Discuss
Bosch HGI8054UC/06 Gas range burner screw
 in
Hello All, I wanted to replace the burners on the cooktop, since they were sort of discolored. Got new ones
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Bosch HGI8054UC/06 Gas range burner screw
  #1 (permalink)
Old 05-16-2018, 04:12 PM
Junior Member
carybimmer is on a distinguished road
Default Bosch HGI8054UC/06 Gas range burner screw
Model Number: HGI8054UC/06   Brand: Bosch   Age: 1 - 5 years
Hello All,
I wanted to replace the burners on the cooktop, since they were sort of discolored. Got new ones and while screwing one of the burners, I used too much torque and damaged the T20 screw-head; I am unable to get it out now. The ignitor is standing far too tall now to place the burner plate..Are there any instructions to remove the cooktop and access underneath to remove the screws. My first step is to try a damaged screw extractor. Assuming I get it out..each new screw is $16.00 which I find strange..
http://www.appliancepartspros.com/bo...ap3782964.html
Are these special screws.can I just get something from Home Depot?
First time here..thank you in advance for any recommendations..
Related Models
Thermador HGSI42TS
Thermador HGSW36TS
Maytag HJ61201JRT ELECTRIC WATER HEATER
Maytag HJ61202JRT ELECTRIC WATER HEATER
Maytag HJ6301JLS ELECTRIC WATER HEATER
Maytag HJ6301JLSCSA ELECTRIC WATER HEATER
Maytag HJ6301JRT2 ELECTRIC WATER HEATER
Maytag HJ6301JRT2CSA ELECTRIC WATER HEATER
Maytag HJ6302JLS ELECTRIC WATER HEATER
Maytag HJ6302JLSCSA ELECTRIC WATER HEATER
Maytag HJ6302JRT2 ELECTRIC WATER HEATER
Maytag HJ6302JRT2CSA ELECTRIC WATER HEATER
Maytag HJ630NORT GAS WATER HEATER
Maytag HJ630NORT2 GAS WATER HEATER
Maytag HJ630NORT2CGA GAS WATER HEATER
Maytag HJ630NORTCGA GAS WATER HEATER
Maytag HJ630PORT GAS WATER HEATER
Maytag HJ630PORT2 GAS WATER HEATER
Maytag HJ630PORT2CGA GAS WATER HEATER
Maytag HJ630PORTCGA GAS WATER HEATER
Maytag HJ6401JLS ELECTRIC WATER HEATER
Maytag HJ6401JLSCSA ELECTRIC WATER HEATER
Maytag HJ6401JRS ELECTRIC WATER HEATER
Maytag HJ6401JRSCSA ELECTRIC WATER HEATER
Maytag HJ6401JRT2 ELECTRIC WATER HEATER
Maytag HJ6401JRT2CSA ELECTRIC WATER HEATER
Maytag HJ6401JRT2CSAF ELECTRIC WATER HEATER
Maytag HJ6401JRT2F ELECTRIC WATER HEATER
Maytag HJ6401JT4W ELECTRIC WATER HEATER
Maytag HJ6401JT4WCSA GAS WATER HEATER
Maytag HJ6402JLS ELECTRIC WATER HEATER
Maytag HJ6402JLSCSA ELECTRIC WATER HEATER
Maytag HJ6402JRS ELECTRIC WATER HEATER
Maytag HJ6402JRSCSA ELECTRIC WATER HEATER
Maytag HJ6402JRT2 ELECTRIC WATER HEATER
Maytag HJ6402JRT2CSA ELECTRIC WATER HEATER
Maytag HJ6402JRT2CSAF ELECTRIC WATER HEATER
Maytag HJ6402JRT2F ELECTRIC WATER HEATER
Maytag HJ6402JT4W ELECTRIC WATER HEATER
Maytag HJ6402JT4WCSA GAS WATER HEATER
Maytag HJ640NBDS GAS WATER HEATER
Maytag HJ640NBDSCGA GAS WATER HEATER
Maytag HJ640NBDVT GAS WATER HEATER
Maytag HJ640NBDVTCGA GAS WATER HEATER
Maytag HJ640NBPDT GAS WATER HEATER
Maytag HJ640NBPDTCGA GAS WATER HEATER
Maytag HJ640NBRS GAS WATER HEATER
Maytag HJ640NBRSCGA GAS WATER HEATER
Maytag HJ640NBRT GAS WATER HEATER
Maytag HJ640NBRT2 GAS WATER HEATER
Maytag HJ640NBRT2CGA GAS WATER HEATER
