Discuss
Garland G283 - Oven temp all over the place
 in
Hi folks, bought an older home last year with a Garland G283 gas range - double oven, six burners, griddle,
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Garland G283 - Oven temp all over the place
  #1 (permalink)
Old 06-11-2018, 11:41 PM
Junior Member
oswaldt is on a distinguished road
Default Garland G283 - Oven temp all over the place
Model Number: G283   Brand: -other-   Age: More than 10 years
Hi folks, bought an older home last year with a Garland G283 gas range - double oven, six burners, griddle, and broiler. Burners, griddle, and broiler all work well but the ovens don't maintain temperature.
I hooked up the thermometer I use for smoking to it this evening and charted out the temperature in one oven. When I set the oven to 300 degrees the saw tooth pattern of the oven cycling had 300 degrees at the top of the saw tooth (seemed to average cooler than set). When set to 400 the pattern had 400 in the lower third of the pattern (seemed to average hotter than set). When set to 500 the oven hit about 480 then averaged around 475, never hitting 500. Finally when set to 425 over about 30 minutes it dropped to 417 and then climbed all the way to 450 then dropped back to 430...
I can post a graph if that will help. My thought is that the thermostat must be shot given that the temperatures were all over the place. Does that make sense? Anything else I should check?
Appreciate the help!
Related Models
Whirlpool G2IXEFMWB00 REFRIGERATOR
Whirlpool G2IXEFMWB01 REFRIGERATOR
Whirlpool G2IXEFMWB02 REFRIGERATOR
Whirlpool G2IXEFMWB03 REFRIGERATOR
Whirlpool G2IXEFMWQ00 REFRIGERATOR
Whirlpool G2IXEFMWQ01 REFRIGERATOR
Whirlpool G2IXEFMWQ02 REFRIGERATOR
Whirlpool G2IXEFMWQ03 REFRIGERATOR
Whirlpool G2IXEFMWS00 REFRIGERATOR
Whirlpool G2IXEFMWS01 REFRIGERATOR
Whirlpool G2IXEFMWS02 REFRIGERATOR
Whirlpool G2IXEFMWS03 REFRIGERATOR
Frigidaire G30BCL2 Frg(v2) / Gas Range
Frigidaire G30BCW1 Frg(v1) / Gas Range
Frigidaire G30CL0 Frg(v5) / Gas Range
Frigidaire G30CL2 Frg(v2) / Gas Range
Frigidaire G30CL3 Frg(v4) / Gas Range
Frigidaire G30CW0 Frg(v6) / Gas Range
Frigidaire G30CW2 Frg(v1) / Gas Range
Frigidaire G30CW3 Frg(v3) / Gas Range
Frigidaire G30LPNL1 Frg(v2) / Gas Range
Frigidaire G30LPNL2 Frg(v2) / Gas Range
Frigidaire G30LPNL3 Frg(v2) / Gas Range
Frigidaire G30LPNW1 Frg(v1) / Gas Range
Frigidaire G30LPNW2 Frg(v1) / Gas Range
Frigidaire G30LPNW3 Frg(v1) / Gas Range
Frigidaire G30NL1 Frg(v1) / Gas Range
Frigidaire G30NL2 Frg(v2) / Gas Range
Frigidaire G30NL3 Frg(v3) / Gas Range
Frigidaire G30NL4 Frg(v4) / Gas Range
Frigidaire G30NL5 Frg(v2) / Gas Range
Frigidaire G30NL6 Frg(v2) / Gas Range
Frigidaire G30NL7 Frg(v4) / Gas Range
Frigidaire G30NW1 Frg(v5) / Gas Range
Frigidaire G30NW2 Frg(v6) / Gas Range
Frigidaire G30NW3 Frg(v7) / Gas Range
Frigidaire G30NW4 Frg(v8) / Gas Range
Frigidaire G30NW5 Frg(v1) / Gas Range
Frigidaire G30NW6 Frg(v1) / Gas Range
Frigidaire G30NW7 Frg(v3) / Gas Range
Frigidaire G30PCL0 Frg(v7) / Gas Range
Frigidaire G30PCL1 Frg(v7) / Gas Range
Frigidaire G30PCL3 Frg(v2) / Gas Range
Frigidaire G30PCW0 Frg(v8) / Gas Range
Frigidaire G30PCW1 Frg(v8) / Gas Range
Frigidaire G30PCW3 Frg(v1) / Gas Range
Frigidaire G30PNL1 Frg(v2) / Gas Range
Frigidaire G30PNL2 Frg(v2) / Gas Range
Frigidaire G30PNL3 Frg(v4) / Gas Range
