Discuss
Infinity Switch does note work and No model number for stove top)
 in
I have had problems with the infinity switch for the Whirlpool 8 inch element for a while ( not shutting
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Infinity Switch does note work and No model number for stove top)
  #1 (permalink)
Old 07-03-2018, 07:29 PM
Junior Member
rendellwatson is on a distinguished road
Default Infinity Switch does note work and No model number for stove top)
Model Number: Not on Appliance   Brand: Whirlpool   Age: More than 10 years
I have had problems with the infinity switch for the Whirlpool 8 inch element for a while ( not shutting off) and now the switch does not work. I want to replace the switch but there is no model number on the underside of the Whirlpool stovetop and no part # on the switch. there are numbers on the switch but they dont correspond to part numbers online. Stove top is over 30 years old. If i remove the switch, do you have any suggestions on how to find a new switch that will work. thanks
Related Models
Admiral NR460 REF - SINGLE DOOR
Admiral NR460A REF - SINGLE DOOR
Admiral NR460H REF - SINGLE DOOR
Admiral NR530 REF - SINGLE DOOR
Admiral NR530A REF - SINGLE DOOR
Admiral NR530H REF - SINGLE DOOR
Admiral NR580 REF - SINGLE DOOR
Admiral NR580A REF - SINGLE DOOR
Admiral NR580H REF - SINGLE DOOR
Admiral NR640 REF - SINGLE DOOR
Admiral NR640A REF - SINGLE DOOR
Maytag NS207MA REF - SXS
Maytag NS207MW REF - SXS
Maytag NS207NA REF - SXS
Maytag NS207NW REF - SXS
Maytag NS207PA REF - SXS
Maytag NS207PW REF - SXS
Maytag NS208MA REF - SXS
Maytag NS208MW REF - SXS
Maytag NS208NA REF - SXS
Maytag NS208NW REF - SXS
Admiral NS20F7 REF - SXS
Admiral NS20F7A REF - SXS
Admiral NS20F7H REF - SXS
Admiral NS20F8 REF - SXS
Admiral NS20F8A REF - SXS
Admiral NS20F8H REF - SXS
Admiral NS20H7 REF - SXS
Admiral NS20H7A REF - SXS
Admiral NS20H7H REF - SXS
Admiral NS20H8 REF - SXS
Admiral NS20H8A REF - SXS
Admiral NS20H8H REF - SXS
Admiral NS20JX REF - SXS
Admiral NS20JXA REF - SXS
Admiral NS20JXH REF - SXS
Admiral NS20L7 REF - SXS
Admiral NS20L7A REF - SXS
Admiral NS20L7H REF - SXS
Maytag NS229NA REF - SXS
Maytag NS229NW REF - SXS
Admiral NS22F8 REF - SXS
Admiral NS22F8A REF - SXS
Admiral NS22F8H REF - SXS
Admiral NS22H7 REF - SXS
Admiral NS22H7A REF - SXS
Admiral NS22H7H REF - SXS
Admiral NS22H8 REF - SXS
Admiral NS22H8A REF - SXS
Admiral NS22H8H REF - SXS
Admiral NS22HP8 REF - SXS
Admiral NS22HP8A REF - SXS
Admiral NS22HP8H REF - SXS
Admiral NS22L8 REF - SXS
Admiral NS22L8A REF - SXS
Admiral NS24F8 REF - SXS
Admiral NS24F8A REF - SXS
Admiral NS24F8H REF - SXS
Admiral NS24H8 REF - SXS
Admiral NS24H8A REF - SXS
Admiral NS24H8H REF - SXS
Maytag NT153MA REF - TOP MOUNT
Maytag NT153MW REF - TOP MOUNT
Maytag NT153NA REF - TOP MOUNT
Maytag NT153NW REF - TOP MOUNT
Maytag NT155MA REF - TOP MOUNT
Maytag NT155MW REF - TOP MOUNT
Maytag NT156MW REF - TOP MOUNT
Maytag NT156NW REF - TOP MOUNT
Maytag NT156PW REF - TOP MOUNT
Admiral NT15A5V REF - TOP MOUNT
Admiral NT15A5VA REF - TOP MOUNT
Admiral NT15A5VH REF - TOP MOUNT
  #2 (permalink)
Old 07-04-2018, 12:49 AM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
Is there another 8" burner on the range? It might have the correct number on it.
If possible post a pic. of the switch and any markings on it.
  #3 (permalink)
Old 07-07-2018, 02:26 PM
Junior Member
Default
was able to find part # for switch. thanks. Does it make sense that a switch could still have continuity ( which is happening) but the switch does not work because the shaft is too loose ( very easy to turn compared to other switiches that work). Also, the switch was not turning off properly before it stopped working which i thought was a good sign that the switch is broken.
THank you
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire Stove Burner Gets too hot, replaced infinity switch questionforyouguys Oven Repair (including Ranges and Cooktops) 0 07-11-2016 02:37 PM
Cannot find model number for old magic chef chateau stove/oven myob Oven Repair (including Ranges and Cooktops) 2 01-17-2015 04:49 PM
Kenmore Washer Lid Switch - model number on replacement rubbed out duplex Washer Repair 1 05-09-2013 03:28 PM
amana model number: SZDE25MBW Serial Number: P1121202WW stop cooling and got hot dustnag966 Refrigerator & Freezer Repair 3 03-01-2013 02:40 PM
GE Profile Slide in Stove Model Number.... cs-john Oven Repair (including Ranges and Cooktops) 0 01-07-2013 04:03 PM
