| » oven won't heat below 450. |
Model Number: B500j0d1ad Brand: GE Age: More than 10 years
I was using my oven earlier and I noticed that the heating element was not staying on. I turned my oven up to 450 F and it came back on. Now the element won't turn on unless the degree is 450 F or higher. Does anyone have any ideas what might be causing the problem or how it can be fixed?
Cannot find any info on the given model number.
The unit may think that it already at a high temperature. Check the oven sensor (se below) for resistance. Also check that the sensor connector are clean and not corroded. Here is a good link http://www.applianceaid.com/elecrange.html Check out 7, 8 and 21 If OK odds are high that the control is gone
__________________
| Display Modes | |
| Wall oven will not heat/re-heat properly | dottavio | Oven Repair (including Ranges and Cooktops) | 0 | 01-07-2010 09:47 AM |
| Oven/clock Control Panel is no longer lit but oven does heat. | jthomas@abrakadoodle.com | Oven Repair (including Ranges and Cooktops) | 1 | 12-05-2009 04:07 PM |
| Oven broiler and burners work - oven will not heat | fatbuford | Oven Repair (including Ranges and Cooktops) | 0 | 11-27-2009 05:50 AM |
| Caloric double oven/bottom oven doesn't heat | kj0505 | Oven Repair (including Ranges and Cooktops) | 1 | 12-10-2008 09:14 AM |
| Bosch 27" Dbl oven Powering on but no heat either oven | badace | Oven Repair (including Ranges and Cooktops) | 0 | 12-02-2007 09:56 AM |