Frigidaire G30PNL4 Frg(v6) / Gas Range
Frigidaire G30PNL6 Frg(v2) / Gas Range
Frigidaire G30PNL7 Frg(v2) / Gas Range
Frigidaire G30PNW1 Frg(v1) / Gas Range
Frigidaire G30PNW2 Frg(v1) / Gas Range
Frigidaire G30PNW3 Frg(v3) / Gas Range
Frigidaire G30PNW4 Frg(v5) / Gas Range
Frigidaire G30PNW6 Frg(v1) / Gas Range
Frigidaire G30PNW7 Frg(v1) / Gas Range
Admiral G3110PRA-M RANGE- F/S STD GAS
Admiral G3110PRA5K RANGE- F/S STD GAS
Admiral G3110PRW-M RANGE- F/S STD GAS
Admiral G3110PRW5K RANGE- F/S STD GAS
Admiral G3127WRA RANGE- F/S STD GAS
Admiral G3127WRA-3 RANGE- F/S STD GAS
Admiral G3127WRA-4 RANGE- F/S STD GAS
Admiral G3127WRA-5 RANGE- F/S STD GAS
Admiral G3127WRV RANGE- F/S STD GAS
Admiral G3127WRV-3 RANGE- F/S STD GAS
Admiral G3127WRV-4 RANGE- F/S STD GAS
Admiral G3127WRW-3 RANGE- F/S STD GAS
Admiral G3127WRW-4 RANGE- F/S STD GAS
Admiral G3127XRA-5 RANGE- F/S STD GAS
Frigidaire G31BFH0 Frg(v3) / Gas Range
Frigidaire G31BFH1 Frg(v6) / Gas Range
Frigidaire G31BFL0 Frg(v2) / Gas Range
Frigidaire G31BFL1 Frg(v5) / Gas Range
Frigidaire G31BFW0 Frg(v1) / Gas Range
Frigidaire G31BFW1 Frg(v4) / Gas Range
Frigidaire G31BPNL1 Frg(v2) / Gas Range
Frigidaire G31BPNL2 Frg(v4) / Gas Range
Frigidaire G31BPNL3 Frg(v2) / Gas Range
Frigidaire G31BPNL4 Frg(v2) / Gas Range
Frigidaire G31BPNL5 Frg(v2) / Gas Range
Frigidaire G31BPNL6 Frg(v2) / Gas Range
Frigidaire G31BPNW1 Frg(v1) / Gas Range
Frigidaire G31BPNW2 Frg(v3) / Gas Range
Frigidaire G31BPNW3 Frg(v1) / Gas Range
Frigidaire G31BPNW4 Frg(v1) / Gas Range
Frigidaire G31BPNW5 Frg(v1) / Gas Range
Frigidaire G31BPNW6 Frg(v1) / Gas Range
Admiral G32026PEKB REF - BOTTOM MOUNTS
Admiral G32026PEKS REF - BOTTOM MOUNTS
Maytag G32026PEKS13 REFRIGERATOR
Maytag G32026PEKS4 REFRIGERATOR
Maytag G32026PEKS5 REFRIGERATOR
Maytag G32026PEKS6 REFRIGERATOR
Maytag G32026PEKS7 REFRIGERATOR
Admiral G32026PEKW REF - BOTTOM MOUNTS
Maytag G32026PEKW12 REFRIGERATOR
Maytag G32026PEKW3 REFRIGERATOR
Maytag G32026PEKW4 REFRIGERATOR
Admiral G32026PELB REF - BOTTOM MOUNTS
Maytag G32026PELB12 REFRIGERATOR
Maytag G32026PELB3 REFRIGERATOR
Maytag G32026PELB4 REFRIGERATOR
Admiral G32027WEKB REF - BOTTOM MOUNTS
Maytag G32027WEKB11 REFRIGERATOR
Maytag G32027WEKB3 REFRIGERATOR
Admiral G3216SRA-M RANGE-F/S CONT CLEAN GAS
Admiral G3216SRW-M RANGE-F/S CONT CLEAN GAS
Admiral G3216WRA-M RANGE-F/S CONT CLEAN GAS
Admiral G3216WRW-M RANGE-F/S CONT CLEAN GAS
Admiral G3227WRA-M RANGE-F/S CONT CLEAN GAS
Admiral G3227WRAM3 RANGE-F/S CONT CLEAN GAS
Admiral G3227WRAM4 RANGE-F/S CONT CLEAN GAS
Admiral G3227WRW-M RANGE-F/S CONT CLEAN GAS
Admiral G3227WRWM3 RANGE-F/S CONT CLEAN GAS
Admiral G3227WRWM4 RANGE-F/S CONT CLEAN GAS
Admiral G3227XRA RANGE-F/S CONT CLEAN GAS
Admiral G3227XRA-3 RANGE-F/S CONT CLEAN GAS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Garland Commercial stove needs pilot help!??? washerTed Oven Repair (including Ranges and Cooktops) 0 10-13-2017 03:50 PM
Garland - griddle igniter sparks randomly wallacch Oven Repair (including Ranges and Cooktops) 0 09-06-2013 09:33 PM
garland commercial oven tomahawk Oven Repair (including Ranges and Cooktops) 0 11-23-2009 11:44 AM
Dishwasher place door back in place carieira Dishwasher Repair 3 07-14-2009 05:01 PM
garland oven won't ignite garyb Oven Repair (including Ranges and Cooktops) 1 01-29-2009 08:26 PM
