Can you tell me how to install a new burner ignition head? I have the part but is it held in place by something under the cooktop? If so, how do I get to the part that holds the ignition in place? The ignition works, however, it doesn't seal properly or hold tightly in place as do the other 3 ignition heads.
Thanks!
