| » Frigidaire Gas Oven Digital Display Not Working |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: GLGF388ABC Brand: Frigidaire Age: 1 - 5 years
Hi I have a FRIGIDAIRE GLGF388ABC its about 3 years old and all of a sudden the digital oven display isn't working. What can I do? The stove top was working but now its not even lighting? I tried unpluging it and still nothing. If I order a new display will that fix the problem?
Thanks, S |
The first thing I would check if there is 120V at the power outlet.
If nothing works - the problem most likely is with the power source. Here are the break down diagrams for the Frigidaire range Model GLGF388ABC Gene.
__________________
Professional appliance repair services in Orange County, California. |
I have checked the Ac outlet and there is no problem. The whole digital display is out. After I noticed it I tried the cook top and it light, no problem. I have tried it since and it no longer lights and the pilot light is also out. I do however still have gas that will come out from the cook top. So I no its not the plu or the gas. By changing the digital display do you think it would repair the problem? I know this oven is supposed to be all "computer" digital controled.
Thanks, S |
The "digital display" or the EOC controls the oven only. The ignition for the top burners operates by the ignition module.
It's very unusual for both of these parts went bad at the same time. Thats why I need you to make sure there is nothing wrong with the power supply. Remove the back cover and check the power cord connection to the range. Check for 120V at the terminal block. Gene.
__________________
| Display Modes | |
| Digital control oven | BWizer | Oven Repair (including Ranges and Cooktops) | 4 | 02-04-2008 09:55 AM |
| Display not working but oven does | fourfauls | Oven Repair (including Ranges and Cooktops) | 2 | 12-27-2007 04:23 PM |
| thermador range display not working | sam | Oven Repair (including Ranges and Cooktops) | 5 | 12-27-2007 03:25 PM |
| Count Down Digital Timer | GeorgeK | Dishwasher Repair | 2 | 10-04-2007 04:59 AM |
| Frigidaire Refrigerator Not Working Right | VICKI | Refrigerator & Freezer Repair | 0 | 08-12-2007 10:23 AM |
