Discuss
FC code jenn-air new clock just installed
 in
I just installed the new clock assembly part # 71001799 clock came on and was able to set time- push
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » FC code jenn-air new clock just installed
  #1 (permalink)
Old 02-26-2008, 04:50 PM
Junior Member
retro repair is on a distinguished road
Question FC code jenn-air new clock just installed
Model Number: sve47600w   Brand: Jenn-Air   Age: More than 10 years
I just installed the new clock assembly part # 71001799 clock came on and was able to set time- push any other function and "fc" flashes and dings. I cut power off and back on- same result. I put old part back in and every thing works fine- except the clock disply is not litt. Is this the correct part? Please Help ! Thanks!
Ads By Google
Related Models
Jenn-Air SVE47600W Range - S/c S/i Ddraft Ele
Jenn-Air SVE47600WC Range - S/c S/i Ddraft Ele
Jenn-Air SVE87600B Range - S/c S/i Ddraft Ele
Jenn-Air SVE87600W Range - S/c S/i Ddraft Ele
Whirlpool SVF100W0
Whirlpool SVF100W1
Whirlpool SVF12FRHW00
Whirlpool SVF15NRHW00
Whirlpool SVF15NRHW01
Whirlpool SVF15NRHW02
Whirlpool SVF15NRJW00
Whirlpool SVF20NRKQ00
Whirlpool SVF60W0
Whirlpool SVF60W1
Whirlpool SVF70W0
Whirlpool SVF70W1
Whirlpool SVF75W0
Whirlpool SVF75W1
Whirlpool SVF75W2
Whirlpool SVF80W0
Whirlpool SVF80W1
Whirlpool SVF90W0
Whirlpool SVF90W1
Whirlpool SVP100W0
Whirlpool SVP50W0
Whirlpool SVP60W0
Whirlpool SVP60W1
Whirlpool SVP70W0
Whirlpool SVP75W0
Whirlpool SVP80W0
Whirlpool SVP90W0
Whirlpool SVU100W0
Whirlpool SVU100W1
Whirlpool SVU100W2
Whirlpool SVU60W0
Whirlpool SVU60W1
Whirlpool SVU60W2
Whirlpool SVU70W0
Whirlpool SVU70W1
Whirlpool SVU70W2
Whirlpool SVU80W0
Whirlpool SVU80W1
Whirlpool SVU80W2
Whirlpool SVU90W0
Whirlpool SVU90W1
Whirlpool SVU90W2
Amana SW22H Ref - SXS/I&W
Amana SW22MBG Ref - SXS/I&W
Amana SW22MBL Ref - SXS/I&W
Amana SW22MBW Ref - SXS/I&W
Amana SW25H Ref - SXS/I&W
Amana SWDT22H Ref - SXS/I&W
Amana SWDT25H Ref - SXS/I&W
Whirlpool SWF100W0
Whirlpool SWF100W2
Whirlpool SWF60W0
Whirlpool SWF60W2
Whirlpool SWF70W0
Whirlpool SWF70W2
Whirlpool SWF80W0
Whirlpool SWF80W2
Whirlpool SWF80W8
Whirlpool SWF80W9
Whirlpool SWF90W0
Whirlpool SWF90W1
Whirlpool SWF90W2
Amana SWP25H Ref - SXS/I&W
Whirlpool SWP70W0
Whirlpool SWP80W0
Whirlpool SWP90W0
Amana SWPD25H Ref - SXS/I&W
White Westinghouse SWS1233CQ0 White Westinghouse/washer
White Westinghouse SWS1233CQ1 White Westinghouse/washer
White Westinghouse SWS1233CS0 White Westinghouse/washer
White Westinghouse SWS1233CS1 White Westinghouse/washer
White Westinghouse SWS1339CC1 White Westinghouse/washer
White Westinghouse SWS1339CC2 White Westinghouse/washer
White Westinghouse SWS1549AQ0 Washer - W.westinghouse
White Westinghouse SWS1549AQ1 Washer - West/grupo Famsa
White Westinghouse SWS1549AQ2 White Westinghouse/washer
White Westinghouse SWS1549AS0 Washer - W.westinghouse
White Westinghouse SWS1549AS1 Washer - West/grupo Famsa
White Westinghouse SWS1549AS2 White Westinghouse/washer
White Westinghouse SWS1649CQ0 White Westinghouse/washer
White Westinghouse SWS1649CQ1 White Westinghouse/washer
White Westinghouse SWS1649CS0 White Westinghouse/washer
White Westinghouse SWS1649CS1 White Westinghouse/washer
White Westinghouse SWS933AQ0 Washer - W.westinghse
White Westinghouse SWS933AQ1 Washer - West/grupo Famsa
White Westinghouse SWS933AQ2 White Westinghouse/washer
White Westinghouse SWS933AS0 Washer - W.westinghse
White Westinghouse SWS933AS1 Washer - West/grupo Famsa
White Westinghouse SWS933AS2 White Westinghouse/washer
White Westinghouse SWSG1031DQ0 White Westinghouse/laundry Center
White Westinghouse SWSG1031DQ1 White Westinghouse/laundry Center
White Westinghouse SWSG1031DS0 White Westinghouse/laundry Center
White Westinghouse SWSG1031DS1 White Westinghouse/laundry Center
White Westinghouse SWT1549AQ0 Washer - W.westinghouse
White Westinghouse SWT1549AS0 Washer - W.westinghouse
White Westinghouse SWT933AQ0 Washer - W.westinghouse
White Westinghouse SWT933AS0 Washer - W.westinghouse
Whirlpool SWU100W0
