Discuss
Odd stove element mystery
 in
I have a glass top GE range. I replaced the two front burners because the outer ring elements did not
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Odd stove element mystery
  #1 (permalink)
Old 06-30-2018, 03:19 PM
Junior Member
daveydad is on a distinguished road
Default Odd stove element mystery
Brand: GE   Age: 5 - 10 years
I have a glass top GE range. I replaced the two front burners because the outer ring elements did not work most of the time. After replacing them, the smaller burner inner element would not come on, only the outer ring. But I noticed when I turned on the large burner to the right of this one, the inner element then came on! I guess these are both somehow wired together...? Once it came on that first time, then it worked fine until I let it sit for a while. Any ideas for this??
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Stove elements keep getting bent-- mystery asvueldo Oven Repair (including Ranges and Cooktops) 0 12-05-2012 07:14 AM
Stove Element for ollder Kenmore compact 24" wide oven/stove johnnyslade Oven Repair (including Ranges and Cooktops) 2 04-26-2012 04:46 AM
oven element/broiler element not working stove top is MD110772 Oven Repair (including Ranges and Cooktops) 3 07-05-2011 01:23 AM
Stove Baking Element tommurrell Oven Repair (including Ranges and Cooktops) 0 07-30-2009 02:45 PM
kenmore stove element calgarian Oven Repair (including Ranges and Cooktops) 1 10-08-2007 11:06 AM
