Discuss
GE Profile Oven no power no lights no clock
 in
GE Profile wall oven Model JPT20BF Hope this isn't too wordy. New at the forum thing... Scenario: Someone gave me
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » GE Profile Oven no power no lights no clock
  #1 (permalink)
Old 09-20-2018, 06:51 PM
Junior Member
gastonlv is on a distinguished road
Default GE Profile Oven no power no lights no clock
Model Number: JPT20BF   Brand: GE   Age: 1 - 5 years
Scenario: Someone gave me a nice working GE Profile wall oven model JTP20
Existing Magic Chef (worked just fine) oven is hardwired along with the electric range top to (two) hots (10ga I believe) and one 10ga stranded aluminum as ground in a 100amp SUB Panel. The 400amp main panel is on the other side of the house. The sub panel is in the garage.
Problem:
1. I removed the magic chef oven to replace it with the GE Profile. I wired the ground to the ground from the feed and ignored the white neutral.
2. Before pushing it into the cabinet space I tested everything and it all worked fine. I shut off the breaker, pushed it into the wall, turned on the breaker and nothing. No lights, no clock. the range top works but absolutely no lights on the oven. No way to reset the oven (according to manual) because there are no lights.
3. Shut off the breaker for 10 minutes and tried again. Nothing. range works fine (both wired together in gang box).
4. I pulled the oven figuring I had a loose connection. All good. tested both leads are hot.
5. Tested power from the romex at the junction box and going into the oven's interior connection. There's 240 power all the way through. 120 on each leg to ground.
6. Gave up and re-installed the old magic chef oven. Turned on the breaker and now THAT oven doesn't work either!!! No lights! Nothing. The range top still works fine.
7. I find it hard to believe I burnt both controller boards but I've done worse in my life.
Last effort: I have a 240 outlet in the garage on a separate circuit. I bought a 50A plug to match, attached it to the GE profile and plugged it in. Nothing. Haven't tried the magic chef yet. Should I try connecting the white neutral to the feed ground instead of the ground?
Humbled and hoping someone can help.
Related Models
Maytag JQTC507B0 COMPACTOR
Maytag JQTC507Q0 COMPACTOR
Maytag JQTC507W0 COMPACTOR
Jenn-Air JRC5 REF - SINGLE DOOR
Jenn-Air JRC5HB REF - SINGLE DOOR
Jenn-Air JRC5HN REF - SINGLE DOOR
General Electric JRP03*06 Electric range
General Electric JRP03*07 GE BUILT-IN OVENS, CONVE
General Electric JRP03*J1 Electric range
General Electric JRP03*J2 Electric range
General Electric JRP03*J3 Electric range
General Electric JRP03*J4 Electric range
General Electric JRP03*J5 Electric range
General Electric JRP030J3 ELECTRIC BUILT-IN OVEN
General Electric JRP03G*06 Electric range
General Electric JRP03G*07 Electric range
General Electric JRP03G*H1 Electric range
General Electric JRP03G*J1 Electric range
General Electric JRP03G*J2 Electric range
General Electric JRP03G*J3 Electric range
General Electric JRP03G*J4 Electric range
General Electric JRP03G*J5 Electric range
General Electric JRP03G0J3 ELECTRIC BUILT-IN OVEN
General Electric JRP03GJ3 ELECTRIC WALL OVEN
General Electric JRP03GJ4 ELECTRIC WALL OVEN
General Electric JRP03GJ5 ELECTRIC WALL OVEN
General Electric JRP03J3 ELECTRIC 15' WALL OVEN
General Electric JRP03J4 ELECTRIC 15' WALL OVEN
General Electric JRP03J5 ELECTRIC WALL OVEN
General Electric JRP03J6 24" ELECTRIC WALL OVEN
General Electric JRP14G*06 Electric range
General Electric JRP14G*07 GE BUILT-IN OVENS, CONVE
General Electric JRP14G*H1 Electric range
General Electric JRP14G*J1 Electric range
General Electric JRP14G*J2 Electric range
