| » Fridedaire Duel Fuel Range wont wrok...HELP! |
Model Number: FCS366ECC Brand: Frigidaire Age: 1 - 5 years
Hi. Our oven stopped working after we used the cleaning cycle. We have used this in the past, and never had any problems. No, it doesn't work. We pulled the oven out and checked wiring in th back. Nothing appears to be burnt or overheated. Any help is appreciated.
Chris Ads By Google Related Models |
Here are the parts
Replacement parts for FRG FCS366ECC | AppliancePartsPros.com Here is the wiring diagram http://manuals.frigidaire.com/prodin.../318271911.pdf Our oven stopped working after we used the cleaning cycle. Is it totally dead (no display etc.) We pulled the oven out and checked wiring in th back. Did you check the power in with a meter? Sometimes you can loose half the line without actually tripping the breaker. The control panel only uses half the line. I do not see a fuse that would kill the entire unit. I do see one in the temperature probe circuit, if this opened the unit would think it was overtemperature and not heat up.
__________________
Quote:
OK. I think the problem has been located. The power cable comes in and is wired to a harness where hot, neutral and ground wires exit. The hot(red) leads to a fuse(i think it is a fuse). Then, the red leads to the front under the cook top. i cant see where it goes from there.... I tested the fuse that I mentioned above for continuity and it doesn't test. So, that means the unit isn't getting power. I am trying to locate this part. Are you aware of this part I am talking about? I could take a picture and post it, but I do not beleive that the forum allows for this. Please advise.
Thanks! Chris |
What I earlier called a fuse is a sensor. We went to a repair shop here locally and they confirmed it was a sensor that was stuck open. They don't have a replacement part. The numbers from left to right are
36tx22 21601 f120-15f 318003613 a0546. |
| Display Modes | |
| Help converting a Dacor Duel Fuel Range | bonniepadgett | Oven Repair (including Ranges and Cooktops) | 4 | 02-17-2012 03:12 PM |
| dual fuel range | Donny C | Oven Repair (including Ranges and Cooktops) | 3 | 02-25-2009 05:27 PM |
| Dacor Epicure Duel Fuel Range Problems | Harvey@houseworksinc.com | Oven Repair (including Ranges and Cooktops) | 0 | 01-01-2009 11:22 AM |
| kenmore duel fuel elite range | lizzzyt | Oven Repair (including Ranges and Cooktops) | 3 | 07-31-2008 07:32 PM |
| Range Top Burner Duel Element Wiring | LDWhite | Oven Repair (including Ranges and Cooktops) | 0 | 07-31-2008 11:39 AM |
