Discuss
Need Help to Buy Correct Jenn Air Surface Burners for CVG4280B
 in
What is the part number for the correct 10,000 BTU burners for the right side only of the Jenn
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Need Help to Buy Correct Jenn Air Surface Burners for CVG4280B
  #1 (permalink)
Old 11-07-2009, 07:25 PM
AngusMcFarlan AngusMcFarlan is offline
Junior Member
AngusMcFarlan is on a distinguished road
Default Need Help to Buy Correct Jenn Air Surface Burners for CVG4280B
Model Number: CVG4280B   Brand: Jenn-Air   Age: More than 10 years
What is the part number for the correct 10,000 BTU burners for the right side only of the Jenn Air CVG4280??
I am concerned that I do not get the incorrect 8,000 BTU burners that come as part of the AG202 "cartridge" assembly. These burners have a different air shutter adjustment designed to work with the lower BTU left side gas control. As far as I know, they are not interchangeable with the higher BTU right side burners. I own both and I can confirm that they are different. My right side burners (the ones I wish to replace) have an adjustable air shutter (a screw and moveable window) whereas the left side burners that I purchased as part of the AG202 cartridge have a fixed air shutter and the owner's manual states that their air shutter is designed to work with the lower 8,000 BTU side.
Unfortunately, I cannot find any information (even from Jenn Air) on the correct right side burners. I ended up ordering the following from this site's sponsor:
AP4094514 (74005001) Burner (frt - blk)
AP4094574 (74005189) Burner(rear/black)
I am almost sure they are not correct and I have placed my order on hold until I can get some resolution here. I can't take 8,000 BTU burners as my primaries. The 10,000 are weak as it is. The reason I am almost sure they are incorrect is because these burners are the exact same part number that is sold in the AG202 kit, which is designed for the lower output left side.
Thanks for any help.
Related Models
Jenn-Air CVG4280B Surface Unit - Ddraft Gas
Jenn-Air CVG4280S Surface Unit - Ddraft Gas
Jenn-Air CVG4280W Surface Unit - Ddraft Gas
Jenn-Air CVG4380B Surface Unit - Ddraft Gas
Jenn-Air CVG4380P Surface Unit - Ddraft Gas
Jenn-Air CVG4380PD Surface Unit - Ddraft Gas
Jenn-Air CVG4380PF Surface Unit - Ddraft Gas
Jenn-Air CVG4380PG Surface Unit - Ddraft Gas
Jenn-Air CVG4380PK Surface Unit - Ddraft Gas
Jenn-Air CVG4380PR Surface Unit - Ddraft Gas
Jenn-Air CVG4380PU Surface Unit - Ddraft Gas
Jenn-Air CVG4380W Surface Unit - Ddraft Gas
Jenn-Air CVGX2423B Surface Base Unit - Ddraft Gas
Jenn-Air CVGX2423Q Surface Base Unit - Ddraft Gas
Jenn-Air CVGX2423W Surface Base Unit - Ddraft Gas
Whirlpool CVR1000
Whirlpool CVR2000
Whirlpool CVR3000
Whirlpool CVR500
Whirlpool CVR600
Whirlpool CVR6001
Thermador CVS30RB
Thermador CVS30RS
Thermador CVS30RW
Thermador CVS36RB
Thermador CVS36RS
Thermador CVS36RW
Thermador CVS45RB
Thermador CVS45RS
Thermador CVS45RW
Thermador CVSE36B
Crosley CW18C1 Washer - Top Loading
Crosley CW18C100 Washer - Top Loading
Crosley CW18C124 Washer - Top Loading
Crosley CW18C125 Washer - Top Loading
Crosley CW18C126 Washer - Top Loading
Crosley CW18C127 Washer - Top Loading
Crosley CW18C1A Washer - Top Loading
Crosley CW18C1H Washer - Top Loading
Crosley CW18C3A Washer - Top Loading
Crosley CW18C3H Washer - Top Loading
Crosley CW18C3W Washer - Top Loading
Crosley CW18M4 Washer - Top Loading
Crosley CW18M4A Washer - Top Loading
Crosley CW18M4H Washer - Top Loading
Crosley CW18M4W Washer - Top Loading
Crosley CW18P2A Washer - Top Loading
Crosley CW18P2AC Washer - Top Loading
Crosley CW18P2H Washer - Top Loading
Crosley CW18P2HC Washer - Top Loading
Crosley CW18P2W Washer - Top Loading
Crosley CW18P2WC Washer - Top Loading
Crosley CW18P6A Washer - Top Loading
Crosley CW18P6H Washer - Top Loading
Crosley CW18P6W Washer - Top Loading