Maytag HJ640NBRTCGA GAS WATER HEATER
Maytag HJ640NBRTF GAS WATER HEATER
Maytag HJ640NBRTFCGA GAS WATER HEATER
Maytag HJ640NOCT42W GAS WATER HEATER
Maytag HJ640NOCT52W GAS WATER HEATER
Maytag HJ640NOLS GAS WATER HEATER
Maytag HJ640NOLSCGA GAS WATER HEATER
Maytag HJ640NORS GAS WATER HEATER
Maytag HJ640NORS2 GAS WATER HEATER
Maytag HJ640NORS2CGA GAS WATER HEATER
Maytag HJ640NORSCGA GAS WATER HEATER
Maytag HJ640NORT GAS WATER HEATER
Maytag HJ640NORT2 GAS WATER HEATER
Maytag HJ640NORT2CGA GAS WATER HEATER
Maytag HJ640NORTCGA GAS WATER HEATER
Maytag HJ640NOVET GAS WATER HEATER
Maytag HJ640NOVET2 GAS WATER HEATER
Maytag HJ640NOVET2CGA GAS WATER HEATER
Maytag HJ640NOVETCGA GAS WATER HEATER
Maytag HJ640NOVIT GAS WATER HEATER
Maytag HJ640NOVIT2 GAS WATER HEATER
Maytag HJ640PBDS GAS WATER HEATER
Maytag HJ640PBDSCGA GAS WATER HEATER
Maytag HJ640PBDVT GAS WATER HEATER
Maytag HJ640PBDVTCGA GAS WATER HEATER
Maytag HJ640PBPDT GAS WATER HEATER
Maytag HJ640PBPDTCGA GAS WATER HEATER
Maytag HJ640PBRS GAS WATER HEATER
Maytag HJ640PBRSCGA GAS WATER HEATER
Maytag HJ640PBRT GAS WATER HEATER
Maytag HJ640PBRT2 GAS WATER HEATER
Maytag HJ640PBRT2CGA GAS WATER HEATER
Maytag HJ640PBRTCGA GAS WATER HEATER
Maytag HJ640PBRTF GAS WATER HEATER
Maytag HJ640PBRTFCGA GAS WATER HEATER
Maytag HJ640POCT42W GAS WATER HEATER
Maytag HJ640POCT52W GAS WATER HEATER
Maytag HJ640POLS GAS WATER HEATER
Maytag HJ640POLSCGA GAS WATER HEATER
Maytag HJ640PORS GAS WATER HEATER
Maytag HJ640PORS2 GAS WATER HEATER
Maytag HJ640PORS2CGA GAS WATER HEATER
Maytag HJ640PORSCGA GAS WATER HEATER
Maytag HJ640PORT GAS WATER HEATER
Maytag HJ640PORT2 GAS WATER HEATER
Maytag HJ640PORT2CGA GAS WATER HEATER
Maytag HJ640PORTCGA GAS WATER HEATER
Maytag HJ640POVET GAS WATER HEATER
Maytag HJ640POVET2 GAS WATER HEATER
Maytag HJ640POVET2CGA GAS WATER HEATER
Maytag HJ640POVETCGA GAS WATER HEATER
Maytag HJ640POVIT GAS WATER HEATER
Maytag HJ640POVIT2 GAS WATER HEATER
Maytag HJ6501JLSW ELECTRIC WATER HEATER
Maytag HJ6501JLSWCSA ELECTRIC WATER HEATER
Maytag HJ6502JLSW ELECTRIC WATER HEATER
Maytag HJ6502JLSWCSA ELECTRIC WATER HEATER
Maytag HJ650NBDS GAS WATER HEATER
Maytag HJ650NBDSCGA GAS WATER HEATER
Maytag HJ650NBDVT GAS WATER HEATER
Maytag HJ650NBDVTCGA GAS WATER HEATER
Maytag HJ650NBPDT GAS WATER HEATER
Maytag HJ650NBPDTCGA GAS WATER HEATER
Maytag HJ650NBRT GAS WATER HEATER
Maytag HJ650NBRT2 GAS WATER HEATER
Maytag HJ650NBRT2CGA GAS WATER HEATER
Maytag HJ650NBRTCGA GAS WATER HEATER
Maytag HJ650NKRT GAS WATER HEATER
Maytag HJ650NKRTCGA GAS WATER HEATER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Stuck Screw on burner in a slide in range nageshb Oven Repair (including Ranges and Cooktops) 1 07-20-2010 01:43 PM
Confirm Tappan Range Top & Sealed Burner Screw Removal farmer186 Oven Repair (including Ranges and Cooktops) 0 01-24-2010 11:52 AM
Confirm Tappan Range Top & Sealed Burner Screw Removal farmer186 Oven Repair (including Ranges and Cooktops) 0 01-24-2010 11:45 AM
Confirm Tappan Range Top & Sealed Burner Screw Removal farmer186 Trash Compactor Repair 0 01-24-2010 11:40 AM
Bosch dishwasher's terminal screw is damaged petermanko Dishwasher Repair 1 11-12-2008 04:43 PM
