Discuss
oven not heating
 in
set temp to bake 350\\ top element heats (185) no heat on bottom element 110volts to each leg of bottom
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » oven not heating
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 07-11-2018, 12:22 PM
Junior Member
deanowhitney is on a distinguished road
Default oven not heating
Model Number: WW30110   Brand: Jenn-Air   Age: More than 10 years
110volts to each leg of bottom element
Full continuity on bottom when pwr off- no resistance
Set upper element leads to bottom element-pwr on - red hot 220volts across terminals
Pwr from L1 -> upper element and lower element (OK)
Pwr from L2 -> control switch of bake element and AUX (OK)
control switch E7 sends current to Upper element E6 sends current to lower element
With oven turned on to bake, I get a reading across Upper element terminals of 220v and the lower element nothing across the two terminals, but 110v from each to ground.
Yellow wire from switch E6 to Lower element
Purple wire from switch E7 to Upper element
Can't figure why the bottom element only gets 110V on each terminal when should be 220V
Related Models
Jenn-Air WW30110B WALLOVEN- S/C ELE
Jenn-Air WW30110W WALLOVEN- S/C ELE
Jenn-Air WW30430B WALLOVEN- S/C ELE
Jenn-Air WW30430P WALLOVEN- S/C ELE
Jenn-Air WW30430PC WALLOVEN- S/C ELE
Jenn-Air WW30430PF WALLOVEN- S/C ELE
Jenn-Air WW30430PG WALLOVEN- S/C ELE
Jenn-Air WW30430PK WALLOVEN- S/C ELE
Jenn-Air WW30430PR WALLOVEN- S/C ELE
Jenn-Air WW30430PU WALLOVEN- S/C ELE
Jenn-Air WW30430W WALLOVEN- S/C ELE
Frigidaire WW334AGW0 Wwh(v1) / Washer
Frigidaire WW334AGW1 Wwh(v2) / Washer
Frigidaire WW334AGW2 Wwh(v3) / Washer
 WW600 MWAVE- CNTRTP / STAND ALONE
General Electric WW8318LAL AUTOMATIC WASHER
General Electric WWA3100BAL Washer
General Electric WWA3100GAL Washer
General Electric WWA3100GBL Washer
General Electric WWA3100VCL Washer
General Electric WWA3650MAL Washer
General Electric WWA3650RBL Washer
General Electric WWA3650SALAD Washer
General Electric WWA3650SALHA Washer
General Electric WWA3650SALWH Washer
General Electric WWA3657SALHA Washer
General Electric WWA3657SALWH Washer
General Electric WWA5009VCL Washer
General Electric WWA5304VNL Washer
General Electric WWA5304VPL Washer
General Electric WWA5400SALWH Washer
General Electric WWA5400SBLWH Washer
General Electric WWA5407MAL Washer
General Electric WWA5411BAL Washer
General Electric WWA5411GAL Washer
General Electric WWA5411VEL Washer
General Electric WWA5412BAL Washer
General Electric WWA5412GAL Washer
General Electric WWA5412VEL Washer
General Electric WWA5509VCL Washer
General Electric WWA5600BAL Washer
General Electric WWA5600GAL Washer
General Electric WWA5600GBL Washer
General Electric WWA5600RBL Washer
General Electric WWA5600SALAA Washer
General Electric WWA5600SALHA Washer
General Electric WWA5600SALWW Washer
General Electric WWA5600SBLAA Washer
General Electric WWA5600SBLWW Washer
General Electric WWA5600VCL Washer
General Electric WWA5610BAL Washer
General Electric WWA5636MAL Washer
General Electric WWA5669MAL Washer
General Electric WWA5669MBL Washer
General Electric WWA5710MAL Washer
General Electric WWA5710RBL Washer
General Electric WWA5710SALAA Washer
General Electric WWA5710SALWW Washer
General Electric WWA5710SBLAA Washer
General Electric WWA5710SBLWW Washer
General Electric WWA5800BAL Washer
General Electric WWA5800GAL Washer
General Electric WWA5800GBL Washer
General Electric WWA5800MAL Washer
General Electric WWA5800RBL Washer
General Electric WWA5800VCL Washer
General Electric WWA5809RBL Washer
General Electric WWA5826MAL Washer
General Electric WWA5826RBL Washer
General Electric WWA5857RBL Washer
General Electric WWA6007MAL Washer
General Electric WWA6407LBL Washer
General Electric WWA6600MAL Washer
General Electric WWA6600RBL Washer
General Electric WWA6600SALAA Washer
General Electric WWA6600SALWW Washer
General Electric WWA6600SBLAA Washer
General Electric WWA6600SBLWW Washer
General Electric WWA6800SALAD Washer
General Electric WWA6800SALHA Washer
General Electric WWA6800SALWH Washer
General Electric WWA7010GAL Washer
General Electric WWA7010GBL Washer
General Electric WWA7050BAL Washer
General Electric WWA7050GAL Washer
General Electric WWA7050GBL Washer
General Electric WWA7059VCL Washer
General Electric WWA7060VCL Washer
General Electric WWA7070BAL Washer
General Electric WWA7070GAL Washer
General Electric WWA7070GBL Washer
General Electric WWA7070VCL Washer
General Electric WWA7079VCL Washer
General Electric WWA7304PML Washer
General Electric WWA7304VKL Washer
General Electric WWA7304VLL Washer
General Electric WWA7600RBL Washer
General Electric WWA7600SALAA Washer
General Electric WWA7600SALWW Washer
General Electric WWA7600SBLAA Washer
General Electric WWA7600SBLWW Washer
General Electric WWA7619MAL Washer
General Electric WWA7640SALAA Washer
General Electric WWA7640SALWW Washer
General Electric WWA7640SBLAA Washer
General Electric WWA7640SBLWW Washer
General Electric WWA7646MAL Washer
General Electric WWA7650SALAA Washer
General Electric WWA7650SALWW Washer
General Electric WWA7650SBLAA Washer
General Electric WWA7650SBLWW Washer
General Electric WWA7678MAL Washer
General Electric WWA7680SALAA Washer
General Electric WWA7680SALWW Washer
General Electric WWA7680SBLAA Washer
General Electric WWA7680SBLWW Washer
General Electric WWA7690SALAA Washer
General Electric WWA7690SALWW Washer
General Electric WWA7690SBLAA Washer
General Electric WWA7690SBLWW Washer
  #2 (permalink)
Old 07-25-2018, 09:49 AM
Member
CarolynE is on a distinguished road
Default
thermosensor?
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool electric double oven (15 months old) lower oven is heating way to high Karenjohnson Oven Repair (including Ranges and Cooktops) 0 02-16-2018 05:15 PM
Frigidaire Double Oven - Lower Oven not heating - Clicking RentAHubby Oven Repair (including Ranges and Cooktops) 12 11-10-2017 03:22 PM
gas oven & display panel turns off when heating oven, recovers when cool Byrdson Oven Repair (including Ranges and Cooktops) 1 02-07-2017 12:03 PM
Oven not heating same time separate micro hood not heating as well? helocat Oven Repair (including Ranges and Cooktops) 0 07-28-2013 09:18 PM
Bottom heating element in oven not heating Bill Pitts Oven Repair (including Ranges and Cooktops) 1 03-07-2009 06:02 PM
