fires normally when I turn on another burner. This unit does have the auto reignite feature. Is the problem in the knob for the problem burner? How does the flame sensor reignite work.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Top Burner Ignition switch 6tinker@arkvi.com Oven Repair (including Ranges and Cooktops) 0 08-14-2009 07:18 PM
Oven Burner ignition stevestein Oven Repair (including Ranges and Cooktops) 0 07-16-2009 06:05 PM
Top burner ignition module Driscol Oven Repair (including Ranges and Cooktops) 3 09-09-2008 11:19 AM
burner ignition TommyG Oven Repair (including Ranges and Cooktops) 1 08-25-2008 01:35 PM
burner ignition has a mind of its own Laura Oven Repair (including Ranges and Cooktops) 2 04-21-2008 01:57 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
