Discuss
Set-in oven won't turn off.
 in
I just replaced the baking element on bottom of unit. A few days later decided to start the self clean
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Set-in oven won't turn off.
  #1 (permalink)
Old 11-06-2009, 08:29 AM
Junior Member
tdtk42 is on a distinguished road
Default Set-in oven won't turn off.
Model Number: RBD305PD Q1   Brand: Whirlpool   Age: More than 10 years
I just replaced the baking element on bottom of unit. A few days later decided to start the self clean process. Baking element will not turn off since cleaning was finished.
Any ideas?
Ads By Google
Related Models
Whirlpool RBD305PDB1
Whirlpool RBD305PDB10
Whirlpool RBD305PDB11
Whirlpool RBD305PDB12
Whirlpool RBD305PDB13
Whirlpool RBD305PDB14 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDB15 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDB2
Whirlpool RBD305PDB3
Whirlpool RBD305PDB4
Whirlpool RBD305PDB6
Whirlpool RBD305PDB7
Whirlpool RBD305PDB8
Whirlpool RBD305PDB9
Whirlpool RBD305PDQ1
Whirlpool RBD305PDQ10
Whirlpool RBD305PDQ11
Whirlpool RBD305PDQ12
Whirlpool RBD305PDQ13
Whirlpool RBD305PDQ14 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDQ15 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDQ2
Whirlpool RBD305PDQ3
Whirlpool RBD305PDQ4
Whirlpool RBD305PDQ6
Whirlpool RBD305PDQ7
Whirlpool RBD305PDQ8
Whirlpool RBD305PDQ9
Whirlpool RBD305PDS12
Whirlpool RBD305PDS14 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDS15 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDT11
Whirlpool RBD305PDT12
Whirlpool RBD305PDT13
Whirlpool RBD305PDT14 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDT15 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PRB00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PRQ00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PRS00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PRT00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD306PDB1
Whirlpool RBD306PDB10
Whirlpool RBD306PDB11
Whirlpool RBD306PDB12
Whirlpool RBD306PDB13
Whirlpool RBD306PDB14 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDB15 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDB2
Whirlpool RBD306PDB4
Whirlpool RBD306PDB6
Whirlpool RBD306PDB7
Whirlpool RBD306PDB8
Whirlpool RBD306PDB9
Whirlpool RBD306PDQ1
Whirlpool RBD306PDQ10
Whirlpool RBD306PDQ11
Whirlpool RBD306PDQ12
Whirlpool RBD306PDQ13
Whirlpool RBD306PDQ14 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDQ15 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDQ2
Whirlpool RBD306PDQ4
Whirlpool RBD306PDQ6
Whirlpool RBD306PDQ7
Whirlpool RBD306PDQ8
Whirlpool RBD306PDQ9
Whirlpool RBD306PDT11
Whirlpool RBD306PDT12
Whirlpool RBD306PDT13
Whirlpool RBD306PDT14 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDT15 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDZ1
Whirlpool RBD306PDZ10
Whirlpool RBD306PDZ2
Whirlpool RBD306PDZ4
Whirlpool RBD306PDZ6
Whirlpool RBD306PDZ7
Whirlpool RBD306PDZ8
Whirlpool RBD306PDZ9
Whirlpool RBD307PDB1
Whirlpool RBD307PDB2
Whirlpool RBD307PDQ1
Whirlpool RBD307PDQ2
Whirlpool RBD307PDQ4
Maytag RBE170PA  Ref - Top Mount
Maytag RBE170PW  Ref - Top Mount
Maytag RBE170TA Ref - Top Mount
Maytag RBE170TM Ref - Top Mount
Maytag RBE170TV Ref - Top Mount
Maytag RBE170TW Ref - Top Mount
Maytag RBE17KA-0A  Ref - Top Mount
Maytag RBE17KN-0A  Ref - Top Mount
Maytag RBE193PA  Ref - Top Mount
Maytag RBE193PW  Ref - Top Mount
Maytag RBE193TA Ref - Top Mount
Maytag RBE193TM Ref - Top Mount
Maytag RBE193TV Ref - Top Mount
Maytag RBE193TW Ref - Top Mount
Maytag RBE19KA-3A  Ref - Top Mount
Maytag RBE19KN-3A  Ref - Top Mount
Maytag RBE19KY-3A  Ref - Top Mount
Maytag RBE214AFM Ref - Top Mount
Maytag RBE214AFV Ref - Top Mount
Maytag RBE214RFA  Ref - Top Mount
Maytag RBE214RFV  Ref - Top Mount
Maytag RBE214TFA Ref - Top Mount
Maytag RBE214TFM Ref - Top Mount
Maytag RBE214TFV Ref - Top Mount
Maytag RBE21KA-4AF  Ref - Top Mount
Maytag RBE21KA4AF  Ref - Top Mount
Maytag RBE21KN-4AF  Ref - Top Mount
Maytag RBE21KN4AF  Ref - Top Mount
Frigidaire RBF136CL Frg(v1) / Electric Cooktop
Frigidaire RBF139CE1 Frg(v1) / Cooktop
Frigidaire RBF139CE2 Frg(v1) / Cooktop
Amana RBG322T Mwave - Cntrtp / Stand Alone
Amana RBG322T1 Mwave - Cntrtp / Stand Alone
Amana RBG358P Mwave - Cntrtp / Stand Alone
  #2 (permalink)
Old 11-07-2009, 06:18 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for WHIRLPOOL RBD305PDQ1 | AppliancePartsPros.com
I am assuming that the only way to turn it off is to trip the breaker.
Is the element on full heat?
If yes then odds are high that you need a new control board.
Either it's electronics are shot or the bake relay's contacts are welded together.
If it is on at a lower heat or only part of it is heating, it could be that it is some how shorting to the frame. Then it will get 120 volts all the time.
Sometimes this can happen through the feet of the element.
__________________
  #3 (permalink)
Old 11-07-2009, 09:14 AM
Junior Member
Default Oven won't turn off.
You are correct. It was the control panel. I decided to buy a new oven rather than spend the money for a new control panel.
Thanks!!
Quote:
Originally Posted by denman View Post
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
oven will not turn off lbrown Oven Repair (including Ranges and Cooktops) 1 03-23-2011 08:31 AM
Maytag Stove/Oven - oven will not turn off bodnarja Oven Repair (including Ranges and Cooktops) 6 11-01-2009 02:23 AM
Oven won't turn off JDMACRAE Oven Repair (including Ranges and Cooktops) 8 06-24-2009 07:56 AM
Oven won't turn off rg99 Oven Repair (including Ranges and Cooktops) 8 03-13-2009 04:11 AM
Oven won't turn off toebridge Oven Repair (including Ranges and Cooktops) 1 01-31-2009 06:03 AM
