Discuss
OVen doesn’t reach temperature
 in
Hi. Hope to find some help. Oven slow to heat on bake. Set at 350 and gets to about 315
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » OVen doesn’t reach temperature
  #1 (permalink)
Old 07-11-2018, 07:39 PM
Junior Member
Jim11787 is on a distinguished road
Default OVen doesn’t reach temperature
Model Number: WOS-130SS   Brand: -other-   Age: More than 10 years
Hi. Hope to find some help. Oven slow to heat on bake. Set at 350 and gets to about 315 after more than 30 minutes but does not reach 350. I checked resistance in the preheat and bake coil and they are about 30 ohms so I assume they are good. No evidence of blisters or cracks. During preheat the preheat coil heats up and the broil element cycles on and off as I see visually and hear clicking relays. It only is on for a few seconds at a time. The bake coil does not get warm at all. I’m thinking that the control board is not sending a signal to the bake element. How do I determine if this is the cause and can someone identify what the replacement part is called and part number? Would this be called “EOC Single” and be DCS PN 211708? I would like to verify that the board is the problem before purchasing it. I appreciate any help. Thanks in advance.
Related Models
General Electric WP71X23 Zoneline
General Electric WP71X26 Zoneline
General Electric WP71X4 Zoneline
General Electric WPDH8800J0MG WASHER
General Electric WPDH8800J0MV WASHER
General Electric WPDH8800J0WW WASHER
General Electric WPDH8800J1MG WASHER
General Electric WPDH8800J1MV WASHER
General Electric WPDH8800J1WW WASHER
General Electric WPDH8800J2MG WASHER
General Electric WPDH8800J2MV WASHER
General Electric WPDH8800J2WW WASHER
General Electric WPDH8800J3MG WASHER
General Electric WPDH8800J3MV WASHER
General Electric WPDH8800J3WW WASHER
General Electric WPDH8850J0MG WASHER
General Electric WPDH8850J0MV WASHER
General Electric WPDH8850J0WW WASHER
General Electric WPDH8850J1MG WASHER
General Electric WPDH8850J1MV WASHER
General Electric WPDH8850J1WW WASHER
General Electric WPDH8850J2MG WASHER
General Electric WPDH8850J2MV WASHER
General Electric WPDH8850J2WW WASHER
General Electric WPDH8850J3MG WASHER
General Electric WPDH8850J3MV WASHER
General Electric WPDH8850J3WW WASHER
General Electric WPDH8850J4MG WASHER
General Electric WPDH8850J4MV WASHER
General Electric WPDH8850J4WW WASHER
General Electric WPDH8900J0MG WASHER
General Electric WPDH8900J0MV WASHER
General Electric WPDH8900J0WW WASHER
General Electric WPDH8900J1MG WASHER
General Electric WPDH8900J1MV WASHER
General Electric WPDH8900J1WW WASHER
General Electric WPDH8900J2MG WASHER
General Electric WPDH8900J2MV WASHER
General Electric WPDH8900J2WW WASHER
General Electric WPDH8900J3MG WASHER
General Electric WPDH8900J3MV WASHER
General Electric WPDH8900J3WW WASHER
General Electric WPDH8900J4MG WASHER
General Electric WPDH8900J4MV WASHER
General Electric WPDH8900J4WW WASHER
General Electric WPDH8910K0MG WASHER
General Electric WPDH8910K0MV WASHER
General Electric WPDH8910K0WW WASHER
General Electric WPDH8910K1MG WASHER
General Electric WPDH8910K1MV WASHER
General Electric WPDH8910K1WW WASHER
General Electric WPGT9150H0MG WASHER
General Electric WPGT9150H0WW WASHER
General Electric WPGT9350C0PL Washer
General Electric WPGT9350C0WW Washer
General Electric WPGT9360C0PL Washer
General Electric WPGT9360C0WW Washer
General Electric WPGT9360E0PL Washer
General Electric WPGT9360E0WW Washer
General Electric WPRB8050D0CC Washer
General Electric WPRB8050D0WW Washer
General Electric WPRB8050D1CC Washer
General Electric WPRB8050D1WW Washer
General Electric WPRB8350H0WT WASHER
General Electric WPRB9110D0CC Washer
General Electric WPRB9110D0WW Washer
General Electric WPRB9110D1CC Washer
General Electric WPRB9110D1WW Washer
General Electric WPRB9220C0CC Washer
General Electric WPRB9220C0WW Washer
General Electric WPRB9220C1CC Washer
General Electric WPRB9220C1WW Washer
General Electric WPRB9220D0CC Washer
General Electric WPRB9220D0WW Washer
General Electric WPRB9220D1CC Washer
General Electric WPRB9220D1WW Washer
General Electric WPRB9220DCCC Washer
General Electric WPRB9220DCWW Washer
General Electric WPRB9250C0CC Washer
General Electric WPRB9250C0WW Washer
General Electric WPRB9250D0CC Washer
General Electric WPRB9250D0WW Washer
General Electric WPRB9250D1CC Washer
General Electric WPRB9250D1WW Washer
General Electric WPRE5240D1WW Washer
General Electric WPRE6100G0WT Washer
General Electric WPRE6100G1WT WASHER
General Electric WPRE6100G2WT WASHER
General Electric WPRE6100G3WT WASHER
General Electric WPRE6150H0WT WASHER
General Electric WPRE6150H1WT WASHER
General Electric WPRE6150H2WT WASHER
General Electric WPRE6150K0WT WASHER
General Electric WPRE6150K1WT WASHER
General Electric WPRE6150K2WT WASHER
General Electric WPRE6150K3WT WASHER
General Electric WPRE6280D1WW Washer
General Electric WPRE6280DCWW Washer
General Electric WPRE8100G0WT Washer
General Electric WPRE8100G1WT WASHER
General Electric WPRE8150H0WT WASHER
General Electric WPRE8150H1WT WASHER
General Electric WPRE8150H2WT WASHER
General Electric WPRE8150K0WT WASHER
General Electric WPRE8150K1WT WASHER
General Electric WPRE8150K2WT WASHER
General Electric WPRE8150K3WT WASHER
General Electric WPRE8320H2WT WASHER
General Electric WPRE8320H3WT WASHER
General Electric WPRE8350H0WT WASHER
General Electric WPRE8350H1WT WASHER
General Electric WPRE8350H2WT WASHER
General Electric WPSB8060B0CC Washer
General Electric WPSB8060B0WW Washer
General Electric WPSB8060B1CC Washer
General Electric WPSB8060B1WW Washer
General Electric WPSB8060B9CC Washer
General Electric WPSB8060B9WW Washer
General Electric WPSB9080B0CC Washer
General Electric WPSB9080B0WW Washer
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven doesn't reach temperature figgies5 Oven Repair (including Ranges and Cooktops) 0 07-11-2015 12:29 PM
GE Oven Doesn't Reach Set Temperature cwtowne3 Oven Repair (including Ranges and Cooktops) 0 04-08-2015 07:24 AM
Oven won't reach temperature tcfroman Oven Repair (including Ranges and Cooktops) 0 10-10-2010 09:11 AM
Oven does not reach set temperature dcmjcook Oven Repair (including Ranges and Cooktops) 0 03-07-2010 05:23 AM
Oven won't reach temperature bbatt Oven Repair (including Ranges and Cooktops) 0 12-05-2008 12:20 PM
