| » Thermador Oven will not heat |
Model Number: rdss30 Brand: Thermador Age: 1 - 5 years
My range will not heat above 200 degrees. The bake element tests out fine. I tried replacing the control panel. Now it looks like it might be the thermal sensor in the oven. However, I can not seem to trace the leads on the sensor back to the control module if that is where they go. Does anyone know how to test the sensor and if so how you replace it? It seems like I have to rip the whole unit apart to get to it. The part listed on this site shows it connected to two long white wires that need to be butt spliced in somewhere. But where?
Thanks Andrew Ads By Google Related Models |
| Display Modes | |
| Thermador Oven won't heat up | mommyoven | Oven Repair (including Ranges and Cooktops) | 2 | 11-11-2009 05:43 PM |
| Thermador Oven will not heat | westillustration | Oven Repair (including Ranges and Cooktops) | 0 | 11-11-2009 11:06 AM |
| Thermador gas oven will not heat | mbasboll | Oven Repair (including Ranges and Cooktops) | 0 | 10-23-2009 08:43 AM |
| Thermador Oven No Heat | trebor | Oven Repair (including Ranges and Cooktops) | 0 | 01-05-2009 12:17 PM |
| THERMADOR double oven no heat | ialandmeier | Oven Repair (including Ranges and Cooktops) | 0 | 04-03-2008 10:06 AM |
