Discuss
Gaggenau Oven heating problem
 in
When the mode knob is set to convection only and tested at 350 degrees the oven works properly and holds
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Gaggenau Oven heating problem
  #1 (permalink)
Old 02-27-2008, 10:42 AM
Fred Bossler Fred Bossler is offline
Junior Member
Fred Bossler is on a distinguished road
Unhappy Gaggenau Oven heating problem
Model Number: EB 291630   Brand: -other-   Age: 1 - 5 years
When the mode knob is set to convection only and tested at 350 degrees the oven works properly and holds temperature within 5 degrees. If mode knob is set for bottom heat with convection the oven is at only 300 degrees although the check temperature function shows the oven at 355. If the mode knob is set to bottom heat without convection the top shelf of the oven goes to 400 degrees while the bottom shelf is at 350. Any mode setting which includes the bottom heat shows these large variations from the desired temperature
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
heating problem techdowe Dryer Repair 1 01-27-2008 07:04 PM
Heating Problem greenhead88 Oven Repair (including Ranges and Cooktops) 0 01-19-2008 01:43 PM
Gaggenau Dishwasher code F jdcantin Dishwasher Repair 1 12-16-2007 08:56 PM
Heating Problem Lynn Wachter Oven Repair (including Ranges and Cooktops) 3 12-11-2007 12:32 PM
Gas Dryer Heating Problem RARMSTRONG@ADELPHIA.NET Dryer Repair 1 12-10-2007 01:19 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
