Discuss
Ignitor Burn Out
 in
The ignitor in the lower oven had burn't out so replaced it. Didn't see the hole burned into the deflection
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Ignitor Burn Out
  #1 (permalink)
Old 08-28-2018, 11:55 AM
Junior Member
Neb L is on a distinguished road
Default Ignitor Burn Out
Model Number: CGS990SET8SS   Brand: GE   Age: 1 - 5 years
The ignitor in the lower oven had burn't out so replaced it. Didn't see the hole burned into the deflection plate ( old style without cut out above ignitor). Started up the oven and had an arc flash when the ignitor shorted out on the metal that dripped from the heat deflector. Put in a new ignitor and deflection plate and now no power to the ignitor. Is there something else in the circuit that may have blown ?
Related Models
Whirlpool CGT8000XQ0 COMMERCIAL STACKED GAS DRYER/WASHER
Whirlpool CGW2761AN0 COMMERCIAL GAS DRYER
Whirlpool CGW2761AN1 COMMERCIAL GAS DRYER
Whirlpool CGW2761AW0 COMMERCIAL GAS DRYER
Whirlpool CGW2761AW1 COMMERCIAL GAS DRYER
Whirlpool CGW2761EW0 DRYERS
Whirlpool CGW2791EW0 DRYERS
Crosley CGW2D2 RANGE- F/S STD GAS
Crosley CGW2D21 RANGE- F/S STD GAS
Crosley CGW2D2K RANGE- F/S STD GAS
Crosley CGW2D2K-1 RANGE- F/S STD GAS
Magic Chef CGW3330ADB WALLOVEN- S/C GAS
Magic Chef CGW3330ADW WALLOVEN- S/C GAS
Crosley CGW3C6CLVK RANGE-F/S CONT CLEAN GAS
Crosley CGW3D1 RANGE- F/S STD GAS
Crosley CGW3D1K RANGE- F/S STD GAS
Crosley CGW3D1X RANGE- F/S STD GAS
Crosley CGW3D3WK RANGE- F/S STD GAS
Crosley CGW3D3X RANGE- F/S STD GAS
Crosley CGW3D5VK RANGE- F/S STD GAS
Crosley CGW3D5WK RANGE- F/S STD GAS
Crosley CGW3D5XK RANGE- F/S STD GAS
Crosley CGW3D6CLVK RANGE-F/S CONT CLEAN GAS
Crosley CGW3D6CSVK RANGE- F/S STD GAS
Crosley CGW3D6CSVK-1 RANGE- F/S STD GAS
Crosley CGW3D6CVK RANGE- F/S STD GAS
Crosley CGW4C58CZKW RANGE- S/C F/S GAS
Crosley CGW4D59EZK RANGE- S/C F/S GAS
Crosley CGW4D59TSK-1 RANGE- S/C F/S GAS
Crosley CGW4D59TSZK RANGE- S/C F/S GAS
Crosley CGW4D59TZK RANGE- S/C F/S GAS
Crosley CGW6C5GWK RANGE- F/S STD GAS
Crosley CGW6C5W RANGE- F/S STD GAS
Crosley CGW6C5WK RANGE- F/S STD GAS
Whirlpool CGW9100VQ0 COMMERCIAL GAS DRYER
Whirlpool CGW9100WQ0 COMMERCIAL GAS DRYER
Roper CGX215VX0 GAS COOKTOP
Roper CGX215VX1 GAS COOKTOP
Thermador CGX304UB
Thermador CGX304US
Thermador CGX304UW
Roper CGX310VW0 GAS COOKTOP
Roper CGX310VW1 GAS COOKTOP
Roper CGX315VW0 GAS COOKTOP
Roper CGX315VW1 GAS COOKTOP
Thermador CGX365UB
Thermador CGX365US
Thermador CGX365UW
Thermador CGX456UB
Thermador CGX456US
Thermador CGX456UW
Roper CGX635VW0 Ranges, Electric*
Roper CGX655VW0 GAS COOKTOP
Amana CH105 COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CH105T COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CH125 COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CH125T COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CH150 COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CH150T COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CH170 COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CH170T COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Thermador CH30 CERAMIC COOKTOP
Thermador CH36 CERAMIC COOKTOP
