| » Dual Infinite Switch Wiring |
Hi Charlie,
I would start from determining which wire where goes on the stove. Which wire is In and which wire is Out. The picture of the old switch you posted is not very clear. Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Gene, Joe, and all who have helped:
For the 6 inch single burner (right rear burner for J/A cooktop CVE3401B) I purchased part #74011242. It is easy to replace and there is no problem for the screw holes. Finally, we are done. Thank you all. Fyao |
Quote:
Black Cable goes to terminal 2 on the old switch Orange cable goes to terminal 5 on the old switch Violet cable goes to terminal 4 on the old switch Blue cable goes to terminal 3 on the old switch I upload an image of the original circuit somewhere in this post you can see the circuit of the replacement switch, if you can't find it I'll scan it and upload it. thanks in advance for your help Charlie |
Hi Charlie,
The Red wire (N terminal from L2 on the LF switch) should go to the P2. The Red wire from the element goes to 2. The Black wire (terminal 2) goes to P1. The Orange wire (terminal 5) goes to S2. The Violet wire (terminal 4) goes to 4a. The Blue wire (terminal 3) goes to 4. Gene.
__________________
| Display Modes | |
| infinite switch wiring change from 6 wires to 5 wire switch | wiedemanndds | Oven Repair (including Ranges and Cooktops) | 5 | 11-24-2009 02:14 PM |
| Wiring for dual infinite switch | captain stan | Oven Repair (including Ranges and Cooktops) | 0 | 05-16-2009 02:37 PM |
| Dual Infinite Switch Replacement | david.freeland@sacorp.com | Oven Repair (including Ranges and Cooktops) | 1 | 09-24-2008 03:30 PM |
| Replacing Dual Infinite Switch on Range | juchunk | Oven Repair (including Ranges and Cooktops) | 0 | 05-02-2008 07:51 AM |
| Infinite Wire Switch Dual Element | leighr3 | Oven Repair (including Ranges and Cooktops) | 1 | 12-11-2007 01:04 PM |
