| » Amana Oven Won't heat... |
Model Number: AER5715QAW Brand: Amana Age: 1 - 5 years
I have an Amana Oven Model #AER5715QAW and purchased an oven element from you, however more is wrong--I suspect the oven sensor--part # 12001656 I think. Is there a way to confirm if it is the sensor. Oven nor Broil element respond (no oven preheating)... display is stuck on 100 degrees, but the oven clicks as though it is pre-heating... and nothing happens. How many parts could still be the problem? Am I on the right track--thinking about the sensor?
Some details: When the oven went out, I happened to be at home--I heard a sort of clank sound... The oven was not being used at the time. Only later did we discover the bad element. When I replaced the oven element, the bad element was broken (I'd never seen that before). Element was missing a 2 inch section which sat on the floor of the enclosure--totally disconnected from the element. The display and range top and all functions seem to work fine--just miss the oven... Thank you! Ads By Google Related Models |
Most likely the problem is a bad control board aka a clock/timer.
- The clock Part number: AP4100738 Here are the breakdown diagrams and Replacement parts for AMANA AER5715QAW | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| amana oven wont heat | russ100 | Oven Repair (including Ranges and Cooktops) | 7 | 01-06-2011 04:58 AM |
| Amana Electric oven won't heat | m218perez | Oven Repair (including Ranges and Cooktops) | 10 | 12-12-2009 12:17 PM |
| Amana Stove won't heat up. | sundown12 | Oven Repair (including Ranges and Cooktops) | 0 | 07-18-2009 10:34 AM |
| Amana/Maytag Electric oven won't heat above 250 | quickmom | Oven Repair (including Ranges and Cooktops) | 1 | 06-11-2009 02:53 PM |
| Amana oven and broiler won't heat | sf46 | Oven Repair (including Ranges and Cooktops) | 0 | 04-07-2009 08:46 AM |
