| » Oven does not fire up |
Model Number: arg7302www Brand: Amana Age: 5 - 10 years
The gas oven and broiler decided not to work the other night so I took a look inside and found that the oven ignitor glows bright almost white when selected but the ignitor for the broiler does not glow at all. Will a bad broiler ignitor cause the safety valve for both the oven and broiler to become inoperative ?
Thanks Ads By Google Related Models |
The broiler igniter can not damage the safety valve.
The first thing I would check is the gas shut off valve (#23 on the gas supply break down diagram). Then I would check amps drawn in the bake igniter circuit. If it's less than 3.2 amps - the igniter is bad and has to be replaced. Check the broil igniter for continuity and replace it if it's open. - The part number for the broil igniter is AP2934763 - The part number for the bake igniter is AP172397 Both igniters are coming without brackets. You have to use the old bracket for the broil igniter. For the bake igniter you can use the old bracket or you can buy the new one. - The part number for the bake igniter bracket is AP174418 Here are the break down diagrams for the Amana range Model ARG7302WW Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| Tappan oven won't fire up... | chippy309 | Oven Repair (including Ranges and Cooktops) | 0 | 12-02-2009 05:42 PM |
| GE oven fire | Stacey72 | Oven Repair (including Ranges and Cooktops) | 3 | 05-31-2009 05:01 PM |
| Oven Drawer fire | AshleyD | Oven Repair (including Ranges and Cooktops) | 2 | 12-08-2008 08:41 PM |
| oven won't fire | curt | Oven Repair (including Ranges and Cooktops) | 1 | 12-06-2007 01:39 PM |
| Oven Won't Fire | OttoZ | Oven Repair (including Ranges and Cooktops) | 0 | 11-11-2007 09:07 AM |
