Discuss
F5 E0
 in
I have already replaced the erc and the membrane then it gave me a code for the door latch. ordered
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » F5 E0
  #1 (permalink)
Old 11-07-2009, 02:57 PM
sherinus sherinus is offline
Junior Member
sherinus is on a distinguished road
Default F5 E0
Model Number: RBD275PDB14   Brand: Whirlpool   Age: 5 - 10 years
I have already replaced the erc and the membrane then it gave me a code for the door latch. ordered the door latch and installed and the lights won't go off in the oven and I get a F5 E0 code and the oven doesn't work, just gives me these codes. The door latch is not identical to the one I took off but it bolts up and electricl connections are the same. I have ordered all my parts fro a.p.p. and they say I must talk to you first before they will replace parts. What do I do now??? My email is sherinus@charter.net. Thanks, Thomas
Related Models
Whirlpool RBD275PDB14 27" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PDB15 27" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PDB2
Whirlpool RBD275PDB3
Whirlpool RBD275PDB4
Whirlpool RBD275PDB6
Whirlpool RBD275PDB7
Whirlpool RBD275PDB8
Whirlpool RBD275PDB9
Whirlpool RBD275PDQ1
Whirlpool RBD275PDQ10
Whirlpool RBD275PDQ11
Whirlpool RBD275PDQ12
Whirlpool RBD275PDQ13
Whirlpool RBD275PDQ14 27" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PDQ15 27" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PDQ2
Whirlpool RBD275PDQ3
Whirlpool RBD275PDQ4
Whirlpool RBD275PDQ6
Whirlpool RBD275PDQ7
Whirlpool RBD275PDQ8
Whirlpool RBD275PDQ9
Whirlpool RBD275PDS12
Whirlpool RBD275PDS14 27" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PDS15 27" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PDT10
Whirlpool RBD275PDT11
Whirlpool RBD275PDT12
Whirlpool RBD275PDT13
Whirlpool RBD275PDT14 27" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PDT15 27" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PDT8
Whirlpool RBD275PDT9
Whirlpool RBD275PRB00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PRQ00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PRS00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PRS01 27" Built - in Electric Double Oven Convection - Upper Self - Clean (gold Line)
Whirlpool RBD275PRT00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD276PDB1
Whirlpool RBD276PDB10
Whirlpool RBD276PDB11
Whirlpool RBD276PDB12
Whirlpool RBD276PDB2
Whirlpool RBD276PDB4
Whirlpool RBD276PDB6
Whirlpool RBD276PDB7
Whirlpool RBD276PDB8
Whirlpool RBD276PDB9
Whirlpool RBD276PDQ1
Whirlpool RBD276PDQ10
Whirlpool RBD276PDQ11
Whirlpool RBD276PDQ12
Whirlpool RBD276PDQ2
Whirlpool RBD276PDQ4
Whirlpool RBD276PDQ6
Whirlpool RBD276PDQ7
Whirlpool RBD276PDQ8
Whirlpool RBD276PDQ9
Whirlpool RBD277PDB1
Whirlpool RBD277PDB2
Whirlpool RBD277PDB4
Whirlpool RBD277PDQ1
Whirlpool RBD277PDQ2
Whirlpool RBD277PDQ4
Whirlpool RBD305PDB1
Whirlpool RBD305PDB10
Whirlpool RBD305PDB11
Whirlpool RBD305PDB12
Whirlpool RBD305PDB13
Whirlpool RBD305PDB14 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDB15 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDB2
Whirlpool RBD305PDB3
Whirlpool RBD305PDB4
Whirlpool RBD305PDB6
Whirlpool RBD305PDB7
Whirlpool RBD305PDB8
Whirlpool RBD305PDB9
Whirlpool RBD305PDQ1
Whirlpool RBD305PDQ10
Whirlpool RBD305PDQ11
Whirlpool RBD305PDQ12
Whirlpool RBD305PDQ13
Whirlpool RBD305PDQ14 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDQ15 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDQ2
Whirlpool RBD305PDQ3
Whirlpool RBD305PDQ4
Whirlpool RBD305PDQ6
Whirlpool RBD305PDQ7
Whirlpool RBD305PDQ8
Whirlpool RBD305PDQ9
Whirlpool RBD305PDS12
Whirlpool RBD305PDS14 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDS15 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDT11
Whirlpool RBD305PDT12
Whirlpool RBD305PDT13
Whirlpool RBD305PDT14 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDT15 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PRB00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PRQ00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PRS00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PRT00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD306PDB1
Whirlpool RBD306PDB10
Whirlpool RBD306PDB11
Whirlpool RBD306PDB12
Whirlpool RBD306PDB13
Whirlpool RBD306PDB14 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDB15 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDB2
Whirlpool RBD306PDB4
Whirlpool RBD306PDB6
Whirlpool RBD306PDB7
Whirlpool RBD306PDB8
Whirlpool RBD306PDB9
Whirlpool RBD306PDQ1
Whirlpool RBD306PDQ10
  #2 (permalink)
Old 11-08-2009, 07:04 AM
denman denman is offline
Senior Expert
APP Volunteer
denman will become famous soon enough
Default
Here is the tech sheet.
http://www.servicematters.com/docs/w...%208302068.pdf
I would check the door and the latch switches with a meter.
I would also check that none of them are4 shorting to the frame.
Alternatively, you could
Unplug the unit
Short the door switch wires together
Tape than up so they cannot short to anything
Disconnect one wire from the latch switch.
Also tape it up so that it cannot short to anything.
Plug it in and give it a try.
If you still have the same error odds are high that the board is no good.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