General Electric JRP14G*J3 Electric range
General Electric JRP14G*J4 Electric range
General Electric JRP14G*J5 Electric range
General Electric JRP14G*J6 Electric range
General Electric JRP14G0J3 ELECTRIC BUILT-IN OVEN
General Electric JRP14GJ3 ELECTRIC WALL OVEN
General Electric JRP14GJ4 ELECTRIC WALL OVEN
General Electric JRP14GJ5 ELECTRIC WALL OVEN
General Electric JRP14GJ6 ELECTRIC WALL OVEN
General Electric JRP14GP1 Electric range
General Electric JRP14GP28G ELECTRIC WALL OVEN
General Electric JRP14GP2BG Electric range
General Electric JRP14GP3BG Electric range
General Electric JRP14GP4BG Electric range
General Electric JRP14GT1BB Electric range
General Electric JRP14GV1BB Electric range
General Electric JRP15BW1BB Electric range
General Electric JRP15BW2BB Electric range
General Electric JRP15BW3BB ELECTRIC OVEN
General Electric JRP15BW5BB Electric range
General Electric JRP15BW6BB Electric range
General Electric JRP15WP1 Electric range
General Electric JRP15WP1WG ELECTRIC WALL OVEN
General Electric JRP15WP2WG Electric range
General Electric JRP15WP3WG Electric range
General Electric JRP15WT1WW Electric range
General Electric JRP15WV1WW Electric range
General Electric JRP15WW1WW Electric range
General Electric JRP15WW2WW Electric range
General Electric JRP15WW3WW ELECTRIC OVEN
General Electric JRP15WW5WW Electric range
General Electric JRP15WW6WW Electric range
General Electric JRP20BJ1BB Electric range
General Electric JRP20SK1SS Electric range
General Electric JRP20WJ1WW Electric range
General Electric JRP24BD1BB Electric range
General Electric JRP24BD2BB Electric range
General Electric JRP24BW1BB Electric range
General Electric JRP24BW2BB Electric range
General Electric JRP24BW3BB ELECTRIC WALL OVEN
General Electric JRP24BW5BB Electric range
General Electric JRP24GP1 Electric range
General Electric JRP24GP2BG Electric range
General Electric JRP24GP3BG Electric range
General Electric JRP24GP4BG Electric range
General Electric JRP24GT1BB Electric range
General Electric JRP24GV1BB Electric range
General Electric JRP28BJ1BB Electric range
General Electric JRP28SK1SS Electric range
General Electric JRS04BW1BB Electric range
General Electric JRS04BW2BB Electric range
General Electric JRS04BW3BB Electric range
General Electric JRS04BW4BB Electric range
General Electric JRS04BW5BB Electric range
General Electric JRS04BW6BB Electric range
General Electric JRS04GP1 Electric range
General Electric JRS04GP2BG Electric range
General Electric JRS04GT1BB Electric range
General Electric JRS04GV1BB Electric range
General Electric JRS06BJ1BB Electric range
General Electric JRS06SK1SS Electric range
Jenn-Air JRS1202W REF - SXS
Jenn-Air JRS202 REF - SXS
Jenn-Air JRS202B REF - SXS
Jenn-Air JRS202H REF - SXS
Jenn-Air JRS202L REF - SXS
Jenn-Air JRS202N REF - SXS
Jenn-Air JRS202W REF - SXS
Jenn-Air JRS203 REF - SXS
Jenn-Air JRS203-AQ01B JENN-AIR REFRIGERATION
Jenn-Air JRS203-BQ01A JENN-AIR REFRIGERATION
Jenn-Air JRS203B Ref - Sxs
Jenn-Air JRS205L REF - SXS
Jenn-Air JRS205W REF - SXS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Profile Oven- Control Panel Has no lights mbaumser Oven Repair (including Ranges and Cooktops) 2 09-13-2017 02:46 PM
GE Profile Model P2S975SEM2SS Slide-In Range Temporarily Loses Power When Oven Used Bilgemaster Oven Repair (including Ranges and Cooktops) 2 12-08-2013 09:14 PM
Kenmore Range - no oven - no error - clock, lights & range ok jfilanoski Oven Repair (including Ranges and Cooktops) 1 04-29-2011 02:51 AM
GE Profile beeping/no lights after power outage mmasut Dishwasher Repair 0 07-17-2010 02:35 PM
Oven buzzing, no lights or clock biltmore_shores Oven Repair (including Ranges and Cooktops) 1 11-12-2008 05:22 AM
