| » Glass Top Burner will not get red hot with setting on Hi |
Model Number: JBP80WFWW Brand: GE Age: 5 - 10 years
My wife turned on the front left burner, setting "HI" (this is the large single burner) to boil water. While she was doing another chore she heard a pop, turned around to locate the sound and noticed the burner was not glowing red. She proceded to check the other burners, all burners except the front left worked OK. The front left burner no longer gets hot. The indicator light for that burner comes on. The "HOT" light does not come on.
Can you help me diagnose the problem? Related Models |
You have to check for continuity the infinite switch and the heating element for this burner.
- The infinite switch Part number: AP2024074 - The heating element Part number: AP2027787 Here are the breakdown diagrams and Replacement parts for GE JBP80WF1WW | AppliancePartsPros.com Gene.
__________________
Professional appliance repair in Orange County, California. |
Gene,
Thank you for you quick reply. When checking the continuity on the Switch, do you have the terminal designations and what I should expect? With the heating element, I assume there should be a low resistance reading or very close to "0" resistance. Can you provide the terminal designation on the element also? Which one would you check first? or should I say which is the easiest to check first? Thanks again. Ron |
| Display Modes | |
| Ge Burner On High No Matter What The Setting Is On | FDAR | Oven Repair (including Ranges and Cooktops) | 2 | 10-22-2009 07:37 AM |
| front burner bright red even on low setting | razkitty | Oven Repair (including Ranges and Cooktops) | 2 | 10-03-2009 08:37 AM |
| Gas burner stays at low setting when turned on | motfec | Oven Repair (including Ranges and Cooktops) | 3 | 05-27-2009 06:05 PM |
| GE Spectra Glass top burner out | dialysate95 | Oven Repair (including Ranges and Cooktops) | 0 | 03-12-2009 09:16 AM |
| Burner only operates at high, ignores setting on know | SLorenson | Oven Repair (including Ranges and Cooktops) | 1 | 01-27-2009 02:43 PM |
