| » kitchen range burner problem |
Model Number: FEF342AWG Brand: Frigidaire Age: 1 - 5 years
I carefully installed a new burner wiring harness yesterday unplugging and plugging one wire at a time to be sure I had the harness correctly installed. However, I still have a problem with this stove. The two rear burners heat normally but the front burners do not heat at all. I tested the front burner elements by replacing the back elements with the front and the elements are good.
Is there somewhere else I should be looking to correct this problem or am I correct in thinking that the burner element controls for both front burners need to be replaced? I am asking what may seem like a stupid question only because it seems like a strange coincidence that only the two front burner controls went out while the rear controls still function correctly. I can see no physical disoloration on the rear of either of the front element controls and testing with a volt meter shows the same voltage going to each control via the red wire. Thanks, Bill Evans Ads By Google Related Models |
| Display Modes | |
| Help, element problem on kitchen aid range | geomam | Oven Repair (including Ranges and Cooktops) | 0 | 09-21-2009 01:46 PM |
| Caloric Gas Range Burner Problem | David Sciabarrasi | Oven Repair (including Ranges and Cooktops) | 0 | 08-22-2009 11:57 AM |
| Kitchen Aid Burner Valve | herrz311 | Oven Repair (including Ranges and Cooktops) | 1 | 05-12-2009 09:12 PM |
| range burner igniter problem | jiminnc | Oven Repair (including Ranges and Cooktops) | 0 | 03-16-2009 08:23 AM |
| Smooth top range burner problem | asum | Oven Repair (including Ranges and Cooktops) | 4 | 03-12-2009 11:58 AM |
