Discuss
Burner won't light
 in
I just bought this from an individual who replaced all the appliances in her new house without using any of
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Burner won't light
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 02-26-2008, 04:43 PM
austin austin is offline
Junior Member
austin is on a distinguished road
Default Burner won't light
Model Number: SF315PEPW2   Brand: Whirlpool   Age: 5 - 10 years
I just bought this from an individual who replaced all the appliances in her new house without using any of the old ones so no history. Everything seems to work fine except the left front burner clicks but will not light. I held a match and it appears no gas is coming through.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-27-2008, 03:41 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
If there is no gas coming through the burner then the problem is the gas burner valve for the left front burner.
Remove control knobs and 4 screws that attach control panel to range cabinet. Pull control panel forward to remove. Set panel and screws aside.
Remove burner grates, burner caps, burners and screws. Lift cook top.
You now have access to the gas burner valve.
There are two different size of the gas burner valve used on the range. Check the plate on the frame behind the bottom drawer to find out the rating for the valve.
- The part number for the 9500 BTU's burner valve is AP3129665
- The part number for the 11500 BTU's burner valve is AP3129666
Here are the break down diagrams for the Whirlpool range Model SF315PEKW1
__________________
Professional appliance repair services in Orange County, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire Electric Oven Rear burner light wont go off seagullgeneral Oven Repair (including Ranges and Cooktops) 1 12-14-2007 04:58 PM
Gas Oven Burner Will not light Matthew Wakefield Oven Repair (including Ranges and Cooktops) 2 11-30-2007 05:50 AM
No burner re-light pbknowles Dryer Repair 0 11-27-2007 07:15 PM
oven burner won't light doc Oven Repair (including Ranges and Cooktops) 1 11-16-2007 02:01 PM
Jenn Air stove top burner does not light J Black Oven Repair (including Ranges and Cooktops) 1 08-17-2007 03:53 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
