Discuss
Jenn-Air wall oven - broiler weirdness
 in
Hi there, I inherited an older model Jenn-Air wall oven when I inherited my childhood home from my parents. It
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Jenn-Air wall oven - broiler weirdness
  #1 (permalink)
Old 09-24-2018, 08:15 PM
Junior Member
rentacopbc is on a distinguished road
Default Jenn-Air wall oven - broiler weirdness
Brand: Jenn-Air   Age: More than 10 years
Hi there,
I inherited an older model Jenn-Air wall oven when I inherited my childhood home from my parents. It is still in decent shape etc. However, the broiler element (top element), does not heat up when the selector dial is switched to broil no matter what temp the temperature switch is turned to. However, the really weird thing is, when I use the self cleaning function on the oven, and the selector switch is turned to 'clean' the broiler/top element comes on and stays bright red, whereas the lower/bake element does not turn on at all... or at least, not enough to turn red. What should I investigate and what do I open to do this investigation???... hehehe...
Thanks for any help!!
Rentacopbc
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Accubake Oven Weirdness (No bake or Broil) Imgoingtofixit Oven Repair (including Ranges and Cooktops) 0 02-09-2012 09:48 PM
Jenn-Air wall oven lindellmusic Oven Repair (including Ranges and Cooktops) 1 01-28-2011 03:33 AM
Jenn-air wall oven dem1969l@fast.net Oven Repair (including Ranges and Cooktops) 0 08-27-2009 10:14 AM
Wall Oven Broiler Wont work Dirk D Oven Repair (including Ranges and Cooktops) 0 08-03-2009 07:25 PM
Jenn Air Wall Electric Wall Oven WILLIAM SHIVER Oven Repair (including Ranges and Cooktops) 3 05-20-2009 12:56 AM