Hardwick CH4-34A9 SURFACE UNIT- GAS
Hardwick CH4-34W9 SURFACE UNIT- GAS
Hardwick CH4-44A9 SURFACE UNIT- GAS
Hardwick CH4-44W9 SURFACE UNIT- GAS
Amana CH68 COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CH68T COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Hardwick CH7241819R WALLOVEN- CONT CLEAN GAS
Hardwick CH9616A79R RANGE- F/S STD GAS
Hardwick CH9616W79R RANGE- F/S STD GAS
Hardwick CH9626A79R RANGE- F/S STD GAS
Hardwick CH9626W79R RANGE- F/S STD GAS
Whirlpool CHA1300W0 Commercial Washers
Whirlpool CHCS51AE1 Freestanding Icemaker
Thermador CHCV30 CERAMIC COOKTOP
Thermador CHCV36 CERAMIC COOKTOP
Maytag CHE9000ACB RANGE- S/C S/I ELE
Maytag CHE9000BCB RANGE- S/C S/I ELE
Maytag CHE9000BCE RANGE- S/C S/I ELE
Maytag CHE9800ACB RANGE- S/C S/I ELE
Maytag CHE9800ACE RANGE- S/C S/I ELE
Maytag CHE9800BCB RANGE- S/C S/I ELE
Maytag CHE9800BCE RANGE- S/C S/I ELE
Maytag CHE9800BCM RANGE- S/C S/I ELE
Maytag CHE9830BCB RANGE- S/C S/I ELE
Maytag CHE9830BCE RANGE- S/C S/I ELE
Admiral CHEA700BCB RANGE- S/C S/I ELE
Admiral CHEA700BCE RANGE- S/C S/I ELE
Maytag CHG9800AAB RANGE- S/C S/I GAS
Maytag CHG9800AAE RANGE- S/C S/I GAS
Maytag CHG9800BAB RANGE- S/C S/I GAS
Maytag CHG9800BAE RANGE- S/C S/I GAS
Maytag CHG9800BAM RANGE- S/C S/I GAS
Maytag CHG9830BAB RANGE- S/C S/I GAS
Maytag CHG9830BAE RANGE- S/C S/I GAS
Admiral CHGA400BAB RANGE- S/C S/I GAS
Admiral CHGA400BAE RANGE- S/C S/I GAS
Amana CHP105 COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CHP105T COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CHP125 COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CHP125T COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CHP150 COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CHP150T COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CHP170 COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CHP170T COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CHP68 COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CHP68T COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Whirlpool CHW8990XW0 COMMERCIAL AUTOMATIC WASHER
Whirlpool CHW9900VQ0 COMMERCIAL AUTOMATIC WASHER
Whirlpool CHW9900VQ1 COMMERCIAL AUTOMATIC WASHER
Whirlpool CHW9900WQ0 COMMERCIAL AUTOMATIC WASHER
Amana CI7.7 FREEZER- CHEST
Amana CI8.8 FREEZER- CHEST
Amana CI8.8-C FREEZER- CHEST
Amana CIC-3 REF - TOP MOUNT
Amana CIC-4H REF - TOP MOUNT
Amana CIC3 MISC / ACCESSORY
  #2 (permalink)
Old 08-28-2018, 04:52 PM
ohm ohm is offline
Senior Member
ohm is on a distinguished road
Default
Would check out the lower oven gas valve with a ohmmeter for continuity.
Here is a service manual that may help.https://drive.google.com/file/d/0B-i...ew?usp=sharing
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Burn signs kimwipes Dishwasher Repair 0 04-16-2017 08:05 PM
burn gas igniter ti_jean1963 Oven Repair (including Ranges and Cooktops) 0 05-20-2015 09:55 PM
burn on SteveUdell Oven Repair (including Ranges and Cooktops) 0 02-03-2010 09:00 PM
Burners burn too low. Glen E. Helmuth Oven Repair (including Ranges and Cooktops) 0 02-03-2010 10:22 AM
Fuse burn out robertiogawa Washer Repair 1 01-27-2008 12:07 PM
