Discuss
Oven wont ignite/no gas
 in
Hello, I have a problem with my oven. The rangetop works fine , but the oven does not light. The broiler
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven wont ignite/no gas
  #1 (permalink)
Old 02-23-2008, 10:07 AM
pavel pavel is offline
Junior Member
pavel is on a distinguished road
Default Oven wont ignite/no gas
Model Number: jgbc15ger2wh   Brand: GE   Age: 5 - 10 years
Hello, I have a problem with my oven. The rangetop works fine , but the oven does not light. The broiler does not work, or the oven. I replaced the Igniter, and it is getting 120 V from the thermostat when the thermostat is turned on. It also has continuity up to the safety valve. The problem is that the safety valve doesn't have continuity through it, even with 120 volts going into it. NO VOLTAGE COMING THROUGH THE SAFETY VALVE, i dont know why. I was wondering if anyone has any ideas on this problem.
JGBC15GER2WH
GE
5-10 YEARS
GLOWBAR IGNITION
THERMOSTAT GIVING OFF ELECTRICITY.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-28-2008, 12:42 PM
Junior Member
Default
bump, any answers?
  #3 (permalink)
Old 02-29-2008, 01:02 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Pavel,
If there is no continuity through the gas safety valve - the gas safety valve is bad and has to be replaced.
- The part number for the gas safety valve is AP2022752
__________________
Professional appliance repair in Los Angeles, California.
  #4 (permalink)
Old 02-29-2008, 06:32 PM
Junior Member
Default
When I said there is no continuity, I assumed there is no continuity because the needle is going infinitely to the left, and bouncing very very rapidly. In other words, they needle is going in the negative direction infinitely. does this change anything?
  #5 (permalink)
Old 02-29-2008, 10:28 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
If the reading across the two safety valve terminals (with at least one wire removed) is "∞" (or close to it) then the circuit is open and the safety valve has to be replaced.
__________________
  #6 (permalink)
Old 03-01-2008, 07:54 AM
Junior Member
Default
Thank you for all your help thus far. As for the last question, how sure are you that it IS the safety valve. Because I have already replaced the coil igniter which had cost 60 dollars and spending another 100 dollars for another possible problem seems iffy to me.
Is there any other way to make sure that it is the problem? When i tested the safety valve I had both wires disconnected and tested the direct line across the two connections on the safety valve.
also, where is the cheapest place I can get this part? is there such a thing as used home appliance parts flying around on the internet?
  #7 (permalink)
Old 03-02-2008, 03:10 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
If you are sure there is no continuity across the safety valve terminals then I'm sure the safety valve is bad.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
replaced igniter in dryer and wont heat up to ignite gas gordhau Dryer Repair 3 05-24-2008 10:33 AM
Burner wont ignite cocm Oven Repair (including Ranges and Cooktops) 5 02-23-2008 07:41 PM
Oven wont ignite carynlee64 Oven Repair (including Ranges and Cooktops) 2 02-22-2008 08:14 PM
Oven won't ignite under 350 holtzlou Oven Repair (including Ranges and Cooktops) 0 09-13-2007 06:39 AM
oven wont ignite mick100 Oven Repair (including Ranges and Cooktops) 3 08-27-2007 10:10 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