Whirlpool SWU100W2
Whirlpool SWU60W0
Whirlpool SWU60W2
Whirlpool SWU70W0
Whirlpool SWU70W2
Whirlpool SWU80W0
Whirlpool SWU80W2
Whirlpool SWU90W0
Whirlpool SWU90W2
White Westinghouse SWX703AQ0 Washer - W.westinghouse
White Westinghouse SWX703AQ1 Washer - West/grupo Famsa
White Westinghouse SWX703AQ2 White Westinghouse/washer
White Westinghouse SWX703AS0 Washer - W.westinghouse
  #2 (permalink)
Old 02-27-2008, 04:17 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The "FC" error code means "Communication error between boards".
Check the "J2" harness, ohm wires end to end.
If the harness is fine then the display board is defective and has to be exchanged under the part warranty.
You have to call the place where you bought it from.
The part number is correct.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 03-14-2008, 08:08 AM
Junior Member
Default
Thanks Gene, bad part alright. Just installed new replacement. Almost every thing OK. All functions work except the "cancel off" function does not work now. I have to dial in "oooo" to cancel baking functions now. Any sugestions? Thanks !
  #4 (permalink)
Old 03-18-2008, 01:48 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Open the control panel and remove the ribbon from the display board.
Clean the ribbon, using an eraser, and plug it back.
If it would not help then the control panel (membrane switch) has to be replaced.
In order to provide the right part number for the membrane switch I need the color of the control panel.
Here are the break down diagrams for the Jenn Air range Model SVE47600W
__________________
  #5 (permalink)
Old 11-30-2008, 01:54 PM
Junior Member
katok is on a distinguished road
Default
I have the same problem with the same model Jenn Aire Gas Stove top.
I've replaced the clock circuit board and the Power Circuit board in the back but have two remaining problems.
a) whenever I turn the on any of the 4 gas burners (when the igniter starts clicking) the clock goes blank and then it either resets to a flashing 12 or I get a FC code and alarm. (we've resigned to lighting the burners with matches to prevent this)
b) the cancel button doen not work.
Could there be a short some where in the igniter circuit? Is there any circuit connection between the gas igniters and the clock?
Jim
  #6 (permalink)
Old 12-01-2008, 11:24 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Jim,
Did you check the power source as has been recommended here: Alarm FC?
__________________
  #7 (permalink)
Old 01-12-2009, 06:01 PM
Junior Member
draxjon is on a distinguished road
Cool Clock assembly
I have the exact same problem on the Jennair SVE47600W Just replaced the same display assembly now nothing works just the fan stays on and no reaction from the key pad and the ribbon is fine any suggestions? did get a F- code once.
  #8 (permalink)
Old 11-27-2010, 10:49 AM
Junior Member
EdFromOhio is on a distinguished road
Default
Quote:
I realize that this thread is old, but draxjon, the behavior you describe is when the ribbon cable from the membrane isn't plugged in properly to the clock assembly. There is a little plastic retainer that you need to gently unclip from each end and it will lift a couple of millimeters. Slip the ribbon in all the way until it hits the bottom squarely, then push the plastic retainer down so it clicks. If that doesn't work, it could be that you have a bad membrane or the ribbon was torn during repair.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
jenn air w130 set clock pdalban Oven Repair (including Ranges and Cooktops) 1 10-01-2010 04:13 PM
Jenn Air F5 error code - "Clock" or Power relay board? chanpaul Oven Repair (including Ranges and Cooktops) 2 12-08-2009 12:22 PM
Jenn-Air error FC and clock dim dblanche Oven Repair (including Ranges and Cooktops) 1 04-18-2009 11:36 AM
Replacing Clock in Jenn Air Range Rosemarie Oven Repair (including Ranges and Cooktops) 0 06-10-2008 07:37 AM
Please Help! Jenn Aire Clock Display abbymac Oven Repair (including Ranges and Cooktops) 2 11-01-2007 10:41 AM
