Discuss
I replaced the hinges and now the door won"t close.
 in
I replaced the stove hinges and now the door will not close. Its about 2 to 2 inches from closing
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » I replaced the hinges and now the door won"t close.
  #1 (permalink)
Old 11-05-2009, 05:47 PM
david4031 david4031 is offline
Junior Member
david4031 is on a distinguished road
Default I replaced the hinges and now the door won"t close.
Model Number: svd48600p   Brand: Jenn-Air   Age: 5 - 10 years
I replaced the stove hinges and now the door will not close. Its about 2 to 2 inches from closing at the top of the door. I looked at the hinge receptacles and there seam to be nothing wrong with them (nothing bent or misshaped). I call the store where I got the hinges and they said the its unlikely to be the receptacles. I'm not sure what to do next????
Related Models
Jenn-Air SVD48600P Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600PC Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600PF Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600PG Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600PK Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600PR Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600PT Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600PU Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600W Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600WC Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310S Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310S-C Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SD Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SF Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SG Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SK Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SR Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SU Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVE47100B Range - S/c S/i Ddraft Ele
Jenn-Air SVE47100BC Range - S/c S/i Ddraft Ele
Jenn-Air SVE47100W Range - S/c S/i Ddraft Ele
Jenn-Air SVE47100WC Range - S/c S/i Ddraft Ele
Jenn-Air SVE47500B Range - S/c S/i Ddraft Ele
Jenn-Air SVE47500W Range - S/c S/i Ddraft Ele
Jenn-Air SVE47600B Range - S/c S/i Ddraft Ele
Jenn-Air SVE47600BC Range - S/c S/i Ddraft Ele
Jenn-Air SVE47600W Range - S/c S/i Ddraft Ele
Jenn-Air SVE47600WC Range - S/c S/i Ddraft Ele
Jenn-Air SVE87600B Range - S/c S/i Ddraft Ele
Jenn-Air SVE87600W Range - S/c S/i Ddraft Ele
Whirlpool SVF100W0
Whirlpool SVF100W1
Whirlpool SVF12FRHW00
Whirlpool SVF15NRHW00
Whirlpool SVF15NRHW01
Whirlpool SVF15NRHW02
Whirlpool SVF15NRJW00
Whirlpool SVF20NRKQ00
Whirlpool SVF60W0
Whirlpool SVF60W1
Whirlpool SVF70W0
Whirlpool SVF70W1
Whirlpool SVF75W0
Whirlpool SVF75W1
Whirlpool SVF75W2
Whirlpool SVF80W0
Whirlpool SVF80W1
Whirlpool SVF90W0
Whirlpool SVF90W1
Whirlpool SVP100W0
Whirlpool SVP50W0
Whirlpool SVP60W0
Whirlpool SVP60W1
Whirlpool SVP70W0
Whirlpool SVP75W0
Whirlpool SVP80W0
Whirlpool SVP90W0
Whirlpool SVU100W0
Whirlpool SVU100W1
Whirlpool SVU100W2
Whirlpool SVU60W0
Whirlpool SVU60W1
Whirlpool SVU60W2
Whirlpool SVU70W0
Whirlpool SVU70W1
Whirlpool SVU70W2
Whirlpool SVU80W0
Whirlpool SVU80W1
Whirlpool SVU80W2
Whirlpool SVU90W0
Whirlpool SVU90W1
Whirlpool SVU90W2
Amana SW22H Ref - SXS/I&W
Amana SW22MBG Ref - SXS/I&W
Amana SW22MBL Ref - SXS/I&W
Amana SW22MBW Ref - SXS/I&W
Amana SW25H Ref - SXS/I&W
Amana SWDT22H Ref - SXS/I&W
Amana SWDT25H Ref - SXS/I&W
Whirlpool SWF100W0
Whirlpool SWF100W2
Whirlpool SWF60W0
Whirlpool SWF60W2
Whirlpool SWF70W0
Whirlpool SWF70W2
Whirlpool SWF80W0
Whirlpool SWF80W2
Whirlpool SWF80W8
Whirlpool SWF80W9
Whirlpool SWF90W0
Whirlpool SWF90W1
Whirlpool SWF90W2
Amana SWP25H Ref - SXS/I&W
Whirlpool SWP70W0
Whirlpool SWP80W0
Whirlpool SWP90W0
Amana SWPD25H Ref - SXS/I&W
White Westinghouse SWS1233CQ0 White Westinghouse/washer
White Westinghouse SWS1233CQ1 White Westinghouse/washer
White Westinghouse SWS1233CS0 White Westinghouse/washer
White Westinghouse SWS1233CS1 White Westinghouse/washer
White Westinghouse SWS1339CC1 White Westinghouse/washer
White Westinghouse SWS1339CC2 White Westinghouse/washer
White Westinghouse SWS1549AQ0 Washer - W.westinghouse
White Westinghouse SWS1549AQ1 Washer - West/grupo Famsa
White Westinghouse SWS1549AQ2 White Westinghouse/washer
White Westinghouse SWS1549AS0 Washer - W.westinghouse
White Westinghouse SWS1549AS1 Washer - West/grupo Famsa
White Westinghouse SWS1549AS2 White Westinghouse/washer
White Westinghouse SWS1649CQ0 White Westinghouse/washer
White Westinghouse SWS1649CQ1 White Westinghouse/washer
White Westinghouse SWS1649CS0 White Westinghouse/washer
White Westinghouse SWS1649CS1 White Westinghouse/washer
White Westinghouse SWS933AQ0 Washer - W.westinghse
White Westinghouse SWS933AQ1 Washer - West/grupo Famsa
  #2 (permalink)
Old 11-06-2009, 04:52 AM
denman denman is offline
Senior Expert
APP Volunteer
denman will become famous soon enough
Default
Perhaps this will help
http://www.servicematters.com/maytag...s/16010191.pdf
__________________
  #3 (permalink)
Old 11-06-2009, 12:10 PM
Junior Member
Default
Thanks for sending that link. I figured out that there was pins in the new hinges that was keeping it open. I thought that were part of the hinge until I saw in the manaul that you put a pin in to keep the door open. Thanks for sending that.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Lid latch switch replaced still shows "L" fault code Cinco de Juan Washer Repair 1 10-01-2009 05:49 PM
Oven Door Hinges Replaced, Now Bad Again Mikeh14 Oven Repair (including Ranges and Cooktops) 6 02-17-2009 11:51 AM
Replaced Door seal, door wont close ggreen3 Dishwasher Repair 3 12-18-2008 10:17 AM
GE Profile Harmony "Close the Lid" message fix fifty7kevie Washer Repair 0 02-25-2008 11:41 AM
My Oven Door Latch Won't unlock so the door won"t close Victorine Ravenell Oven Repair (including Ranges and Cooktops) 1 11-14-2007 11:40 AM