Crosley CW18T2A Washer - Top Loading
Crosley CW18T2W Washer - Top Loading
Crosley CW20C5A Washer - Top Loading
Crosley CW20C5H Washer - Top Loading
Crosley CW20C5W Washer - Top Loading
Crosley CW20C7A Washer - Top Loading
Crosley CW20C7W Washer - Top Loading
Crosley CW20M4A Washer - Top Loading
Crosley CW20M6 Washer - Top Loading
Crosley CW20M6A Washer - Top Loading
Crosley CW20M8 Washer - Top Loading
Crosley CW20M8A Washer - Top Loading
Crosley CW20M8H Washer - Top Loading
Crosley CW20M9A Washer - Top Loading
Crosley CW20M9N Washer - Top Loading
Crosley CW20P4A Washer - Top Loading
Crosley CW20P4H Washer - Top Loading
Crosley CW20P4W Washer - Top Loading
Crosley CW20P5A Washer - Top Loading
Crosley CW20P5AC Washer - Top Loading
Crosley CW20P5H Washer - Top Loading
Crosley CW20P5HC Washer - Top Loading
Crosley CW20P5W Washer - Top Loading
Crosley CW20P5WC Washer - Top Loading
Crosley CW20P6 Washer - Top Loading
Crosley CW20P6A Washer - Top Loading
Crosley CW20P6AC Washer - Top Loading
Crosley CW20P6H Washer - Top Loading
Crosley CW20P6HC Washer - Top Loading
Crosley CW20P6W Washer - Top Loading
Crosley CW20P6WC Washer - Top Loading
Crosley CW20P8 Washer - Top Loading
Crosley CW20P8A Washer - Top Loading
Crosley CW20P8AC Washer - Top Loading
Crosley CW20P8AS Washer - Top Loading
Crosley CW20P8ASC Washer - Top Loading
Crosley CW20P8D Washer - Top Loading
Crosley CW20P8DS Washer - Top Loading
Crosley CW20P8DSC Washer - Top Loading
Crosley CW20P8H Washer - Top Loading
Crosley CW20P8HS Washer - Top Loading
Crosley CW20P8HSC Washer - Top Loading
Crosley CW20P8W Washer - Top Loading
Crosley CW20P8WC Washer - Top Loading
Crosley CW20P8WS Washer - Top Loading
Crosley CW20P8WSC Washer - Top Loading
Crosley CW20T5A Washer - Top Loading
Crosley CW20T5W Washer - Top Loading
Crosley CW20T5WC Washer - Top Loading
Crosley CW20T6A Washer - Top Loading
Crosley CW20T6AC Washer - Top Loading
Crosley CW20T6W Washer - Top Loading
Crosley CW20T6WC Washer - Top Loading
Crosley CW20T7A Washer - Top Loading
Crosley CW20T7V Washer - Top Loading
Crosley CW20T7W Washer - Top Loading
Crosley CW20T8A Washer - Top Loading
Crosley CW20T8AC Washer - Top Loading
Crosley CW20T8V Washer - Top Loading
Crosley CW20T8VC Washer - Top Loading
Crosley CW20T8W Washer - Top Loading
Crosley CW20T8WC Washer - Top Loading
Crosley CW22B5M Washer - Top Loading
Crosley CW22B5V Washer - Top Loading
Crosley CW22B6M Washer - Top Loading
  #2 (permalink)
Old 11-07-2009, 10:31 PM
Junior Member
Default
I am now thinking that this is just a matter of Jenn Air shipping the burner with a different air shutter setting when sold as part of the AG202 cartridge for the left side. The burners are probably the same, right? The only difference between 10,000 BTU and 8,000 BTU sides is a larger orfice for the gas output where the burners slide in - at least that's my current thinking. The different look in air shutter design I am seeing between my current burners may just be a Jenn Air design change on the air shutter design. Maybe they went from a set screw and window design circa 1996 to a sliding sleeve type shutter sometime thereafter and that design looks like it continues to this day.
Reply
« Oven | F5 E0 »
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
F5 code on Jenn-Air control surface readout thom2 Oven Repair (including Ranges and Cooktops) 0 06-01-2009 10:18 AM
Hot Surface light stays on when no burners are on dodger58 Oven Repair (including Ranges and Cooktops) 1 04-09-2009 05:25 PM
Jenn air oven heats, but not to correct temp miketesting Oven Repair (including Ranges and Cooktops) 0 07-14-2008 06:42 AM
Maytag Gas Oven.....Surface Burners ALL Ignite..... Tony D. Oven Repair (including Ranges and Cooktops) 6 12-21-2007 11:08 AM
jenn-air cooktop - diagnose correct part Michael Estep Oven Repair (including Ranges and Cooktops) 1 08-01-2007 02:18 PM
